Fuel econamy issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fredlyzone, Feb 14, 2018.
  1. Feb 14, 2018 at 8:56 AM
    fredlyzone
    fredlyzone [OP] Member
    Fred
    Austin, Texas
    4x2 TRD Off Road w/JBL
    Push Guard, Modified Skid Plate, Bug Deflector.
    I have a 2010 TRD Offroad 2wd with 110000 miles and my number of miles per gallon has fallen off lately. It has had regular maintenance and overall runs well. Have any of your had this issue and done anything to correct the issue? I run the Iridium plugs but have had them in for 50k. What about cleaning the fuel injectors? Any advice would be greatly appreciated.
  2. Feb 14, 2018 at 9:02 AM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
  3. Feb 14, 2018 at 11:01 AM
    grizquad
    grizquad Well-Known Member
    Massachusetts
    12 Tacoma TRD sport
    Plasmaglow Firestorm lights, Westin Bull bar, Flyzeye interior console lights
    I see you are in Texas, I am in New England. Every winter mileage drops off, change of formulation and just plain cold. I know Texas has had some pretty cold and wild weather this winter, wait until Spring and everything should go back to normal. I have read that Iridium plugs (from articles here) don't really help mileage. Last summer went back in with normal Denso plugs and my mileage went up a little.
    outlawtacoma and fredlyzone[OP] like this.
  4. Feb 14, 2018 at 11:14 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OP what are you MPG's?
  5. Feb 14, 2018 at 11:15 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    2015 sporty dcsb 4wd
    Lifted, armored, lumenz w/ switches, positraked, long legged, big tars, debadged with a hood skewp
    Winter blend gas an in colder conditions vehicles run richer an air is more dense allowing more in the same allotted space. Therefore more fuel consumption you ever notice on cool day your truck is a little peppier that’s what’s happening. Hope this helps.:thumbsup:
  6. Feb 14, 2018 at 11:17 AM
    fredlyzone
    Fred
    Austin, Texas
    I get bewteen 14-16 in the city a bit more if it is all highway driving.
  7. Feb 14, 2018 at 11:29 AM
    fredlyzone
    Fred
    Austin, Texas
    I don't think it is a Winter thing but I guess time will tell. It will be warm here some enough! ;-) I plan to go back to the standard plugs the next time I work on it...
    grizquad[QUOTED] likes this.
  8. Feb 14, 2018 at 11:42 AM
    nd4spdbh
    SoCal
    any mods (tires lift etc). 16 in the city sounds about right.
  9. Feb 14, 2018 at 11:46 AM
    fredlyzone
    Fred
    Austin, Texas
    It has stock sized tires and only an add-a-leaf in the back and 5150s. Pretty much stock suspension.
  10. Feb 14, 2018 at 11:47 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Have you cleaned the MAF and throttle body?
    MattCowsmasher likes this.
  11. Feb 14, 2018 at 11:48 AM
    fredlyzone
    Fred
    Austin, Texas
    Not recently but that sounds like a great idea! What do you use to clean them?
  12. Feb 14, 2018 at 11:50 AM
    taco2010trd
    Tampa, Florida
  13. Feb 14, 2018 at 12:22 PM
    b_r_o
    b_r_o Beef jerky time
    Alex
    WA
    2015 DCLB
    Is the check engine light on?
  14. Feb 14, 2018 at 12:24 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    4-banger? If not switch to Denso or NGK stock plugs. Can try to run some Seafoam through the Gas tank and intake as instructed on the bottle.
    taco2010trd and b_r_o like this.
  15. Feb 14, 2018 at 12:34 PM
    fredlyzone
    Fred
    Austin, Texas
    No, all is normal.
  16. Feb 14, 2018 at 12:34 PM
    taco2010trd
    Tampa, Florida
    Op keep us posted after you try those recommendations
  17. Feb 14, 2018 at 12:36 PM
    fredlyzone
    Fred
    Austin, Texas
    It is the 6 cylinder Pre-Runner. I have added Lucas Upper Cylinder Lubrication & Injector Cleaner several tank fulls recently.
  18. Feb 14, 2018 at 12:40 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Are those the same tank fulls you are getting lower mileage on? You could have dirty O2 sensors from all that intake/injector cleaner. Best way to make any real diagnoses would be with an obdii reader and associated phone app/laptop.
    b_r_o likes this.
  19. Feb 14, 2018 at 12:43 PM
    fredlyzone
    Fred
    Austin, Texas
    No, I usually run some of this every several months. I'll have to remove one of the O2 sensors and have a look but no codes are being reported.
  20. Feb 14, 2018 at 12:46 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Sensors don't always throw a code. Fuel trims as a "response" to O2 readings can be within a 20% swing and still not throw a code, but towards the boundaries can run rich/lean enough to drop mileage
