Front Wheel bearing replacement questions.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Eesh, Jun 21, 2012.
  1. Jun 21, 2012 at 4:39 PM
    Eesh
    Eesh [OP] Well-Known Member
    Regina, Sask., Canada
    trd Sport
    Hey guys. My passenger side front wheel bearing is toast.
    1) Do I have to get the whole hub assembly? Or can I just get a wheelbearing?
    2) What are the part numbers of the parts that I would need??
    3) Where is the cheapest place to get them?
  2. Jun 21, 2012 at 4:42 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    You can just get bearings. The auto parts stores will have them. I suggest you search for a how to on replacing them. There are many steps to follow.
  3. Jun 21, 2012 at 4:51 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    I'd get the whole thing because trying to press the bearing into a new hub is a PITA that you'll have to take to the shop to do anyway.
    If you're interested, I have a brand new bearing and hub I can sell you
  4. Jun 21, 2012 at 4:58 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    If you get just the bearing--I recommend TIMKIN==From what I researched here at (TCW) they are best.
    1st gen's are a pain in the ass--especially BALL JOINT removal.
    If you have the cash--let someone do it for you.
  5. Jun 21, 2012 at 8:43 PM
    Eesh
    trd Sport
    What do you mean by TIMKIN? Is that a brand? If so is it better than the Toyota OEM one? And how much does it cost?
    does anyone have the part #'s for the Timkin or the OEM front passenger wheel bearing?? not the hub
  6. Jun 21, 2012 at 9:04 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Find the wheel bearing thread, it has all the info you need.
    Timkin is a brand of bearing. Koyo is a great brand as well. As are SKF bearings.
  7. Jun 21, 2012 at 10:47 PM
    koco
    Bay Area Ca.
    '01 Taco
    Timken, Nachi, NSK... all good
  8. Jun 22, 2012 at 11:20 PM
    Eesh
    trd Sport
    I can't find the wheel bearing thread you guys are talking about.
    Can someone give me the Timken wheel bearing part # as well as let me know what kind of grease and seals I'll need.
  9. Jun 23, 2012 at 1:10 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
  10. Jun 25, 2012 at 12:21 AM
    Eesh
    trd Sport
    Does anyone know anything about a brand called National????
  11. Jul 3, 2012 at 3:32 PM
    Eesh
    trd Sport
    Ok so now I have two choices.
    One of the choices is the SKF bearings with the hub and the other choice is the SKF bearings with out the hub.
    Will I need to purchse seels for both of these options???
  12. Jul 3, 2012 at 3:42 PM
    ST3VE
    ST3VE IG: @fishsohard
    MD --> SC
    Tint, car seat, baby wipes
  13. Nov 8, 2015 at 5:31 PM
    Vancehale
    Vancehale New Member
    Vance
    .....Just pressed my front passenger side bearing with 12 ton press. Easily done. Mines a rwd prerunner, pretty large bearings.
