Garage Shop: Tools
Discussion in 'Garage / Workshop' started by T4RFTMFW, Jan 26, 2019.
  1. Aug 10, 2022 at 11:58 AM
    #5441
    Kwikvette
    Fresno County
    4 run, 2 don't
    Will do.
    Got new hoses between the filter to air compressor and plasma cutter. Conveniently short (at HF) cause I hate running super long hoses where I need a short run.
    la0d0g and dumontrider like this.
  2. Aug 10, 2022 at 1:01 PM
    #5442
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    No markings on it, if I had to guess from memory I'd say Craftsman. Definitely not impact rated :bananadead: Replacements are 1/4, 3/8 & 1/2" impact rated Milwaukee Shockwave.
    Toyko Joe[QUOTED] likes this.
  3. Aug 10, 2022 at 1:35 PM
    #5443
    la0d0g
    running for the hills
    For crawling not hauling
    I need new hoses!
    Kwikvette[QUOTED] likes this.
  4. Aug 10, 2022 at 4:05 PM
    #5444
    Kwikvette
    Fresno County
    4 run, 2 don't
    Got them from HF.
    Surprised how beefy they are really, and the swivel at the end is convenient and leak-free.
    It's 3/8" at 5' long Also opted to use brass couplings for quick connect/disconnect.
  5. Aug 10, 2022 at 9:30 PM
    #5445
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Buy a quality die grinder. After investing in some Mac air tools, I’m a believer. My Mac die grinder and 3” 90 degree grinder are insane. They have a dial to adjust air flow. On low they’re great for precise and finish work or high hogs material away.
    I also bought quality consumables as well and that made a difference as well.
  6. Aug 10, 2022 at 11:40 PM
    #5446
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    If you already have milwaulkee power tools, I have one of the m18 die grinders, and 2 of the m12 90 degree die grinders, and they have been great. Get used every day, quite a lot.
    la0d0g likes this.
  7. Aug 11, 2022 at 7:27 AM
    #5447
    Toyko Joe
    Toyko Joe Here for the pictures
    Welders,
    I haven't welded in 20 years, but I have a few small welding projects I need to address in the next year. I think I want to buy a little flux/solid core or maybe even a tig/stick welder. Nothing crazy I won't be welding anything large and don't want to spend more than $300 total. Open to suggestions. Thanks in advance for all your help.
  8. Aug 11, 2022 at 8:06 AM
    #5448
    cynicalrider
    cynicalrider #NFG
    Jersey
    Used market will only get you something that can do solid core well. Never used it but flux-core only Titanium 125 is also in your price range.
  9. Aug 11, 2022 at 1:44 PM
    #5449
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    I got a Eastwood 130 and it does fine. Think u can even get it with free shipping at times.
  10. Aug 11, 2022 at 2:35 PM
    #5450
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    Might have better luck/visibility here...
    https://www.tacomaworld.com/threads/anything-welding.113957/page-1167
    Drainbung likes this.
  11. Aug 11, 2022 at 5:26 PM
    #5451
    Kwikvette
    Fresno County
    4 run, 2 don't
    Well, what projects exactly?
    I'd opt for a welder that can do solid core, so you can have the option in case you want to do some clean welding.
    Most will also do stick welding, which in turn can be made to TIG weld. Any stick welder can be a TIG welder, just need to adapt shielding gas and control it independently.
    Or maybe you're close by and we can just knock them out right away.
  12. Aug 12, 2022 at 5:12 PM
    #5452
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Bought an old Sears compressor, works great
    Grumpy, la0d0g, OffroadJet and 3 others like this.
  13. Aug 13, 2022 at 4:12 AM
    #5453
    OffroadJet
    OffroadJet Well-Known Member
    Sebastian, FL
    2018 Offroad 4x4 - Manual
    id LOVE to have this lol good find
    Grossomotto[QUOTED] likes this.
  14. Aug 14, 2022 at 10:35 AM
    #5454
    Kwikvette
    Fresno County
    4 run, 2 don't
    Coming back to ya as promised.
    So the other day I went ahead and opted for the "not so cheap" Harbor Freight die grinder. I mean everything is super cheap there anyway.
    It's the Chief mini die grinder, some professional series.
    I chose it over the others because both its size, and weight. Felt much better in my hands than the other.
    Someone mentioned the medium used, and as simple as die gringers are, I opted for a nice Champion titanium carbide burr bit. Got that on Amazon.
    The bit by itself had a lot of heft to it; made in good ol' USA.
    Had forgotten to get a swivel when I took this pic.
    Anyway I got to work on my bumper a tad and this thing made stupid quick work of it.
    The air compressor didn't even have to kick on for more than 3-5 seconds when I finished. This thing just eats metal away easily.
    I don't have it turned up all the way cause I remember at really fast speeds it can catch so I wanted to prevent that.
    I'm normally one for battery-powered goodies, having M18 and M12, but I wanted to add some air tools to the bunch. My air compressor does plasma cutter duty almost exclusively.
    rob1208, jubei, Grumpy and 4 others like this.
  15. Aug 14, 2022 at 1:54 PM
    #5455
    la0d0g
    I need to get one of those bits.
    Drainbung and Kwikvette[QUOTED] like this.
  16. Aug 14, 2022 at 1:59 PM
    #5456
    Kwikvette
    Fresno County
    4 run, 2 don't
    That's right, you were the one suggesting just going with HF on a die grinder.
    The bit for sure is the real reason why this made the job super quick. I should mention I did dial down the regulator as well as the one in the tool and it never bogged down once.
    Not a single chip on the bit either.
    If the tool was something I used often, I would've opted on a whole bit set (they're $250+) but for small work, buying one or two at $20-30 each will easily suffice for a long time.
    dumontrider and la0d0g[QUOTED] like this.
  17. Aug 14, 2022 at 6:29 PM
    #5457
    Taco & Salsa
    Taco & Salsa Well-Known Member
    Marcus
    San Antonio, TX
    2017 Black SR5 DCSB 4x4
    This is my work in progress. Started this morning. Still need pegboards and some other bits.
  18. Aug 14, 2022 at 8:52 PM
    #5458
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Its possible that I will be in the market for a riding lawn mower in the near future. I dont know anything about riding mowers though, what things should I look for since I will most likely buy a used one? I am thinking John Deere, Cuba Cadet, Toro.
    Something in the 40 inch range, good mulching feature, don't care about bagging clippings.
  19. Aug 15, 2022 at 9:49 AM
    #5459
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Definitely hop in this thread too. Lots of guys into older, used stuff who can point you in the right direction for used stuff https://www.tacomaworld.com/threads...to-parts-websites-in-1st-post.649569/page-434
  20. Aug 15, 2022 at 1:35 PM
    #5460
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Finally got my side box in and for once it was cheaper than i expected.
