Front Diff and Transfer Case Oil Change Howto
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jspadaro, Mar 24, 2011.
  1. Aug 6, 2016 at 6:16 PM
    #841
    Chip4x4
    Chip4x4 New Member
    Nathan
    Redding, ca
    2007 impulse red Toyota Tacoma 4x4
    Do u need to add lsd additive to the front diff? Thanks in advance
  2. Aug 6, 2016 at 8:15 PM
    #842
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    No.
  3. Aug 6, 2016 at 8:39 PM
    #843
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    you should have ATRAC, which is way better than LSD for offroad... ATRAC uses your brakes independently to slow any wheel that's spinning excessively, allowing the other wheels to grip.
  4. Aug 9, 2016 at 12:17 PM
    #844
    utrichatx
    utrichatx Member
    Utrich
    Tacoma2001silver
    Does anyone know if the rear differential drain plug needs a new washer for a 2014 Tacoma V-6? I had to replace the washer on my 2001 Tacoma V-6, but couldnt find anything about a washer replacement.
    Thanks!
  5. Aug 9, 2016 at 12:21 PM
    #845
    Redsnapper
    Redsnapper Member
    Travis
    2013 Tacoma TRD Sport
    So I did the change over the weekend using Royal Purple 75w90:
    Rear diff was a bit milky...easy to change went smoothly.
    Transfer case oil was clean and the change was painless.
    Front diff I could not budge the drain plug. Way over-torqued from factory and I've ordered a replacement plug and now I'm trying to decide if I'll try again or just take it someplace with a lift and let them do it.
  6. Aug 9, 2016 at 12:22 PM
    #846
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    just about any drain plug has a crush washer.. most of these are copper, and are intended to be single use, but I've read you can anneal them and reuse them in a pinch.
  7. Aug 9, 2016 at 3:15 PM
    #847
    Fox2011PM
    Fox2011PM "The Mountains are calling"
    '13 DCSB 4X4 TRD OR
    ADS 2.5" CO's w/adj, ADS 2.5" Rears w/ piggybacks, Firestone air bags and 1.5" AAL, SCS SR8s, Tom Woods custom one piece drive shaft....more to come
    Look at post #868, I listed what style of washer and its part # for which diff and transfer case and their torque specs. I have a 2013, I'm not 100% sure on your 2014, but I can't imagine they would be different. Unfortunately 3 different types are used. 2 are aluminum (transfer case) 2 are crush on the rear diff, and the front diff fill plug takes a crush style and the front diff drain plug takes a copper washer. Amazon has the cheapest prices I could find and if I'm not mistaken I think they have a "bundle" package with all 3 types. I did both diffs and transfer case and replaced all washers, just for my piece of mind. Probably not a big deal for the aluminum or the copper washers, as they are just flat, but the crush are just that, they "crush" down when you torque them correctly creating a type of seal so you don't develop a leak. Hope this helps
    Jake.A, utrichatx[QUOTED] and Norton like this.
  8. Aug 10, 2016 at 10:11 AM
    #848
    Qwntm
    Qwntm Well-Known Member
    Edward
    Boise, ID
    2016 Inferno TRD Off Road DCSB
    None...yet!
    The 2016 manual says 75w85 GL-5 for the diffs and 75w for the T-case. I'm guessing any 75w90 GL-5 is ok in the diffs (like Royal Purple, Mobil 1) and what about the T-CASE? Are you guys running the 75w90 oil in the T-cases as well? Or was there a specification change in 2016?
    I did notice the manual wasn't too specific about grade or qualifications of the 75w oil in the T-case... i.e no GL-5 etc. I'm guessing the T-case is not that picky. :)
  9. Aug 12, 2016 at 3:11 PM
    #849
    Redsnapper
    Redsnapper Member
    Travis
    I finally got my front diff drain plug out and the oil changed. New plug and all is good. The dealer declined to pay for the new plug/gasket even though it was way over torqued from factory.
  10. Aug 14, 2016 at 3:05 PM
    #850
    Treaddirt
    Treaddirt Active Member
    Lake Stevens, WA
    '23 White TRD OR access cab
    Just finished my second front/rear differential and transfer case fluid change on my 2012 - 94,000 miles. The rear oil was dark and the others slightly dark. Used Mobel 1 for both changes. This time I purchased a drill powered fluid pump off of Amazon and the thing is awesome (hated the little plastic bottle top hand pumps). Check for this pump "master ratchet fluid pump" made by PBT, comes with hoses and case. You need to buy the cordless drill sleeve/holder as well. This pump works great and makes the job quick and who doesn't like to buy a new tool.
  11. Aug 17, 2016 at 7:40 PM
    #851
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    ^^That pump looks pretty damn cool. However, for as often as we do this... I'll stick with the $10 pain in the ass pump.
    TACO TX and Norton like this.
  12. Aug 24, 2016 at 3:42 PM
    #852
    dawgn86
    dawgn86 Well-Known Member
    2013 Toyota Tacoma
    I plan on doing my 2013 4 cyl Tacoma Prerunner this weekend...I think the manual calls for 75w-85w gear oil, but it seems hard to find. Is 75w-90w ok to use?
  13. Aug 24, 2016 at 3:51 PM
    #853
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    I used 75w-90 Mobil 1 in my rear diff, Lucas 75w-90 in my transfer case, and Royal Purple 75w-90 in my front diff. Only used 3 different types because that's all they had. I think 75w-90 is fine to use if you can't find the 75w-85 the manual calls for. I'm no expert or certified mechanic though, might wanna get more opinions
  14. Aug 24, 2016 at 3:55 PM
    #854
    dawgn86
    2013 Toyota Tacoma
  15. Aug 24, 2016 at 4:48 PM
    #855
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    the differential oil should be GL-5 rated 75W90. LiquiMoly or Redline would be my choices.
  16. Aug 24, 2016 at 7:15 PM
    #856
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Not from everything I have read. My TRD OR 4x4 w/ ATRAC and rear locking diff doesn't require any additive. Check with your dealer (not my first suggestion) or check the manual. Also BamaToy is a great source of knowledge and could answer more definitively. I believe with the newer models no additives or special blends are required, but again, that's just what I have read, I advise doing some research on your model, as I have been wrong (ask my wife) before
  17. Aug 26, 2016 at 7:15 PM
    #857
    Teuton
    Teuton Well-Known Member
    2011 Reg Cab 4x4, 2021 TRD sport, 2024 TRD Sport
    Just did both differentials and transfer case on my 4x4 2.7L. I bought the car with 68k miles and its currently at 73k miles. No idea if previous owner ever changed the oil so I decided to flush them for peace of mind.
    I went out and bought 6 replacement washers from toyota, 6 qts of Mobil 1 75w90 oil, a cheap pump from AutoZone, and a breaker bar in case the bolts were tricky. Whole job took me about 3 hours taking my time. I had no problem loosening the bolts with my torque wrench. Rear differential and transfer case oil looked totally fine. The front was very dark with some sludge.
    If your hesitant about doing this, don't be. Its a super easy job that anyone who can loosen/tighten bolts can perform. I highly advise getting a cheap pump for the oil. I attempted to use a funnel and made a huge mess.
    ruffridha9 likes this.
  18. Aug 26, 2016 at 7:26 PM
    #858
    dawgn86
    2013 Toyota Tacoma
    Did the rest diff this evening. Easy job
  19. Sep 6, 2016 at 3:08 PM
    #859
    uncrx2003
    uncrx2003 Well-Known Member
    Minh
    NC
    '13 4x4 TRD Offroad
    Taking the rear nut wasn't easy but got it done. It didn't look bad at all. No metal shavings. The fluid from the transfer case looks brand new. I decided to hold off the front since I didn't want to deal with taking off the skid plate. The guy at Toyota said I don't need to do it this early since I don't 4 wheel that often. After seeing the fluid from the transfer case, that's the only thing holding me back from doing the front.
  20. Sep 6, 2016 at 3:14 PM
    #860
    Teuton
    When I did mine the font fluid was by far the dirtiest with the most sludge.
