Front camera sr5
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Heath101, Sep 1, 2019.
  1. Sep 1, 2019 at 11:58 AM
    Heath101
    Heath101 [OP] Well-Known Member
    anyone installed a front facing camera on their sr or sr5? I see a lot of pro installs but would love to get some ideas of where to mount on the grille of an sr5 with tss
    Tullie D likes this.
  2. Sep 1, 2019 at 12:10 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    What year?
  3. Sep 1, 2019 at 12:46 PM
    Heath101
  4. Sep 1, 2019 at 12:48 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Some use the license plate, some offset to the side.
  5. Sep 1, 2019 at 2:05 PM
    Heath101
    Looking for pics for some ideas
  6. Sep 2, 2019 at 7:44 PM
    Heath101
    Looks like I may have to create a solution for others...
  7. Sep 5, 2019 at 1:50 PM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    Do it ! :thumbsup:
    BTW, welcome to the forum from Eastern North Carolina.
  8. Sep 5, 2019 at 2:06 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    I don't have a picture of the front mount location at the moment.
    I mounted the camera centered in the grill underneath an area that had been reinforced for the sensor. For this to work I had to shorten the threaded camera attach point as pictured.
    Be sure to mock up your install and take a look at the image displayed on screen before going through the trouble of routing everything. My first attempt was with a camera that couldn't be adjusted without a mirrored image and I was forced to switch it out with a different brand camera.
  9. Sep 5, 2019 at 2:28 PM
    Tullie D
    Tullie
    Wilson, NC
    Welcome to the forum from Eastern North Carolina.
    BTW, Nice work with the saw. :thumbsup:
    What camera did you end up using?
  10. Sep 5, 2019 at 3:04 PM
    Gen3TacomaOBX
    S
    Thanks! I play down on the NC coast whenever I get a chance but live in Va. Hoping the area doesn't get too flooded/battered this hurricane season.
    This is the one that worked for me: https://www.amazon.com/NATIKA-Backup-Camera-Waterproof-Reverse/dp/B07H852D49
    Tullie D[QUOTED] likes this.
  11. Sep 5, 2019 at 3:20 PM
    Tullie D
    Tullie
    Wilson, NC
    Well, we've been pounded by Tornados this afternoon, and the Hurricane itself is still a long ways off.
    I may order one of those cameras. Looking forward to seeing how you mounted yours. :thumbsup:
  12. Sep 5, 2019 at 3:25 PM
    no vtec 4me
    no vtec 4me Well-Known Member
    Kevin
    West Chester, Pa
    2017 Tacoma TRD Sport
    The real question is, are you able to make these function with the stock head unit?
  13. Sep 5, 2019 at 4:54 PM
    Tullie D
    Tullie
    Wilson, NC
    That camera has been used with the stock head unit. You do have to have an interface to make it work though.
    Here's one example. There are others, maybe better.
    https://www.tacomaworld.com/threads/car-solutions-reverse-anytime-front-camera-install.604733/
    As for me, I'm thinking about NOT using the stock head unit, but instead using a small dedicated monitor, similar to this:
    https://www.amazon.com/Monitor-Parking-Optional-Bracket-Adhesive/dp/B019GQLNJU
    I'm still undecided. I want to do it without butchering up the OE wiring.
  14. Sep 5, 2019 at 5:08 PM
    ICU1
    ICU1 Well-Known Member
    Car Solutions is plug in play. No added switches needed. Amazon has them
  15. Sep 5, 2019 at 5:18 PM
    Bach88
    Bach88 Well-Known Member
    Florida
    2016 Tacoma OR DC
    You can make you own harness and not butcher anything.
    Metra Electronics AX-TOYCAM3... https://www.amazon.com/dp/B01E4B6UQS?ref=ppx_pop_mob_ap_share
    28-pin Head Unit Wiring Harness... https://www.amazon.com/dp/B01BSE5X9Y?ref=ppx_pop_mob_ap_share
    I only did the front anytime camera so it was pretty simple to wire up.
  16. Sep 6, 2019 at 6:30 AM
    Tullie D
    Tullie
    Wilson, NC
    Maybe "butcher" was not the best choice of words. :eek:
    What I want to have is a front camera without "involving" ANY changes to the OE wiring.
    My intent is to have a isolated (except for getting power) camera and monitor that can not affect, or be affected by, any of the OE equipment.
    I can do that with a small dedicated monitor. :cool:
    Anyway, I've ordered a camera and monitor. I'll let y'all know how it turns out. :)
  17. Sep 6, 2019 at 8:13 AM
    Gen3TacomaOBX
    S
    I used https://www.anytimebackupcamera.com/ with front camera option. I use it all the time parking in narrow parking spaces or cresting a steep driveway/ramp at slow speeds.
    Fortunately (and unplanned) the wheelbase guidelines rendered on-screen match up with the outer edges of my tires.
    Tocamo and Tullie D like this.
  18. Sep 6, 2019 at 8:20 AM
    Tullie D
    Tullie
    Wilson, NC
    The fisheye effect of the camera sure changes things, huh? o_O
    Any chance of you posting a front view of the installed camera?
  19. Sep 6, 2019 at 8:24 AM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    I mounted my front camera on my sport with the sr/5 grill. I’ll have to find or take pictures later.
  20. Sep 6, 2019 at 8:26 AM
    Bach88
    Florida
    2016 Tacoma OR DC
    Could you post some pics of where you mounted your camera? I used a cheap $10 emblem mounted camera and you can’t see any of the bumper. Thinking of replacing it with something better quality and mount it where I can see some bumper.
