Fuel door hitting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 88nitro305, Apr 6, 2018.
  1. Apr 6, 2018 at 1:54 AM
    88nitro305
    88nitro305 [OP] Well-Known Member
    Tom
    Vermont
    2012 white DCSB TRD OR
    Does anyone have this issue if your fuel door scraping when opening? I have never put any pressure on it or bent it.. one day it just starting rubbing when I would fully open it. It’s bothering enough to where I want to know if others have this issue?
  2. Apr 6, 2018 at 2:31 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    https://www.tacomaworld.com/threads/fuel-door-problem.117776/
    https://www.tacomaworld.com/threads/fuel-door-issue.358949/
    https://www.tacomaworld.com/threads/have-to-have-my-fuel-door-replaced.533274/
    https://www.tacomaworld.com/threads/fuel-filler-door-rubbing.132685/
  3. Apr 6, 2018 at 2:42 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Known issue when the hinge isn't maintained by cleaning and greasing.
    88nitro305[OP] likes this.
  4. Apr 6, 2018 at 2:43 AM
    RBTaco
    RBTaco Well-Known Member
    2013 RC 4X4
    Trac rac, tow hitch, fog lights, tonneau cover, Texas Edition rims, custom console, weathertech floor mats.
    Hinge is either bent or broken.
  5. Apr 6, 2018 at 3:15 AM
    88nitro305
    Tom
    Vermont
    Thanks guys will have to check it out and replace it
    TheTrooper likes this.
  6. Apr 6, 2018 at 3:23 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Unless it’s bent or damaged, like others said just grease the hinges. I used a Q-tip dipped in grease to get in the hard to reach spots. No problems since.
  7. Apr 6, 2018 at 3:58 AM
    88nitro305
    Tom
    Vermont
    Thanks guys! I’ll check it out after work and see if it’s indeed bent, broke or just dry
