Front Diff and Transfer Case Oil Change Howto
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jspadaro, Mar 24, 2011.
  1. Dec 3, 2015 at 9:03 PM
    #721
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    They seem to over tighten everything at the factory, even getting the filter off for the first oil change was a nightmare. The good news is that I now have every oil filter wrench known to man.
  2. Dec 4, 2015 at 2:06 AM
    #722
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    Just out of curiosity was the Jack positioned on the drivers side or passenger side of the truck? I can't imagine how you could get the proper angle to actually turn the hex.
  3. Dec 4, 2015 at 4:29 AM
    #723
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    Granted my truck only had 22,000 miles when i did my fluids, but everything seemed torqued accordingly. Only took a 14" breaker bar at moderate force to loosen every one.
  4. Dec 5, 2015 at 12:08 PM
    #724
    Backt
    Oregon
    Please listen the last thing you want to do when working on your truck is to cause more problems or hurt yourself. I bought my Tacoma in February with 38,000 miles. Before that I paid for all my maiintenace and did not do very much preventative maintenance. When I bought the Tacoma I found TW and saw all the DIY articles. Since February I have changed the diffs and transfer case, oil change, cleaned mas and throttle body, changed plugs, upgraded headlights, and practiced getting the truck in temp check mode to perform a AT flush soon.
    The one thing in common with all these jobs is the preparation I do beforehand. I read the threads once from beginning to the end. Often times someone will post a trick somewhere in the thread that may help. I then look at it again and plan the job and acquire the proper tools. If it's posted to use a 6 point socket instead of a 12 I go get one, torque wrench, breaker bars, etc. Most often a job takes me longer than it should. That's because I take my time and if I run into a problem I stop and think about it, or post a question, or search.
    Good luck
    Crom and Flhighby like this.
  5. Dec 5, 2015 at 1:28 PM
    #725
    Flhighby
    Flhighby Well-Known Member
    Remynator
    Montreal surroundings
    2014 TRD Sport DCLB
    Skid plate (front section) OR FAB, Leer shell 122, CB Cobra WX ST II, Little Wil Antena, BF MudTire 32's, rear diff breather relocation, power lock tailgate, cab outlet/400W park and driving, fog lights on any time, rubber floor, blacked emblems, door ding
    Precisely that !
    Couldn't of said better. When the time comes to do the job, I almost know the tread by heart. It's the original post, +, all the comments that helps. I ran in a pump situation with the rear diff. I had read enough of the tread to turn myself around and find a quick solution. And have the tread readily one my phone close by while working !
    I'm a handy person, but it's not my trade, and this keeps me from doing it wrong the first time and then learn from my mistakes. It's a good thing to learn by mistrial, but if I can do it right, just once, I'm a happy camper !
  6. Dec 5, 2015 at 2:04 PM
    #726
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    That's exactly what I did. All I had to buy was a 24mm socket and a cheap pump plus fluids and crush washers and I was set. I must have read this thread four or five times and then found some DIY videos on YouTube. When I got under my truck I knew exactly where everything was and what to expect. I couldn't believe how easy it was due to the right preparation. And, as I said before, if I can do it anyone can.
    Stryker420 and Crom like this.
  7. Dec 7, 2015 at 6:28 PM
    #727
    Pigpen
    Dan
    Northwest Montana
    It's a Christmas miracle!!! God bless us one and all!
    Welcome back Arin, we needed some quality entertainment.
    DoorDing likes this.
  8. Dec 11, 2015 at 7:12 AM
    #728
    WebberLander
    WebberLander Well-Known Member
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    Changing this fluid (and the rear diff) for the second time this weekend thanks to this DIY write up. Can't wait to wrench on my truck :)
  9. Dec 17, 2015 at 9:10 AM
    #729
    timawa15
    timawa15 Member
    2006 Silver Tacoma 4X4
    I have '06 Tacoma Double Cab 4X4 and having trouble with the low clearance at front differential. Is jack stand advisable or ramp is better to get access to the front diff?
  10. Dec 17, 2015 at 10:06 AM
    #730
    ejl923
    Eric
    Western Mass
    Either one, just make sure its level when filling. I was able to drain while it was on wheels, but needed to jack up the front when torquing the drain and fill bolts. After tightening them, i lowered back to wheels to fill. I had 3/8 ID hose which i ran down the engine bay to fill, no pump needed.
  11. Dec 23, 2015 at 5:10 AM
    #731
    Munson01
    Munson01 Well-Known Member
    Cypress, TX
    2014 Silver Tacoma 4x4
    None yet
    Just did this on Monday. Both front and rear where a little milky, the TC was fine, 35K miles. I was surprised since I've never really had it in any deep water other than rain puddles on the road. Pretty straight forward and I was able to do it with wheels on. My driveway slopes down, as most do, so I just raised the rear by driving the back end up on 2x10's to level it out. The only hard part was trying to get a torque wrench on the front diff. It could be done with a small torque wrench or raising the vehicle.
  12. Dec 28, 2015 at 8:02 AM
    #732
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    @njjoe732
  13. Dec 30, 2015 at 3:58 PM
    #733
    Nichostiles
    Nichostiles Well-Known Member
    Nick
    USA
    08 Taco Access Cab 4x4
    Can anybody recommend a good place to get a replacement fill plug for front diff (the 10mm Hex) ...it's not stripped, just a little warn so I figured I'll replace it when I have it off.
    I'm pretty far from a Toyota dealer. Was hoping to find it online somewhere. Amazon?
    Thanks
  14. Dec 31, 2015 at 1:25 AM
    #734
    Backt
    Oregon
  15. Jan 4, 2016 at 3:48 AM
    #735
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I would avoid using impacts on the plugs unless you want to replace the plug after removal...the steel is awfully soft.
  16. Jan 10, 2016 at 4:17 PM
    #736
    pidgeball
    pidgeball Active Member
    Houston Texas
    2010 TRD Dbl Cb
    HomerTaco insp.UG Satoshi, LG satoshi, bull bar, XD spies with BFG ATs and 1.25" spidertraxx, OMD insp. frankenstein rear leafs, Billy 5100s, Nerf bars. Oh, and a kick ass 8ball shifter knob!
    20160110_142401.jpg Great write up! Problems with th20160110_125737.jpg 20160110_145549.jpg e front diff drain plug. Always had the stealership do the service before I hooked up with TW. There's NO WAY that plug's ever been out before. Cock munchers are about to get a rash o' shit when I take it in this week...
  17. Jan 10, 2016 at 4:19 PM
    #737
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Holyshit Batman!!
  18. Jan 10, 2016 at 7:47 PM
    #738
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Dude - was it your breaker bar that broke AND the hex socket? Were you able to pull out the remnants of the hex socket from the hex bolt?
  19. Jan 10, 2016 at 8:37 PM
    #739
    CO Ryan
    CO Ryan Well-Known Member
    Colorado
    13 TRD Offroad
    stuff
    Mine was pretty stuck. I used one of these
    And one of these
    Edit: I still can't post pictures. It's an Allen wrench and a rubber mallet.
  20. Jan 10, 2016 at 8:40 PM
    #740
    pidgeball
    Houston Texas
    2010 TRD Dbl Cb
    Hex stripped out eventually. I suck with intranets, so the pics aren't in order, I don't think.
    The hex fit snug, tapped it in and started with the 1/2" drive with the 3/8" adapter (assuming I'd be needing it to torque the DP back in). Realized that it was tighter than I'd thought and went to the 3/8" drive. Realized I'd need a breaker with a cheater and put the propane on it (don't know why I didn't bring the mini kit over and put more heat on it, I'm just lazy). With the breaker and a cheater (which works much better in tight spots as you can adjust your length) the hex stripped out. Got passed, used one of these posts suggestions and dremeled the hex into a 3/8" square. Breaker fit perfectly. With the cheater on the breaker I was lifting the truck (not literally, but I'm getting red faced and looking at the suspension lifting), so I'm kind of like "Are you shitting me?" So, in a fit of anger I decided I'd put the jack under the breaker and make sure I wasn't imagining things. The pic with the jack was supposed to demonstrate the "lifting" of the truck. In hindsight it probably doesn't make sense to anyone but me. Lifted the driver side for more leverage, set the breaker almost straight down with the cheater right at the floor, held the bull bar and used my leg, pushing and pulling at the same time. Square drive on the 3/8" breaker snapped. Long story, but ended up using a 24oz. Ball peen and a Ken plug tool (tapered squares) to pound the fucker into submission.
    Stryker420 likes this.
