Front or Back Seat Risers?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by surfdoc81, Jan 26, 2021.
  1. Jan 26, 2021 at 8:15 AM
    surfdoc81
    surfdoc81 [OP] Active Member
    Joe
    2020 White Tacom TRD OR
    I am considering adding seat risers to the passenger seat in my Taco but I see that there are risers available for the front and back. I don't really want to buy both to figure out which one works better. My wife complains of leg and back pain on long road trips. What have you guys found that works best?
  2. Jan 26, 2021 at 8:31 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    All depends on her height, leg length. Front risers will give better leg support for longer legs. I have front risers, and they made world of difference. 6'-1" 33" inseam.
    shakerhood likes this.
  3. Jan 26, 2021 at 8:39 AM
    surfdoc81
    Joe
    Just thought about it for a bit, and I think if I put a leveler on the seat in her car (which is adjusted for her), then repeat in my passenger seat, I should be able to see which way I need to go. Wouldn't be an exact science, as there are some variables such as floor to seat height, etc. but should at least get me moving in the right direction.
  4. Jan 26, 2021 at 9:09 AM
    Westsideott
    Westsideott Well-Known Member
    Ottawa, ON
    2020 DCSB OR
    I installed front risers for leg support. Find they improve comfort a lot.
    edw_oh and shakerhood like this.
  5. Jan 26, 2021 at 9:19 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Why not grab a couple of bath towels, fold them up, place them on the seat bottom in various locations (e.g. front, under her legs or rear under her butt) and then judge whether it's the front or rear of the seat that needs to be raised. Proceed accordingly.
    shakerhood and tractorfarmer123 like this.
  6. Jan 26, 2021 at 9:57 AM
    79CHKCHK
    79CHKCHK Padawan of Rock Lobster
    SoCal no mo
    2018 Super White TRD Pro AT
    I tried rear risers before fronts were available...made my leg pain worse on drives over 30-45 mins. Removed those and added front risers, pain gone. Even on long multi-day road trips or driving upwards of 9 hours in a day. The front risers provide support under my thighs. I'm 5'10" with a 31" inseam.
    What I purchased: https://www.tacomaworld.com/threads...s-lifts-the-front-of-the-seat-3rd-gen.607482/
    My review after purchase and use: https://www.tacomaworld.com/threads...the-seat-3rd-gen.607482/page-17#post-21624698
    And I've done a lot more driving since...only time I have leg pain is if I forget to take my wallet out of my back pocket. But that's an easy solution.
  7. Feb 1, 2021 at 5:16 PM
    robert34
    robert34 Member
    robert
    Orlando, FL
    2017 Toyota Tacoma TRD Sport
    Sorry to hijack thread here a bit OP, but if anyone else could help.
    I'm not a tall guy at all (5'6") and I see a lot of taller people using the front risers for leg support. I get that "seat risers" sounds very obvious, but did you feel the front risers really helped give you lift as well? (although that doesn't seem to be the tall individuals concern here)
  8. Feb 1, 2021 at 5:28 PM
    Westsideott
    Ottawa, ON
    2020 DCSB OR
    I'm 6'1 and noticed no lift with the front risers (other than thigh support). I did however drop my seat height slightly to fit under the wheel better but don't think I experienced higher sightlines prior to seat height adjustment.
  9. Feb 1, 2021 at 6:36 PM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    I couldn’t drive longer than an 1hr with my back hurting and back of legs, constantly shifting around trying to get comfortable. It felt like I was sitting with the Cali lean so I raised the rear (1”) and immediately felt a difference. I was skeptical at first but I’m glad I tried it. 5’10”
  10. Feb 1, 2021 at 8:46 PM
    BroncoAZ
    BroncoAZ Well-Known Member
    Cape Cod, MA
    2021 WhiteTacoma TRD Offroad
    Front made all the difference for me, especially on the flat passenger seat. I did add 3/4” under the rear drivers side and 1/4” under the rear passenger.
    surfdoc81[OP] and shakerhood like this.
  11. Feb 2, 2021 at 1:49 PM
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    6 foot here, 34 in inseam. My seat felt like I was sliding forward out of it. Did the front risers, thumbs up, all good now.
  12. Feb 2, 2021 at 2:48 PM
    baldbeardedtaco
    FL
    Just to expand on this- it also depends on how your truck sits. Example, I was sagging in the rear with a cap (roughly 180 lbs) nothing else but sagging nonetheless on stock. Now when I say sag I lost my factory rake so it was probably more level (I personally don’t like level because on the occasions I tow, or pick up a heavy load I’m really squatting). So my rear sag/level truck made me feel as if I was in a Cali lean in the seat so the 1” rear fixed my uncomfortableness dramatically. Past weekend I installed 3leaf aal and obviously raised the rear (maybe a tad above stock) so I can feel that in the seat (maybe almost too much), I’ll have to give it awhile and a long drive if I need to make an adjustment.
    surfdoc81[OP] and 79CHKCHK like this.
  13. Mar 30, 2021 at 7:50 PM
    Joe671
    Joe671 YouTube Mechanic
    Joe
    Washington State
    2019 Tacoma TRD Off Road
    Little late to reply but in case you are still trying to find some info. I'm 5' 6" and felt almost the opposite of what these tall fellas feel. The rear part of the seat felt just a little bit too low so I added a 1/4" spacer to the rear bolts. Couldn't believe it but thats all I needed to give me a little bit of a lift. I've only driven it a couple of miles but the seat position feels great. We'll see how I feel in a week or so lol.
  14. Mar 30, 2021 at 8:26 PM
    pochoboy
    pochoboy Well-Known Member
    trying to fit an amplifier under front passenger seat, I installed 1-1/2 risers on the back and it made the seat lean forward quite a bit making it uncomfortable physically and in mind. It seems like the front risers are kinda standard at 1-1/4", but I know it'll kinda even out the front to back angle and give us more of a view over the hood skewp.
