Functional Hood Scoop (RKS Sport Hood Scoop) for Engine Cooling
Discussion in 'Performance and Tuning' started by zscott, Dec 14, 2017.
  1. Jan 4, 2018 at 6:45 PM
    #41
    omgwtfbbq!
    omgwtfbbq! Well-known Idiot
    Ohio
    2013 X-Runner
    If you want a cooler engine just run a colder thermostat. That being said, my scoop is functional because fake scoops are lame as hell.
    1997tacomav6 likes this.
  2. Jan 5, 2018 at 4:48 AM
    #42
    ChadsPride
    Sponsored by TacomaWorld.com
    Have you considered hood louvers?
  3. Jan 5, 2018 at 8:13 AM
    #43
    zscott
    zscott [OP] Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Already did that. It has made a big difference but we are in the middle of winter so I don't know if it will provide the same performance when the temps start heating up. If it does then no problem and I probably wont bother with the hood. If it doesn't make a difference I will keep exploring more options, one of which is this hood.
  4. Jan 5, 2018 at 8:13 AM
    #44
    zscott
    Zach
    Utah
    Based on what I have read those would be better. The problem is nobody makes a louvered hood for tacomas to my knowledge and body work is not my strong suit.
    ChadsPride[QUOTED] likes this.
  5. Jan 5, 2018 at 8:15 AM
    #45
    ChadsPride
  6. Jan 5, 2018 at 8:27 AM
    #46
    sasquatch95
    sasquatch95 Well-Known Member
    Hunter
    nanaimo BC
    07 DCLB sport
    McNeil makes one. I'm just not sure if it's functional or just for looks
    ChadsPride likes this.
  7. Jan 5, 2018 at 8:37 AM
    #47
    chyknees
    chyknees nomadic wanderer
    So Cal
    05 Tacoma TRD 4x4
    TRD, Total Chaos, Fox, Volk, BFHoodrich
    hood louvers
  8. Jan 5, 2018 at 8:46 AM
    #48
    zscott
    Zach
    Utah
    I think theirs only is for the 05-11 trucks. Mine is a 2013.
  9. Jan 5, 2018 at 8:47 AM
    #49
    zscott
    Zach
    Utah
    I would consider something like this if I had a second hood to try it on. Don't want to cut and drill my current hood and it not be functional or look good.
    ChadsPride and Murphinator like this.
  10. Jan 5, 2018 at 8:51 AM
    #50
    zscott
    Zach
    Utah
  11. Jan 5, 2018 at 8:51 AM
    #51
    ChadsPride
    Totally understandable, just trying to help :thumbsup:
  12. Jan 5, 2018 at 8:58 AM
    #52
    omgwtfbbq!
    Ohio
    2013 X-Runner
    Nowhere near as much debris, water, and dust as comes in from the bottom I'd wager.
    1997tacomav6 and ChadsPride like this.
  13. Jan 5, 2018 at 10:19 AM
    #53
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    With louvers like that facing the windshield whenever you are moving air would be pushing out of the louvers so it would be pushing dust away, water yes for sure but I've been rinsing my engine compartment weekly for ten years with no issues so non issue really.
  14. Jan 5, 2018 at 10:20 AM
    #54
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    That is a debatable topic as well because the 4.0 is designed to run at the temp range the OE thermostat provides. I've read a few times that it is not good to run it colder
  15. Jan 5, 2018 at 10:58 AM
    #55
    zscott
    Zach
    Utah
    I would agree with this until you start introducing forced induction applications. My truck always was fine until the supercharger was introduced and then my average temps jumped up from operating between 180-192 stock to 195-210 supercharged. I added the URD high performance thermostat so that it opens sooner and am now back down to the 182-188 temp range during normal operations.
  16. Jan 5, 2018 at 4:24 PM
    #56
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Sure thing, that makes complete sense with the increased temps from your SC. It's something crazy like +10 degrees intake temp for every pound of boost right ?
    ChadsPride and 1997tacomav6 like this.
  17. Jan 5, 2018 at 4:28 PM
    #57
    zscott
    Zach
    Utah
    That's what I have read on the forums. I usually peak at around 6lbs of boost up here at 5000-6000 feet so roughly a 60 degree intake temp increase.
  18. Jan 5, 2018 at 6:26 PM
    #58
    1997tacomav6
    Denver
    :burnrubber:
    Yea, so if your engine is not running a turbo or supercharger no sense in having an open scoop, but having a blocked scoop does seem a bit lame,
  19. Jan 5, 2018 at 6:27 PM
    #59
    1997tacomav6
    Denver
    And I peak at 10 pounds at 6000 feet, so I'm definitely happy with a working scoop
