"FOG LIGHTS ON W/PARKING...LOW BEAM...HIGH BEAM..."
Discussion in 'Lighting' started by "OLYMPIC VIEW", Jan 9, 2011.
  1. Aug 7, 2016 at 5:26 AM
    #381
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Mines staying on when trucks is off and keys out.
  2. Aug 7, 2016 at 5:32 AM
    #382
    Gearheadesw
    Davenport Fl
    Fuck it. I quit. Fuck electrics.
  3. Aug 7, 2016 at 10:54 AM
    #383
    NordidiroN
    NordidiroN Well-Known Member
    Ron
    Georgia
    '15 DCSB SR5 4x4
    Retrax MX Pro bedcover, Avid bumper gaurd, Predator step rails, Aux D rings, Door sill protectors
    Ok, THAT is weird :notsure:
  4. Aug 7, 2016 at 10:58 AM
    #384
    NordidiroN
    Ron
    Georgia
    '15 DCSB SR5 4x4
    Is the jumper wire from the bent leg on your fog relay going to the leg of the tail/tow relay highlighted in red in this diagram?
  5. Aug 7, 2016 at 12:42 PM
    #385
    Gearheadesw
    Davenport Fl
    Thanks for the replys. I think that the numbering on the trailer relay is what's got me. 1 and 2 side by side on top, then I thought it was 3 then 4 coming down from the side by side 1 & 2.
  6. Aug 7, 2016 at 1:02 PM
    #386
    Gearheadesw
    Davenport Fl
    @NordidiroN, thank you sir. I was pissed earlier when I was obviously hooking it up wrong in the first place. Seems to be operating correctly now.
  7. Aug 7, 2016 at 1:29 PM
    #387
    NordidiroN
    Ron
    Georgia
    '15 DCSB SR5 4x4
    No prob. Glad I could help and glad you got it hooked up :thumbsup:
    Gearheadesw[QUOTED] likes this.
  8. Sep 5, 2016 at 3:11 PM
    #388
    SilverSky15
    SilverSky15 Well-Known Member
    Brian
    Florida
    '15 DoubleCab SR5
    Does anyone know how to wire them to come on with the DRLs on the '15s?
  9. Sep 14, 2016 at 9:15 AM
    #389
    hueman562
    hueman562 Well-Known Member
    ken
    los angeles
    13 double cab LB 4x4
    Does your dog light indicator still work on your instrument cluster?
  10. Dec 30, 2016 at 1:42 PM
    #390
    Dhannah
    Dhannah 2017 Tacoma OR DCSB
    Daniel
    North Carolina
    '17 DCSB OR TRD 4x4
    Under Construction
    what size wiring did you use and what did you use for the tips I am wanting mine to run when the truck turns on with the daylight running lights but if I dont want them on I can hit the FOG button and turn them on? Or will they run at ALL times.
  11. Dec 30, 2016 at 1:43 PM
    #391
    Dhannah
    Daniel
    North Carolina
    '17 DCSB OR TRD 4x4
    Under Construction
    subd
  12. Dec 30, 2016 at 1:44 PM
    #392
    Dhannah
    Daniel
    North Carolina
    '17 DCSB OR TRD 4x4
    Under Construction
    SUBD I want to know this also before I do it.
  13. Dec 30, 2016 at 1:45 PM
    #393
    Dhannah
    Daniel
    North Carolina
    '17 DCSB OR TRD 4x4
    Under Construction
    never mind I see the wiring now and the tips but still want to know if the fog light button will still work. I might not want them running all day everytime I ride.
  14. Dec 30, 2016 at 11:15 PM
    #394
    Suprajim54
    Suprajim54 Unfamous Member
    Jimbo
    Irving, TX
    Silver 2015 Tacoma SR5 4x4 DCSB
    King ET Coilovers, SPC UCA's, 5160 Rears, Icon Progressive AAL, Method 701, STT Pro 285/75/16, SOS Offroad Skid and Sliders
    I just did this mod on my 2015 the other day. I bent the blade on the fog light relay in the small fusebox, used a female spade connector on a 16ga wire that I ran out of that box to an inline fuse to a t-tap on a light green wire in the main fusebox. It is a switched ignition wire, so the foglights are controlled completely by the on/off switch as long as the key is in the ACC/ON position.
  15. Feb 22, 2017 at 4:37 PM
    #395
    Bravisimo
    Bravisimo So many mods, very little money.
    Joe
    Santa Clarita, CA
    2014 Tacoma PreRunner SR5 DCLB
    Tint, headlights wrapped & rear lights smoked, power outlet mod., grill & rear bumper wrapped, Falken A/T 3W,
    Pics? I tried to do this today but I couldn't so Im looking for an alternative. My small fuse box only has two fuse boxes and thats it. I have a 2014 Pre SR5 V6. No tow package. No TRD. No 4x4.
  16. Feb 22, 2017 at 4:50 PM
    #396
    Suprajim54
    Jimbo
    Irving, TX
    You can see my purple T-Tap on the light green wire near the top left corner. I bent the tab on the relay and connected a red wire with a female spade connector as you see in bottom right. I ran that wire through a hole in the bottom of that relay box and back up through another hole in the fuse box. The other end of that wire has a male spade connector that plugs into the purple T-Tap. No holes drilled at all.
    Bravisimo likes this.
  17. Feb 22, 2017 at 4:54 PM
    #397
    Bravisimo
    Joe
    Santa Clarita, CA
    That looks good. I take it that green wire is hot? Also, did u use a in line fuse from the small fuse box? If not why not?
  18. Feb 22, 2017 at 4:59 PM
    #398
    Suprajim54
    Jimbo
    Irving, TX
    The green wire is ignition powered so the lights will only come on when key is "ON" position and fog light switch on. Thanks for reminding me, I DID use a small inline fuse with 15amp fuse between the red wire and the spade connector that goes into T-Tap.
  19. Feb 24, 2017 at 8:47 AM
    #399
    Bravisimo
    Joe
    Santa Clarita, CA
    Sounds good. Looks like this will be the route I'm going to use. Thanks for all your help!
  20. Feb 24, 2017 at 9:22 AM
    #400
    Suprajim54
    Jimbo
    Irving, TX
    Yes, sir. Good luck!:thumbsup:
