Gear Oil + LSD additive
Discussion in '2nd Gen. Tacomas (2005-2015)' started by j1999t, Dec 11, 2009.
  1. Dec 11, 2009 at 4:05 PM
    j1999t
    j1999t [OP] Well-Known Member
    Justin
    Northern Colorado
    traded it in
    im getting my gear oil in my rear diff changed tomorrow and i know i need 80W-90, but what brand is best? and what about LSD additive (my truck has LSD rear end)
    thanks
  2. Dec 11, 2009 at 4:08 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Read this thread, and it will give some good suggestions. I think a lot of those guys with LSD's are running dyno oil with the LSD additive.
    EDIT: I'm not sure what brand most of them are suggesting but any name brand dyno oil should be good, but read the thread and it will have some suggestions.
    http://www.tacomaworld.com/forum/technical-chat/24545-changing-differential-fluid-step-step-how.html
  3. Dec 11, 2009 at 4:12 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    As long as it's the correct grade (80W-90) the brand shouldn't matter. As for as the LSD additive, I went with Lubegard :
    http://www.youtube.com/watch?v=WBo4Jqm4j2o
  4. Dec 11, 2009 at 5:40 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    I currently have Valvoline 80w-90 + Motorcraft LSD additive in my truck. Works fine.
    Before, I had 75w-90 and NAPA LSD additive. I was getting the groans in the morning.
    My local dealership sells Kendall 80w-90 LSD Gear Oil. Only $4.99 per qt.
  5. Dec 12, 2009 at 6:16 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I've used Amsoil Severe Gear oil in our corvette LSD rear. Works great.
    It already has the additive in it.
    Just double check it's the proper specs for tacomas. I'll probably use that in mine when its time to change - assuming it meets recommendations (I haven't looked myself).
  6. Dec 26, 2010 at 3:06 PM
    WV_Tacoma
    WV_Tacoma Well-Known Member
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    I have a 2005 prerunner v6, 4.0 auto trans, basic truck, no trd or anything like that, no possi rear end..........
    I do not have the rear lsd sticker....the manual doesn't say use lsd. only 90 sae.......
    I tow 5,ooo # travel trailer in and out hills and 1k miles trips...
    1. I can not find 9o sae only. I found 80/90 sae...it has lsd in the bottle
    2. should I upgrade for towing?
    4. I think I would like syn fluid..?
  7. Dec 26, 2010 at 8:06 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    If you towing go with some good synthetic. Like Mobil Delvac 75w-90. Make sure you have good amount in Diff as it will need it to keep it cool.
  8. Dec 26, 2010 at 8:21 PM
    wired_af
    wired_af Well-Known Member
    Alex
    Colorado Springs, CO
    '07 DC TRD Sport S/C, Rivian R1T
    I highly recommend the Redline gear oil with the additive already in it. After going through many oil changes and additives , this is the only one that has worked for me.
  9. Dec 26, 2010 at 8:25 PM
    WV_Tacoma
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    do you think this amsoil 110sae is to much for our trucks? I tow....
  10. Dec 26, 2010 at 8:38 PM
    BlueT
    NorthEast
    I dont know how good Amsoil is, I tow it too but I have LSD so it was hard to get oil right. Delvac worked with GM additive and it is used in 18 wheelers so its good assurance that if you tow it can handle towing.
  11. Dec 27, 2010 at 12:25 AM
    AFTaco
    AFTaco Well-Known Member
    Doug
    Anchorage, Alaska
    TRD Off-road
    I just finished replacing my front and rear diff, and my transfer case with royal purple. I was kinda hesitant about spending $20 a quart, but living in Alaska, cheap synthetic is still expensive. Anyways, I test drove it and I will always use Royal Purple. Remember your first ride in a car with brand new tires installed? Less hummin, smoother drive? Its kinda like how I felt when driving with the Royal Purple. also, if you have the TRD Sport, it already has the LSD additive. My truck only has 15k but I felt that my rear diff had water in it after driving through 3ft of water this summer. come to find out, it didn't have any water. I still do not regret changing my fluilds though. Royal Purple has a new fan!
  12. Dec 27, 2010 at 4:15 AM
    Janster
    Jandy
    Lancaster, PA
    Hmm thread revival battman....
    Just noticed the guy has a 2010 and he has an AUTO LSD and doesn't need any friction modifiers.
    :D
  13. Dec 27, 2010 at 4:30 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    11' tacoma SR5 4x4 I use Synthetic 75-90 for both diffs and transfer. No additive needed (changed my rear to detroit mechanical-no clutches)
  14. Jul 11, 2017 at 5:00 PM
    Bravisimo
    Bravisimo So many mods, very little money.
    Joe
    Santa Clarita, CA
    2014 Tacoma PreRunner SR5 DCLB
    Tint, headlights wrapped & rear lights smoked, power outlet mod., grill & rear bumper wrapped, Falken A/T 3W,
    My truck has auto lsd, so I should use an LSD additive?
  15. Jul 11, 2017 at 6:07 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    No not needed
    Bravisimo[QUOTED] likes this.
  16. Jul 11, 2017 at 7:07 PM
    Bravisimo
    Joe
    Santa Clarita, CA
    Thanks man. appreciate it.:thumbsup:
    Lord Helmet[QUOTED] likes this.
  17. Jul 11, 2017 at 7:07 PM
    Lord Helmet
    Nick
    '24 X3 M40i
    Yup no problem!
  18. Jul 11, 2017 at 7:22 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    I use whatever brand of non synthetic 80-90 (I might go with 85-140 next time, that's what east coast gear supply recommends) gear oil and the 4oz champion lsd additive in the rear diff. I use synthetic 75w-90 in the front diff and transfer case. IMG_4958.jpg
    Bravisimo likes this.
