FS: The CVRV Mirror Riser (new product)
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Tbird, Aug 8, 2013.
  1. Nov 8, 2017 at 11:53 AM
    #181
    DANGERMONEY
    DANGERMONEY Well-Known Member
    +1
    I've been really careful not to do this. I would also recc not hanging accessories from it.
    EatSleepTacos[QUOTED] likes this.
  2. Jan 24, 2018 at 8:59 AM
    #182
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    The website doesn't seem to work for me. I emailed the company to see if I can get an order.
  3. Jan 24, 2018 at 9:46 AM
    #183
    GDT
    GDT Well-Known Member
    '09 Tacoma 4x4 access base 2.7l 5spd
    Get that annoyingly low mirror out of your line of sight, and replace it with a gadget to block your view again.
    wuttheheeck, Biscuits, PDXKid and 2 others like this.
  4. Jan 25, 2018 at 2:11 AM
    #184
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I simply put a double layer of 3M trim adhesive on the mount leaving a small tab of the backer sticking out so I could grab it with pliers. I then slid the mount on to the dove tail receiver and pulled the backer out and pressed the adhesive to the windshield.
    The adhesive is what holds the mirror up now and the stock mount is simply a location tab.
    I've had no issues with breakage as the load is more evenly dispersed across a significantly larger surface area and I regularly adjust the mirror one handed as the instructions tell you not to do.
    Absolutely love my mount!
  5. Jan 26, 2018 at 8:25 AM
    #185
    Tbird
    Tbird [OP] Well-Known Member
    Tom
    Santa Teresa, NM
    05 4X4 TRD Sport Access cab (white)
    ICON Ext.trav coilovers, rear ICON w/res. TC UCAs. All-pro 3" leafpac & U-bolt flip kit. Konig Countersteer offroad wheels. Goodyear Durtracs 260/75/16. Blacked-out badging, BHLM, Extra D-rings, Satoshi grill, SockMonkey "All Terrain" decals, Avid Off-road light bar and rock rails, Wet Okey seat covers. Weathertech digital fit floor mats. GROM ipod interface.
    Not sure how GoDaddy did it...but our BirdDawg Industries page got royally screwed up. Not sure how, but almost no links worked.
    Got it fixed last night...so ordering Mirror Risers and Tech Decks should be a snap once again. Sorry for the inconvenience.
    http://www.birddawgindustries.com/
    Thanks again for all the orders, AND the great reviews!
  6. Jan 26, 2018 at 8:27 AM
    #186
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Biscuits likes this.
  7. Feb 7, 2018 at 5:59 AM
    #187
    ArmandHammer83
    ArmandHammer83 This truck is AMAZING
    Raymond
    Alabama
    2018 Tacoma AC V6 MT 4x4
    none yet
    i ordered a mirror riser last night i read good things so i'm hopeful to fix the ducking issues
    EatSleepTacos likes this.
  8. Mar 1, 2018 at 6:40 AM
    #188
    yotastaco
    yotastaco Well-Known Member
    NC
    2015 MGM TRD OR
    See Build
    I've purchased one to run a RAM mount for my phone.
    Tools
    1/32 Hex Key
    Torx 20
    3M Molding Adhesive Tape
    Due to the concerns of cracking a windshield, I've made some initial modifications that I believe will reduce the risks.
    I've added 3M Molding Tape to the back of the mount to mitigate stress points and metal vibrating against the windshield.
    After installing the base, I added Blue Loctite to all screws, and tightened down the screws very very lightly. I noticed a small gap behind the base, and applied the molding tape.
    Final Thoughts
    The riser installed easily, but the instructions were not accurate for a 2015 Generation, and the windshield cracking issues made me more cautious. I'll report back if anything changes.
    Suggestions
    I'd like to see a polymer version of this mount to reduce the weight on the windshield and the vibration of metal on glass.
    Slashaar, Biscuits and wavytrent like this.
  9. Apr 4, 2018 at 8:57 AM
    #189
    wavytrent
    wavytrent Well-Known Member
    Trent
    ICT Kansas
    2015 Super White TRD Off Road Double Cab Tacoma
    SCS F5s BAMF Sliders BAMF Bed Rack BAMF Skids
    Whats different for the 2015? I just ordered and will be installing soon. I may steal your idea to prevent any windshield cracking.
  10. Apr 12, 2018 at 5:32 PM
    #190
    wavytrent
    Trent
    ICT Kansas
  11. Apr 29, 2018 at 3:53 AM
    #191
    yotastaco
    NC
    2015 MGM TRD OR
    See Build
    Nothing different for 2015 vs 2005+. Instructions were a little off, but nothing common sense couldn't adjust for.
    Use 3M Trim dual-side backing tape. 3M Molding Adhesive Tape
    Also, I don't run the RAM Mount on the ball all the time, so far I've only used it for long trips.
  12. Apr 29, 2018 at 4:27 AM
    #192
    Kennedyusmc
    Kennedyusmc Well-Known Member
    Christopher
    2017 Cement Pro
    Still waiting for it
    3G compatible?
  13. Jun 25, 2018 at 4:10 PM
    #193
    06TXED
    06TXED Well-Known Member
    Tony
    Aurora CO
    2023 DCSB MGM TRD OR 4x4
    Does anyone know what size and thread pitch for the RAM ball mounting bolts ?
  14. Jun 25, 2018 at 4:33 PM
    #194
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    10-32
    06TXED[QUOTED] likes this.
  15. Oct 31, 2018 at 3:13 PM
    #195
    45calmike
    45calmike Well-Known Member
    2010 Crew Cab 4x4 Long Bed SR5
    I read through the threads and it seems the solution to reduce the likelihood of the cracked windshield is to use 3M adhesive, correct?
  16. Nov 27, 2018 at 7:16 PM
    #196
    DblD
    DblD Well-Known Member
    Dave
    SW Missouri
    '18 DCSB TRD/OR - Prem. & Tech.
    I had a mirror riser on my '09 and thought it was great. Now I have a new '18 and I'm encountering the same issues with placement of the rear view mirror. Wondering if anyone has tried this on a Gen. 3?
    Thanks,
    dd
  17. Dec 20, 2018 at 6:02 AM
    #197
    Lil red 02
    Lil red 02 Spendaholic
    Brent
    Sanford, Fl
    2005 Doublecab longbed
    Just put my order in for the mirror relocation with ram mount. It was bad before but after the seat riser mod its really in the way. Cant wait to have more sight while riding in the woods.
  18. Dec 24, 2018 at 7:24 AM
    #198
    Lil red 02
    Brent
    Sanford, Fl
    Trying to put my Riser on now, I popped the mirror off the ball but can't seem to get the mount off of the windshield any hints or tips?
    Edit I went to their website and there was much better directions than the ones they sent. It went on perfect and I can't wait to use it driving daily thanks guys
  19. Jan 3, 2019 at 11:14 AM
    #199
    quikrain
    quikrain Well-Known Member
    2017 Red Tacoma TRD SP DCLB
    Is this available on 3rd Gen?
  20. Jan 4, 2019 at 1:48 PM
    #200
    Shayne
    Shayne Well-Known Member
    Shayne
    South Shore, Mass
    2018 Inferno TRD Sport DC 4x4
    Hey, I got mine delivered yesterday and tried to install it. In my 2018 Sport, I have a box that does the lane departure thing and something else next to the original bracket. I talked to Max from Bird Dawg this morning on the phone and he said that I'd probably have to do some trimming. Looked at it a little while ago and think that he's right.. Ill have to trim the passenger side flush so it sits flush with that black box. Ill give it a whirl tomorrow.
    cfalc0n and DblD like this.
