Front bumper end removal 1st gen
Discussion in '1st Gen. Tacomas (1995-2004)' started by mattleegee, Apr 13, 2010.
  1. Apr 13, 2010 at 4:30 PM
    mattleegee
    mattleegee [OP] Well-Known Member
    Tacoma, WA
    2020 TRD PRO 6sp
    I feel some like 10mm bolts back there...
    Anyone want to shoot a quick how to with tool list?
    Its sunny i need to paint!
    Thanks in advance
  2. Apr 13, 2010 at 4:37 PM
    mattleegee
    Tacoma, WA
    2020 TRD PRO 6sp
    im talking about those little "chrome" bumper caps on the front bumper... not the entire bumper
  3. Apr 13, 2010 at 6:52 PM
    Robbsolid
    Robbsolid Zombie Killer
    ABQ, N.M.
    02 PreRunner SuperWhite DBL Cab
    Plastic X'd Flares, deck plate mod, Thrush welded muffler, graphite painted wheels, relocated turn signals, fogs in bumper
    got a picture?
  4. Apr 13, 2010 at 7:11 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I think he's referring to these....... The 98 thru 00s have these shiny front corners.
  5. Apr 13, 2010 at 7:15 PM
    Coolidge
    Coolidge Well-Known Member
    So Cal, Ca
    2003 Pre Runner
    King coilovers frt +3". Bilstein 5100 shocks rear w/AAL, K&N FIPK, Magnablow exhaust, Billet grill, clear corner lights, Sony stereo, JBL, Sub etc.
    If you want the chrome ends off, you have to remove the frt bumper assy. Its EZ
  6. Apr 13, 2010 at 7:42 PM
    mattleegee
    Tacoma, WA
    2020 TRD PRO 6sp
    dang ive been out there beating on shit for 40mins...
    i was trying to not take off the bumper... i can see the little clips but cant pop it
    i guess bumper needs to come off...
    got the grille painted black anyway... guess i will have to go rip that off tommarow
  7. Apr 13, 2010 at 7:44 PM
    mattleegee
    Tacoma, WA
    2020 TRD PRO 6sp
    thank you, found a small write up on the bumper removal
  8. Apr 13, 2010 at 9:24 PM
    ywen
    ywen Well-Known Member
    where is this write up? please provide thanks.
  9. Apr 14, 2010 at 7:58 AM
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    Post pics too!
  10. Apr 14, 2010 at 6:11 PM
    mattleegee
    Tacoma, WA
    2020 TRD PRO 6sp
  11. Apr 15, 2010 at 6:40 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    easiest way is to take the bumper as 1 piece there is 4 or 8 bolt on the bracket to the frame if i remember they are 12mm or 14mm and then it slides out. dont forget to unplug lights and maybe mark the brackets to make alignment easier on install
