From 18mpg to 16mpg after Seafoam, Undercover, and New Tires?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mc4nam, Mar 8, 2011.
  1. Mar 8, 2011 at 9:22 AM
    mc4nam
    mc4nam [OP] Well-Known Member
    Dallas, TX
    04 PreRunner
    I have a 2004 Double Cab Prerunner 3.4L auto with 84k. It has had all factory recommended service at the local Toyota Dealer since I bought it used in 2007.
    I was running 265/70/17 Firestone Destination A/T tires until about 3 weeks ago. I switched to 265/70/17 Bridgestone Dueler Alenza's. I am running 34psi in the tire, Max is 44psi. As expected, the ride has improved quite a bit going away from an A/T tire.
    I put an Undercover Tonneau on about 2 weeks ago and a ran the seafoam treatment through the engine about a month ago.
    I also started using Chevron 87 octane gas exclusively. In the past, I would just get gas at the nearest station
    I did not expect the tonneau cover or any of this to improve the mileage, well maybe a little? I did not expect it to get worse.
    Am I running the tire pressure to low?
    Are these tires known to get worse mileage?
    (I am still in the 30 day exchange period on the tires at Firestone if I choose.)
    Did seafoam cause fuel filter issues? Any issues?
    I am open to any ideas or suggestions to improve mileage. I did search Gas Mileage threads, but I thought I would put my specific information hoping that would help?
  2. Mar 8, 2011 at 9:36 AM
    scocar
    scocar hypotenoper
    I don't think Seafoam would cause FF issues. It is just solvents. Pull your spark plugs (or a plug, to start) and check the burn. Make sure they did not get fouled during the Seafoam. Also, did you change your oil right after seafoam? Not that that alone would cause a mileage drop, but it should be done after all the carbon is knocked loose, and to get the solvent out of the oil system.
    BTW, I have only ever done seafaom in the gas tank and some in the oil right before an oil change. I have never done the vaccuum smokestorm seafoam method.
    Also, when was he last time your throttle body was cleaned?
  3. Mar 8, 2011 at 9:40 AM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    myth busters did a think on toneau covers. the best gas mileage was open bed with the tail gate up
  4. Mar 8, 2011 at 10:00 AM
    mc4nam
    Dallas, TX
    04 PreRunner
    I did not check the spark plugs. Check the Burn? What exactly do I look for on the plugs and how do I tell if they are bad? (I am not much of a mechanic.)
    I did not have the oil changed. It has only been about 2000 miles since last one. (I guess I should have waited on seafoam.) I did seafoam smokestorm method and rest in gas tank. Not as much smoke came out as expected, but I guess that is a good thing.
    I have no idea about the throttle body cleaning? If it was part of the attached maintenance schedule below 84k, I have done it. If not, is that something I can do or about how much does it cost to get done?
  5. Mar 8, 2011 at 12:18 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I think the tonneau cover is part of the problem as it add's weight to the truck and effect the arrow dynamics ( air flow ). Big ties don't help either.
    If you are concerned about carbon build up I run a bottle of Techron through mine once a year and with quality gasoline there should be no carbon build up, the reason I ran it was I bought the truck used and was not sure about previous owners maintance.
    I would never run any additive into the intake some guys swear its the thing to do.
    If your thermostat is out of wack and not heating up to normal that could tell the computer to run the engine a little richer.
  6. Mar 8, 2011 at 12:34 PM
    scocar
    scocar hypotenoper
    Behold the goldmine of information we have assembled for you here:
    http://www.tacomaworld.com/forum/1s...y-how-thread-compiled-list-helpful-links.html
    Specifically:
    SparK Plug Replacement:
    http://www.4runners.org/writeups/sparkplugs/
    -Spark plug read-up. How to diagnose spark plug for engine troubleshooting:
    http://www.aa1car.com/library/cm1196.htm
    There is no 1st-gen-specific write-up here for the TB cleaning, but there is a 2nd gen writeup. It is recommended maint. as needed. Procedure and parts are the same, but it just looks a little different. Note that this includes cleaning the MAF sensor (mass airflow sensor), which you should also do while you have it apart.
    http://www.tacomaworld.com/forum/technical-chat/94203-how-throttle-body-cleaning-2005-v6.html
    These are both great DIY projects for you if you are comfortable with them. Cost is virtually nothing...just your time and patience.
  7. Mar 8, 2011 at 4:12 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    False. It was open bed with net tailgate
  8. Mar 8, 2011 at 4:56 PM
    johnson910413
    johnson910413 Well-Known Member
    Samuel
    South Carolina
    2011 MGM DC TRD Offroad
    10% Tint, Bull bar, Silver star ultra's, LED Dome Light, ARE Tonneao cover, Two 10" subs, 1000w amp, Exhaust tip. Weather tech mats <3
    Well i have an A.R.E. cover for my truck and i did so much mpg caculating before and after and from what i can tell the tonneau cover increased my gas mileage by 1 to 2mpgs and i did the average both times on three fill ups. i do mostly all highway driving also but i feel that it is more airo dinamick****(f' ed that word up) i get almost 19.5 from my 18 previous
  9. Mar 8, 2011 at 5:02 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Even if the tire size remains the same there could be a weight difference in them.
    Look up the specs on tire rack or some place like that to see if they are heavier.
  10. Mar 8, 2011 at 5:13 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    On my last truck 05 Dodge Ram quad cab Hemi with the 20' wheels, I averaged 15 mpg for about 2 years. Then I added an Undercover toneau and my milage dropped to 14.5. I am convinced the aerodynamics were the cause. The weight of the Undercover was 55 lbs. I cant see the weight making that big of a difference on a truck with 345 hp. Some people think I'm crazy, but I checked my milage regularly even though the truck had the cpu that calculated it. I even came to the conclusion that the cpu gave me an extra 1/2 mpg than what I figured, It consistantly gave me the extra .5 mpg over my figures. Anyway, weather it was the weight difference or the change in the aerodynamics, I saw my milage drop by a 1/2 mpg.
  11. Mar 8, 2011 at 5:16 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    Seafoam could have fouled your plugs, change em out.
  12. Mar 8, 2011 at 5:28 PM
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
    34 is kinda low psi for street use, pump it up to 40 and see what happens.. dont worry, obama said 40 is ok
  13. Mar 8, 2011 at 6:50 PM
    tacoman78
    tacoman78 Well-Known Member
    Bakersfield, CA
    02 Limited Dbl Cab Prerunner
    Deck Mod
    It could honestly be any number of things. The added weight of the toneau, most likely not. 34 is a little low for street use, and yes the messiah did say 40 was an ok PSI to use, so go for it, cause he's never wrong (ok I'll leave the politics out from here on out). Could be the weight in tires, could be the seafoam. Could be the winter weight packed on over the last couple months. Could be your plugs. Could be you got a crap batch of gas the last time you filled up. Could be you got some crappy oil for your last oil change, or your oil filter is clogged, or your fuel filter is clogged. Or it could be you just put your foot in it a little more with the new tires and Undercover.
    There are so many variables when it comes to fuel mileage that you really have to take an average account over a long period of time. One calculation does not a diagnosis make. Go to WalMart or your local parts place and get some Chevron Fuel System cleaner. Go to Chevron, put the cleaner in your tank, fill up the tank with the good stuff. Drive it through and then on your next tank do a calculation, and see what you come up with.
    Oh btw. Mythbusters is awesome. I would love to have that job, you get to blow stuff up and shoot stuff, and get paid for it. That's one heck of a job. They did a really elaborate test. Open bed with a net gets the best gas mileage. Then the toneau closed bed. Then the open bed closed gate, and the worst was the open bed open gate.
  14. Mar 8, 2011 at 7:01 PM
    kcrob1
    kcrob1 Choot It!
    Casey
    Montgomery, TX
    TRD SPORT CC/LB
    Adjustable Billies, Debadged, Painted emblem on grille Kenwood Double din, polk components, co-ax, polk 8" sub & polk amp, TSB springs, 6000K hids, FJ Wheels
    Aero Dynamic :laughing: ;)
  15. Mar 8, 2011 at 8:11 PM
    mc4nam
    Dallas, TX
    04 PreRunner
    According to Tire Rack, the Alenzas actually weigh a pound less each than my old Firestone destinations. The Tonneau only weighs 55 lbs that shouldn't cause a loss right?
    Since I didn't change the oil right after seafoam last time, should I seafoam again a few days before oil change?
    I am going to pump up the psi to 38-40 and run some chevron cleaner through my next tank and check it out. My next oil change, I will have Toyota check throttle body, fuel filter, and plugs. I will report back my findings.
    Thanks for all of the advice!
  16. Mar 8, 2011 at 8:17 PM
    jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    i dont know about everyone else but
    I saw my 2002 do better with shell than cheveron I used up more gas when I use cheveron although it ran a little smoother
  17. Mar 8, 2011 at 8:20 PM
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    Toyota will clean and replace whatever you want but your fuel filter isn't bad, they're lifetime filters and your not even at 100k. I bet it's winter gas
  18. Mar 8, 2011 at 8:20 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    stock size for the first gen TRD is 265-70-16, but you are running a 17" wheel...
    radius and circumference of the 16 is 388.62mm and 2441.7mm
    on the 17 its 401.32mm and 2521.4mm which is pretty close to a 265-75-16 in which case, i could see where the MPG would start to decline...
  19. Mar 9, 2011 at 4:34 AM
    mc4nam
    Dallas, TX
    04 PreRunner
    I understand, but I was running 265/70/17's Firestone destinations for 45k miles and was getting 18mpg. The Alenzas are the same size.
  20. Mar 9, 2011 at 6:54 AM
    HeadlampRevamp
    HeadlampRevamp Well-Known Member
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    I had a drop in mpg by 2 miles after I switched tires simply because my new tires are heavier. you could be having the same issue.
    However, this past weekend I seafoamed engine, replaced plugs, and cleaned throttle body. Its still early but it seems I like I might have gotten those 2mpgs back.
