FOUND IT! Post lift clunking and knocking.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jtweezy, Dec 23, 2015.
  1. Feb 1, 2016 at 9:35 AM
    #141
    jtweezy
    jtweezy [OP] Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Got the truck re-aligned this morning after the new struts and tie rod ends and everything feels great. Caster is still not in spec, but it's on stock UCAs and drives fine, so I'm happy.
    I also haven't heard the rear end clunk in over a week. I'm going to try greasing the rear leafs again to see if that's causing them to rotate/shift.
  2. Feb 8, 2016 at 6:49 AM
    #142
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Bad news...
    The clunk is back. Same situations, same driveway will cause the clunk.
    Now I'm trying to answer the question...What happens while/after swapping the front suspension that cause the clunk to go away at first, and then return?
    Having swapped the front coils out/in gives me a lot of info about the parts. The ones I didn't swap out have to be ok since the clunk went away for a while. LCA, UCA, swaybar, etc can be considered "fine". In fact, they should all be "ok" since the clunk did go away.
    Loose nuts and bolts that were retightened when I reassembled and have now come loose again? Possible but not likely as I torqued everything trying to fix the clunk before swapping coils. This one is frustrating because it's the least likely because I checked them all, but most likely from a logical standpoint.
    Sanity check? Am I confused and not seeing it?
  3. Feb 8, 2016 at 7:57 AM
    #143
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
  4. Feb 8, 2016 at 8:29 AM
    #144
    Saskabush
    Saskabush Well-Known Member
    Adam
    Saskatchewan, Canada
    2013 TRD Sport
    Elka 2.5" DSC w/ Deaver Stage 1, Archive Hammer Hangers, SPC UCAs, Timbren bumps, 16" TRD baja wheels, 265/75r16 BFG K02, 1.25" wheel spacers, TRD skid plate, N-Fab spare tire box mount.
    Did you replace or do anything with the rubber bushing between the coils and the top plate? I did an absurd amount of research trying to figure out what was causing the noise on mine and quite a few forums mention this. Apparently even getting a small amount of grease on it can cause it or the coil to move when the suspension cycles. Sometimes it makes a creaking noise and sometimes it makes a pop or clunk noise. Some sites say lube it and some say glue it. I'm not really sure what the pros and cons are to each but I'm leaning towards gluing mine in place.
  5. Feb 8, 2016 at 9:51 AM
    #145
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    I didn't do anything special to the bushing on the strut. No grease, no glue. I guess I could mark the coil and spring and see if it's rotating.
  6. Feb 8, 2016 at 10:22 AM
    #146
    mferguson
    mferguson Well-Known Member
    Marc
    2011 Tacoma TRD Sport
    does the truck have sliders? sometimes they knock on the pinch weld of the cab
  7. Feb 8, 2016 at 11:15 AM
    #147
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Unfortunately, no sliders.
  8. Feb 8, 2016 at 11:46 AM
    #148
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Is it more of a squeak or clunk when going over stuff? I chased down what sounded like a squeak over bumps for a long time and traced it down to be my radiator support bushings just being garbage and shifting over bumps.
  9. Feb 8, 2016 at 11:47 AM
    #149
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It may be best to take pictures of all this stuff and see if we can notice the both shock areas in detail etc. Etc. You get my point?
  10. Feb 8, 2016 at 12:04 PM
    #150
    1rooster
    1rooster TACOMA31750
    Georgia
    2007 Tundra crewmax
    5100's ALL WAY AROUND, 885X COILS, DRIVER SIDE LEAN SPACER, ICON PROGRESSIVE AAL W/O OVERLOAD, 265/75/16 KENDA KLEVER M/T. 1 1/4 SPIDERTRAC WHEEL SPACERS, GEN 1 TRD COLD AIR INTAKE, STOCK MUFFLER WITH CHOPPED TURNDOWN, 5% TINT OVER FACTORY, DEBADGED, TOYOTA RUBBER BED MAT, WEATHERTECH MATS,UWS TOOLBOX, UNDERCOVER SE, LOCKER MOD, REAR BUMPER, PIONEER DOUBLE DIN WITH PARKING BREAK OVER RIDE, CUSTOM OIL CATCH CAN, FULL LED INTERIOR, ARB BUMPER REPLACEMENT. COVERKING SEAT COVERS. MORIMOTO H1 MINI COVERSION WITH MINI GATLIN GUN SHROUDS AND 5000K MORIMOTO BULBS. TRAILER PLUG RELOCTED TO BUMPER. 20 INCH LED LIGHTBAR MOUNTED BEHIND CUSTOM PAINTED GRILL. STUBBY ATNENNA
    So did you not change out your LCA bushings? You need a camera or a go pro to rig up, and go into the same driveway that is causing the clank. Get it on camera and swap them out.
  11. Feb 8, 2016 at 12:33 PM
    #151
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Definitely not a squeak. Clunk/pop/knock are my best descriptions.
    Right on. I'll climb under there and shoot a video and get some pics.
    I did not change the LCA bushings. The more I paid attention to it, it doesn't line up with LCA bushing symptoms. Plus, it was gone for about 10 days and I hadn't don't anything to the LCAs.
    12TRDTacoma[QUOTED] likes this.
  12. Feb 8, 2016 at 12:48 PM
    #152
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I haven't tried to even figure out why mine does it, but it's just like yours. Only does it if the wheel is turned slightly and not over any big bumps. Just small bumps. I am gonna say fuck it and just upgrade the front. I don't see how adding a new fucking coil assembly up front is going to cause all this clunking.
  13. Feb 8, 2016 at 1:01 PM
    #153
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Me neither. If I didn't have a wedding to pay for this year I'd get new UCAs, ball joints, bushings, LCAs and any other random thing. Probably not the best approach either way, haha.
  14. Feb 8, 2016 at 1:04 PM
    #154
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I have new UCA's as well. It was fine for a month or so then bingo there it is. I do mostly highway anyway so I don't here it often. But the other day I was going through a Parking Lot that still had some icy bumps in it. And all you could feel and hear was clunk clunk clunk til I hit flat ground. Really fucking annoying is all I can say.
  15. Feb 8, 2016 at 1:21 PM
    #155
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    check the slip yoke. It clunks when under greased from the factory. It a common issues with tacomas and its covered under the 60K.
  16. Feb 8, 2016 at 1:25 PM
    #156
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Don't know a lot about underneath so where is this you speak of?
  17. Feb 8, 2016 at 1:31 PM
    #157
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    Mine has the same damn clunk on the driver side and I said fuck it as well. Ill keep up with this post and see what solutions you all find.
    Unchained 5150 likes this.
  18. Feb 8, 2016 at 1:32 PM
    #158
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Mine is a Mall Krawling Princess so I will live it until I sell it. Which is probably soon
  19. Feb 8, 2016 at 1:33 PM
    #159
    Thomas Jefferson
    Sacramento,CA
    '13 SR5 DCSB 4x4
    Its where the driveshaft connects to the rear differential. I brought it to the dealer due to the clunk thinking it had something to do with the brakes re adjusting or something but it ended up being the slip yoke.
    https://www.tacomaworld.com/threads/tsb-list-for-2005-toyota-tacoma.7107/
    Its T-SB-0250-12
    On here it says 2wd from 2005-2012 but the pdf is out of date. It effects both 4wd and 2wd from the 2nd Gen. Mine started doing it at about 30K and Toyota replaced the entire driveshaft at 35K for free.
  20. Feb 8, 2016 at 1:40 PM
    #160
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I can feel it right under my feet on the drivers side and in the steering wheel.
