Front end growl after 5100s goes away over bumps, will dif drop help?
Discussion in 'Suspension' started by nvtaco, Jun 7, 2012.
  1. Jun 7, 2012 at 11:39 PM
    nvtaco
    nvtaco [OP] Well-Known Member
    Vancouver, BC
    07 Double Cap TRD Sport
    Vent visors, backup lights, the loadhandler!
    Installed 5100s front at .85 orig
    coils, got that growling noise others have gotten for the front end which goes away in 4wd, BUT it also goes silent over those large speed bumps when the truck front end has the weight off it for a couple seconds. The sound then returns when the truck is flat on level ground with normal front end weight.
    My question is will the dif drop help remove that growl grind sound based on my comments above? Thanks
  2. Jun 7, 2012 at 11:58 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB MGM
    Afe CAI (removed back to stock intake), TSB 4 leaf pack with Firestone Air Bags and Daystar cradels, 3rd OEM HU, Wranger All Terrain Adventure with Kevlar 265/75/16, Cali raised LED pods, Wheeler Off Road Front Bump Stops.
    At 0.85, you shouldn't really haven't any issues with your CV joints binding or grinding. I haven't heard of this issue before.
    I would double check that the sway bar isn't contacting anything, and that your coils and struts are correctly installed. The spring seat is easy to install upside down...
  3. Jun 8, 2012 at 12:11 AM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    http://www.tacomaworld.com/forum/2n...nt-differential-bearing-vibration-thread.html
    you've read this thread? ECGS replacement bushing might be the fix for you
    Chase at East Coast Gear Supply (ECGS) has presented promising news about a possible fix for this vibration issue using a bushing that replaces the needle bearing in the front diff. Skip to page 4 of this thread and read on. Check out East Coast Gear Supply on Facebook for updates on the new bushing fix!!
  4. Jun 8, 2012 at 10:27 AM
    nvtaco
    Vancouver, BC
    Checked both the sway bar and the coils and struts are inst. right.
    This growling noise can be felt through the pedal. The sound is kind of like when your tire treads get really low, but only louder. My tires are 70% remaining.
    Could alignment issues be making the sound? My #'s were not very good, after they tried a re-alignment after the 1st. #'s weren't good.
  5. Jun 8, 2012 at 10:28 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+295k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED), 2006 F350 King Ranch 6.0L
    Yes, I'd get a good alignment. What were your numbers?
  6. Jun 8, 2012 at 10:29 AM
    nvtaco
    Vancouver, BC
    Thanks I have read through there. Didn't want to the the effort yet of doing the bearing replacement. I thought since the sound went away when the weight was off of the front of the truck when going over the speed hump (the wider type than speed bump) and then came back once over the hump It would be less of a fix.
  7. Jun 8, 2012 at 10:48 AM
    Large
    Large Red
    Get an alignment.
  8. Jun 8, 2012 at 2:08 PM
    Taqoma
    Brennan
    Los Angeles
    2011 TRD Off-Road
    did u see the videos? I'm not a tech or anything but the amount of "play" that's in the cv shaft might cause the growl to temporarily go away when u go over the bump cause its lining back up so to speak.... :notsure:
    http://youtu.be/x4qw5GtfoRc
  9. Jun 8, 2012 at 2:39 PM
    nvtaco
    Vancouver, BC
    Here's the 2nd alingment, which is current. The first made the driving squirrely. I have to say at with these #'s the truck still wanders and follows the ruts in the roads, just not jumpy. These are the #'s at which I am getting the growling.
  10. Jun 8, 2012 at 3:00 PM
    nvtaco
    Vancouver, BC
    Just watched 3 of them. Thank you. I think you're right about the "play" issue after watching the dial runout indicator. Before I do that fix though, I think I would try the dif drop...don't know if that will work, less invasive to start though.
  11. Jun 8, 2012 at 3:07 PM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    Wheel bearing?
  12. Jun 8, 2012 at 3:12 PM
    nvtaco
    Vancouver, BC
    Was cruising through other posts and someone who had a similar problem was asked if the cv joints/axle were pulled on or moved around. I have to admit, when I took the old struts out and I put the new strut assemblys in there the Drivers Side CV axle felt as though I had "pulled it out" or "away" from the differential. All I did was move the axle around a little and then shove it back towards the diff and everything was fine.
    Is there a certain way to check if the cv joint is positioned correctly?
    This could be where the noise is from?
  13. Jun 8, 2012 at 3:13 PM
    nvtaco
    Vancouver, BC
    I dont quite know, the sound goes away when I switch over to 4x4 instantly. After reading the bearing sound thread I ruled out the wheel bearing(s).
  14. Nov 19, 2012 at 5:52 AM
    fdb03taco
    fdb03taco Well-Known Member
    Danny
    SOMD!
    2014 Tundra SR5 CrewMax 5.7 4x4
    Long time lurker here.
    I've got this same exact problem with my 03 TRD 4wd since installing Bilstein 5100 series shock on the tallest setting. The rear is stock height and the front is ~2" taller than stock. The rotational hum goes away when 4wd is engaged.
    I was pretty convinced that it was something with the diff, but that post has convinced me to check my front axles. I will check them this week/weekend.
    Also, I've got the diff drop installed too. That did not help the issue.
  15. Nov 19, 2012 at 6:14 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Diff drop on 2nd gen will do more harm then help.
  16. Nov 19, 2012 at 10:09 AM
    NiceTaco
    NiceTaco Canadian Redneck
    Ontario, Canada
    2012 TRD Sport
    Aero Turbine 2525, Front bilstein 5100's @1.75, rear 5100's, 1" Toytec rear block, Devil Horns, BGF AT's, 18" Moto Metal 962's
    I have to hear the reasoning behind this comment? Is it not good to drop the diff and get the angles back to stockish... I understand for wheeling it may not be good but for the sale of conversation street truck only.. how come?
  17. Nov 19, 2012 at 10:23 AM
    sirsaechao
    Tim
    Commifornia
  18. Nov 19, 2012 at 10:30 AM
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
