Fog lights, on without headlights mod?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rc2125, Oct 22, 2008.
  1. Oct 22, 2008 at 11:41 AM
    rc2125
    rc2125 [OP] Well-Known Member
    Indiana/Michigan border
    09 TRD
    Would like to be able to use my fog/driving lights without the headlights being on. Figured I would ask first, before digging into the switches/relays/etc. Didn't find anything in search.
  2. Oct 22, 2008 at 11:48 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    its already a sticky. Called fog light mod. Piercedtiger has taken the time to explain it and take a picture or 2.
  3. Oct 22, 2008 at 11:51 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  4. Oct 22, 2008 at 11:52 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
  5. Oct 22, 2008 at 1:07 PM
    rc2125
    09 TRD
    Thanks!
  6. Apr 1, 2010 at 9:51 PM
    lextech
    lextech Member
    There is still a better way to do it, no cutting, no splicing. Also doing it that way has no fuse protection.
  7. Apr 1, 2010 at 10:48 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    your right, you can take apart the fuse block and do it that way so you dont see anything. and your right there is no fuse protection....BUTTTT just add a fuse then guess what, your protected.
  8. Apr 2, 2010 at 5:46 AM
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
    Where would you put the fuse? In line with the 6" wire the write up talks about? Also, what size fuse? I want to do this for driving on the beach at night with just fogs and I'd like to put the fuse in while I'm there.
  9. Apr 2, 2010 at 6:08 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Blackstone, MA
    '09 Sport DCLB Met Grey
    Toyota bed mat (1st mod), Toyota all season floor mats, Rear spring TSB, Map light mod, Fog light mod, Putco yellow fog bulbs, Weather Tech window vents, Extra d-rings, Mounted mag light, TRD CAI with AFE pro dry filter, '05 front mud flaps (winter only), 2 set's of wheels/tires, 285/75/16 Hankook MT's, Black Painted 1st Gen TRD wheels (wheeling set) Black powder coated FJ Cruiser with 265/70/17 BFGoodrich KO2's (everyday), painted center of grill & bumper black, Devil horns, OME with 885's + spacers front, OME shocks w/OMD designed rear springs, Front diff drop, Rear trailer plug relocate, ATO IFS skid, Relentless Trans & Transfer skids, BAMF bolt on rock sliders, Relentless tailgate reinforcement, Uniden 75 CB radio, BAMF antenna bracket, TRD exhaust, high lift jack w/ATO mounts. And of course ProEFX Towing Mirrors!
    What way are you talking about???
  10. Apr 2, 2010 at 6:06 PM
    lextech
    lextech Member
    Still bend the tab on your fog relay but other than splicing into green wire i got my power from the switched side of the "Towing tail" relay. The only time that relay is switched on is when park lights are on. Its in the same box so no cutting, drilling, splicing or running wires inside like all the other ways i have seen to do this. I can go back and get the specifics if any ones cares.
  11. Apr 3, 2010 at 5:34 AM
    mach1man001
    Rob
    Blackstone, MA
    I'd love to get them. Also do you have any pic's?
  12. Apr 3, 2010 at 9:56 AM
    lextech
    lextech Member
    I will work on some pics this afternoon and shoot those and the pins you need to go to.
  13. Apr 3, 2010 at 5:42 PM
    raycie
    raycie Well-Known Member
    Oahu, HI
    16 T4R Trail
    In need of $$$
    I have been thinking of doing this mod for a long time as well.. Just never got around to it..
    Lextech... I would like to see the pics as well.. Thanks..
  14. Apr 3, 2010 at 5:47 PM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    yea i am interested as well...please post a write up
  15. Apr 3, 2010 at 5:52 PM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    What size fuse should I put in line if I want to have one?
    I'm getting my power from the solid green wire like most people have done
    Thanks for any info...
  16. Apr 3, 2010 at 7:18 PM
    wushaw
    wushaw Well-Known Member
    Texas
    08 AC TRD 4x4 6sp
    So where does the relay get power from? Fuse??
  17. Apr 4, 2010 at 10:31 AM
    lextech
    lextech Member
    Ok well first remove your Fog light relay, bend Pin 1 on the relay.
    Crimp a small famale blade connector to a short length of wire. Install that connector to the bent terminal on the fog relay and reinstall the relay. strip the other end of the wire. Remove the Towing tail relay, slide the striped end of the wire into Pin 3 of the relay socket and reinstall the relay. For the Pins i am talking about i have posted a diagram and it is just the same as you will be looking at it when you remove the cover.
  18. Apr 5, 2010 at 11:53 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    has anyone tryed this other type of mod to see how well it works
    just curious cause I have that kind of luck where tapping into the green wire would probaly kill my truck:frusty:
  19. Apr 6, 2010 at 4:50 AM
    mach1man001
    Rob
    Blackstone, MA
    OK Lextech I have one more question. Does doing it this way make the fogs work anytime the key is on or when you put the parking lights on?
  20. Apr 6, 2010 at 4:58 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    08 V6 4x4 DC TRD, 6spd
    TRD Supercharger, TRD CAI, Sirius, Rear TSB, Front 5100 with Eibach coils, 1.5" AAL, URD short throw, fog light mod, weather tech liners,
    I like this idea better, running fogs with parking, also ensure I will not leave them on when the key is off.
    reading an earlier post, parking lights need to be on, since this is how the power is taken from the towing tail relay.
