Front camera frustration!! What else do I need?
Discussion in '3rd Gen. Tacomas (2016+)' started by Arkie-Marty, Mar 7, 2017.
  1. Mar 7, 2017 at 2:27 PM
    Arkie-Marty
    Arkie-Marty [OP] I'm not a real DIY expert, I just play one on TW.
    Marty
    Searcy, Arkansas
    2017 4x4 Sport DCSB, Magnetic Gray
    MODS COMPLETED IN MY TACOMA CAREER (2015 & 2017): WeatherTech Floor Mats, Chrome Nerf Bars, Under Hood LED Lights, Glove Box LED Lights, Cup Holder LED Lights, Center Console LED Lights, LED Bed Lights, Dual USB Port Console Install, 12v Power Outlet in Bed, 12v Power Outlet Under Hood, Gentex 177 Rearview Mirror w/Temp & Compass, @ImMrYo's Rearview Mirror Relocation Bracket Mod, Disable Lock/Unlock Beeps Mod, Under Door Projector/Puddle Lights, Behind Rear Seat Storage LED Lights.
    I have spent the past week Googling and reading all of the "front camera" threads I could find here on TW, but cannot find what I'm looking for. I have the camera and video switcher listed below, but neither came with directions that I can understand.
    I have a 2017 4x4 Sport, with non-JBL HU, with Navigation. It is my understanding that there is no RCA video port on the back of the HU, so I don't understand how I can use either of these items. What am I missing here?
    https://smile.amazon.com/gp/product/B00P2EN5J2/ref=oh_aui_detailpage_o01_s01?ie=UTF8&psc=1
    https://smile.amazon.com/gp/product/B00B155G5M/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
  2. Mar 7, 2017 at 8:01 PM
    lamia2super
    lamia2super Well-Known Member
    Frank
    Miami Beach, FL
    2016 Tacoma TRD Off-Road, (sold) 07 Tacoma xRunner
  3. Mar 7, 2017 at 8:17 PM
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    Curious what one would need this for anyway?
  4. Mar 7, 2017 at 8:33 PM
    Arkie-Marty
    Marty
    Searcy, Arkansas
  5. Mar 7, 2017 at 8:44 PM
    Cazzwell
    Cazzwell The Circuit Rider Signman
    2018 Silver Sky DCSB TRD Sport
    Stock.
    I'd say when pulling into a tight parking space when there's a moron parked across the line in front of you (which would leave you hanging out in the back). Could also be used to keep an eye on your winch or tow rope and such.
    I'd be more interested in trying to record the video (from both) in case of an accident.
    Arkie-Marty [OP] likes this.
  6. Mar 7, 2017 at 9:15 PM
    OdiN1701
    Colorado
    Huh...I've never needed a camera to know if the front of my vehicle will hit something. Drives my wife nuts because she thinks I'm too close a lot.
  7. Mar 7, 2017 at 9:19 PM
    sigrooms
    sigrooms Well-Known Member
    Sam
    2017 MGM Tacoma TRD Off Road 4x4 Auto DCSB w/JBL
  8. Mar 8, 2017 at 12:14 PM
    Arkie-Marty
    Marty
    Searcy, Arkansas
  9. Mar 8, 2017 at 12:26 PM
    OdiN1701
    Colorado
    The RCA plugs are just two wires - ground (outer) and signal (inner). As long as you are splicing the right wire to the right inputs, etc. it is just a video signal.
  10. Mar 8, 2017 at 1:50 PM
    lamia2super
    Frank
    Miami Beach, FL
    i would use the front for trail purposes. cant see anything when the nose is up in the air
    bsacamano likes this.
  11. Mar 8, 2017 at 1:53 PM
    OdiN1701
    Colorado
    You get used to seeing your line and knowing what to do while your nose is up. But sometimes if your nose is that much up the front camera wouldn't help much. In that case you need a spotter :)
  12. Mar 8, 2017 at 1:55 PM
    sigrooms
    Sam
    Then how about this:
    https://www.anytimebackupcamera.com/
    He did majority of the wiring work for you, you just need to install the camera and kit he provides.
  13. Mar 8, 2017 at 2:00 PM
    Hoangde
    Hoangde Well-Known Member
    @Arkie-Marty
    My rough draft drawing per your parts. (Not included switch for a,b selection and Line 2 (Reverse signal) control to toggle to Video screen at anytime).
    IMHO: Do not use E-Video Switcher, you can either connect per:
    1. This link
    2. Or use Mechanical A/V switch box to replace your E-Video Switcher
    synaps3 and Arkie-Marty [OP] like this.
  14. Mar 8, 2017 at 3:01 PM
    Hoangde
    Keep in mind that the whole idea is:
    1. Switch line 12 of 24 pin connector between Front and Rear Camera. Allow user to toggle between Rear Video or Front Video.
    2. Apply 12 vdc to Pin 2 of 28 pin connector when you are not in Reverse gear to toggle video screen ON (so you can see Front or Rear Video at anytime). Required to cutoff line 2 and install switch (read and understand before you do it).
  15. Mar 8, 2017 at 7:07 PM
    Arkie-Marty
    Marty
    Searcy, Arkansas
    @Hoangde man I sure appreciate your help! So if I understand the diagram above correctly, I won't need to use a relay or diodes....correct? Also, in reference to above diagram, I'm not understanding the yellow rear camera plug and the other yellow plug. How do these physically connect to the 24 pin connector? Do I just jab the stripped wires into the appropriate hole? Why the red X on the picture?
  16. Mar 8, 2017 at 11:08 PM
    Hoangde
    This is my way, you may find a different way to do it. Welcome to understand and do the way you like:
    1. Locate wire on pin 12 and wire on pin 24 of 24 pin connector.
    2. Cut both wires in the middle. (Red X).
    3. Now you have wire on pin 12 and wire on pin 24 at Head Unit side (the wires still attached to plastic connector). Let's call these side "AB" for now.
    4. The other end of wire on pin 12 and wire on pin 24 (the wires still attached to bundle wires). Let's call these side "CD" for now.
    5. Now connect wires (Wire 12&24) from "AB" side and wires (Wire 12&24) from "CD" side as figure 1 below
    6. Get a RCA Female connector and connect as in black circle.
    7. You just completed Front/Rear Camera Selector
    8. Connect 12 vdc to Front Camera
    9. Connect Video cable from Front Camera to RCA Female Connector (step 6).
    Next locate wire on Pin 2 of 28 Pin connector.
    1. Cut wire on Pin 2 in the middle length.
    2. Now you have wire on pin 2 at Head Unit side (the wires still attached to plastic connector). Let's call this side "E" for now.
    3. The other end of wire on pin 2 (the wires still attached to bundle wires). Let's call this side "F" for now.
    4. Connect wire on E side and wire on F side as figure below.
    5. Located +12 vdc and connect to switch as below.
    6. You just completed Anytime Camera switch
    Congratulation. You just DIY “Anytime Front/Rear Camera Mod”.
    If you understand to this point, you can substitute the two toggle switches above with OEM style as you wished.
    _______________________________________________________________
    For better power control and keep Front Camera off when not in uses then connect per my diagram (with relay) in here
  17. Mar 9, 2017 at 5:42 AM
    Arkie-Marty
    Marty
    Searcy, Arkansas
    Outstanding work @Hoangde!!! Even a senile old fart like me can follow those instructions! :thumbsup:
  18. Mar 13, 2017 at 11:21 AM
    Arkie-Marty
    Marty
    Searcy, Arkansas
    Just to be sure, is this an "on-off-on" DPDT or "on-on-on"?
    UPDATE: The correct switch is a DPDT two position On/On switch. A DPDT on-off-on will also work.
  19. Mar 13, 2017 at 2:08 PM
    Hoangde
    S1= DPDT, on/on
    S2 = SPDT, on/on
