"FOG LIGHTS ON W/PARKING...LOW BEAM...HIGH BEAM..."
Discussion in 'Lighting' started by "OLYMPIC VIEW", Jan 9, 2011.
  1. Mar 30, 2013 at 7:15 AM
    #321
    Txfly
    Txfly Well-Known Member
    WNC
    It's silver
    '09 Dbl cab, TRD suspension plus 2" lift, LEDS, FJ TRD rims. All around pretty mild.
    I did the jump to the towing relay...That's what was freaky about it. There shouldn't be any power when the key is off/ out.
  2. Apr 6, 2013 at 8:06 PM
    #322
    Marcs2012
    Marcs2012 Well-Known Member
    Honolulu
    Trd sport
    Hi guys new member here want to do this mod and not sure what I need to do this as I probably don't have these tools can anyone tell me what I need?
    And does this mod affect my warrantee if toyota see's this?:confused:
  3. Apr 21, 2013 at 5:03 PM
    #323
    cshughes79
    cshughes79 Active Member
    chuck
    Tri cities, va
    2012 tacoma 4x4 double cab
    nerf bars;3" toytec lift 885 coils and Ol Man Emmu shocks in the front add aleaf in the rear
    Alright I installed the OME fog lights this weekend, and I want to do this mod. But my truck is the base model 2012 4x4 and I had to add the tow package later so in the fuse box in the engine compartment I don't have any of the relays you guys show in the pictures. Does anybody know how I can do this mod, I can post pics of my fuse boxes it helps someone help me figure out what to do.
  4. Apr 21, 2013 at 5:26 PM
    #324
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Base model is a crap shoot.
    SR5 is usually prewired.
    Look down into the fuse box where the fuses and relays are to be installed. If you see brass contacts, you are likely prewired. If not, you're on your own, and adding a tow package is going to be a major ordeal.
  5. Apr 22, 2013 at 10:24 PM
    #325
    cshughes79
    chuck
    Tri cities, va
    Here are the pics from my fuse box, any ideas on how to do the mod?
  6. Apr 22, 2013 at 10:25 PM
    #326
    cshughes79
    chuck
    Tri cities, va
    i do have a relay that i had to put in for the fog lights i was thinking i could jump off that but where do i jump it to.
  7. Apr 24, 2013 at 6:23 PM
    #327
    x.trouttaco
    x.trouttaco New Member
    Brad
    Maryland
    2011 Tacoma- TRD Sport
    I just bought a used 2011 Tacoma and it won't pass MD inspection due to fogs lights staying on when I turn on my brights. I'm assuming the previous owner did the MOD but I am wondering if anyone had a suggestion for fixing this to pass inspection.
    Thanks!!
  8. Apr 29, 2013 at 3:27 PM
    #328
    anarion55
    anarion55 Well-Known Member
    Tony
    S. Florida
    2013 PreRunner SR5
    ImMrYo's Mirror Mod, Stereo Upgrade - Power Pro 60x4 Amp/Kicker powered 8" sub/Pioneer component speakers, PassPort 8500 Radar Detector, Locking Bed Storage Cubbies, Onboard air system - Viair 450C compressor/16 gal. PVC tank/15 & 16" horns, quick-d/c air chuck in bed cubby 24" LED light Bar (mounted to skidplate)A Headlights, foglights interior lights and backup lights all converted to LED (HUGE difference)
    Does this affect the towing lights at all?
  9. May 3, 2013 at 10:25 AM
    #329
    DannyD
    DannyD Well-Known Member
    Dan
    BC Canada
    2021 DCLB
    I screwed something up doing this. I touched the wrong wire under the fog lamp relay. Now I have a bunch of lights on my dash. Abs, traction, and the "!" one. I imagine a fuse is blown somewhere. Any idea which one. All lights are still working. Tried disconnecting the negative terminal of the battery for 10 minutes but they just came back.
    Edit, blew IGN #2 inside the cab fuse box.
    For any bodies future reference. I tried coming into that fog relay post from underneath to make it cleaner. That will leave the lights on all the time. Which made me start playing around and going outside the directions. And blew the fuse.
  10. May 15, 2013 at 6:22 PM
    #330
    Dr.TunaTaco
    Dr.TunaTaco Member
    Colorado
    txpro
    So I have 2012 txpro and it seems to me that my tow relay is in a different spot n the fuse block it shows to be the bottom right blue one not the brown one HELP!!!
  11. May 26, 2013 at 11:02 AM
    #331
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    2012 Tacoma TRD T|X Baja
    Pelfreybilt IFS Skid, Mid Skid and Plate Bumper, Rigid Industries Dually's, ARB CKMA12 On Board Air, Kenwood TM-281A Radio, Rear view mirror relocation bracket, Wheelers SuperBumps, Toytec Baja Spacer
    Finally got around to doing this. NO idea why I waited so long. Took me 3 min tops lol. Works like a charm.
  12. Jun 4, 2013 at 5:38 PM
    #332
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    question, I have a 2012 and I followed the directions, are you supposed to be able to turn the fogs on and off without your parking lights on? I have to click the light stock up once which turns on my brake lights also and dims everything in the cab, is this right?
    Alex
  13. Jun 4, 2013 at 9:47 PM
    #333
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Nope not according to mine. Got any Pics of how you went about it? Mine only requires the key to be in the on position, no other lights need to be on.
  14. Jun 5, 2013 at 9:42 AM
    #334
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    I followed the diagram on the previous page. I'll take some pics today at lunch. Does your green light come on (fog light) the dash or is that reserved for when your lights are all the way on? Hmmmm I cant remember if I tested with the key in the on position, I'll give that a shot and report back.
  15. Jun 5, 2013 at 2:11 PM
    #335
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    So I followed your instructions and no dice. I turned the key to "On" and pressed the fog light button, no lights. I then left the key in the "On" position and turned the light stock one click to engage the parking lights, that's when the fogs kicked on. couldnt get any pictures of how I did the mod (at work in nice clothes :) ) so I'll have to get pics later today and or just try it again.
  16. Jun 7, 2013 at 4:07 PM
    #336
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    Still haven't had a chance to get under there and get you some pics. I'll grab em tonight when I get home from work. Thanks for the help!
    EDIT: So this is what I have going on.
    Appreciate the help!
    Alex
  17. Jul 15, 2013 at 8:32 PM
    #337
    machineman89
    machineman89 Well-Known Member
    Matthew
    San Leandro
    overlanding limo in progress :-P
    Weather tech floor mats, fog light any time mod, derped front embelem, Pelfretbilt 3 hoop plate bumper, 10k warn xeon winch-s some leds, pelfreybilt roof rack, scs stealth series rims, wrangler authority tires, BAMF 96" bolt on sliders, BAMF dif skid, some dirt....
    ......inspections??????? what exactly are these "inspections"????
  18. Jul 15, 2013 at 8:39 PM
    #338
    Rich91710
    Rich
    Los Angeles
    08 Base
    A lot of states have annual safety inspections that they need to pass to renew their tags.
    It's on the books in California, but it's an "on demand" thing.
    In the 60s and 70s, CHP would set up roadblocks all the time and pull inspections. If you got tagged, the car had to be repaired and signed off by a certified headlight/brake mechanic (most gas stations were certified).
    If you passed, you got a CHP sticker for your windshield so you wouldn't be bothered the rest of the year.
    The law is still on the books, and these certified stations still exist.
  19. Jul 15, 2013 at 9:42 PM
    #339
    machineman89
    Matthew
    San Leandro
    hmm...never dealt with anything like that before... i jus got a lecture from my old man who's a class A driver bout driving with fogs on n no headlights, i guess i'll have to be aware when i have em on and i dnt believe i'll have a problem.....only time i dealt with a inspection was when we had to get my old car bought back after an accident n it was salvaged title, inspection needed...... they do those road block still????
  20. Jul 15, 2013 at 9:54 PM
    #340
    Rich91710
    Rich
    Los Angeles
    08 Base
    I haven't seen a roadblock since I was probably 8 years old, but the law is still on the books. Used to be fun out riding with mom to see who would be the first to spot the cops at the side of the road having their "pow-wow" before setting up a checkpoint.
    They'd check your headlight alignment to make sure they were aimed properly, brake check (not sure how they did it), and sometimes they'd have a speedo check machine to verify your speedo calibration. I only remember mom getting caught in one once when I was very young. Funny that my "poor" friends parents always seemed to have the inspection stickers on their windshields and we never did. I have a feeling there was a lot of profiling going on in selecting who they would pull into the checkpoint. A current-model Buick didn't draw much attention from anyone other than women looking to hook up with a doctor ;)
    Likely the roadblocks would jam traffic too badly today... that, and all of the cars they'd have to tow because of drivers without licenses or insurance.
