front shock replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by shift96, May 15, 2010.
  1. May 15, 2010 at 9:44 PM
    shift96
    shift96 [OP] Well-Known Member
    So I have a hydraulic press in my garage and am wondering if I can use it to change my front shocks on my 01 Tacoma. Anyone here ever use a press to do this?
  2. May 15, 2010 at 9:46 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    What sort of hydraulic press? You'll definitely need a pair of spring compressors to remove the shocks from the coils springs though.
  3. May 15, 2010 at 9:55 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    I bet you could fab up a rig to hold it and use the press.
    http://www.tacomaworld.com/forum/suspension/92519-ome-install-starts-tomorrow.html
    Just make sure you can control the speed when you release the pressure on the hydraulic jack.
    Here is a very simple rig I put together and used it to change out a good number of shocks. It is in the pics in the link above scroll down the thread a bit to see them.
  4. May 15, 2010 at 10:50 PM
    shift96
    Cool thankyou. I can control the speed on my press. I can get it to release very slowly
  5. May 15, 2010 at 10:55 PM
    shift96
    Looking at your pics I actually like that setup you have better. I may try that. I have a setup similiar to that from when I changed out shock springs in my old Harley Softail.
  6. May 16, 2010 at 1:48 PM
    OH-MAN
    Sunny Az.
    10 4X4 O.R. White
    The allthread rod is expendable as it gets messed up after a few runs throuth the riser clamp.
    I am still using the same rod but I had to use the vise grips to hold it this time.
    The riser clamp is used in piping systems when passing pipe through floors in multi story applications.
    That one is a 2" IPS or 2 1/2" O.D. pipe clamp.
    I drilled the extra set of holes in the wings to keep the 5/8" allthread in place.
    Add a couple 90 degree unistrut brackets and a 1/2" bolt and thats it.
  7. May 18, 2010 at 8:42 AM
    shift96
    where did you get the pipe clamps? Home Depot?
  8. May 18, 2010 at 2:33 PM
    OH-MAN
    Sunny Az.
    10 4X4 O.R. White
    I don't think home depot carries them
    I would look for a plumbing supply shop.
    They are more of a commercial kind of item.
