Getting new tires, have a couple n00b questions (yes, I searched)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Beancooker, Aug 12, 2019.
  1. Aug 12, 2019 at 7:53 PM
    Beancooker
    Beancooker [OP] Alea iacta est
    The middle of Arizona
    2021 Jeep Wrangler Rubicon
    Lots, straight from the factory.
    I searched and read a fair bit, and a lot if my questions have been answered, but I still have two:
    Okay, so my wife decided that it is time to ditch the stock tires and get some decent off road tires. I’m petty partial to the BFG KO2’s.
    1. The KO2 vs KO2DT. Read all about the differences. I’m in AZ, rare to see snow. I’m assuming the DT would be just fine for off roading, and I benefit from a 50k warranty. Are there any downsides to the DT?
    Edited the second question. After continued searching, I found the answer. Still curious about question one.
  2. Aug 12, 2019 at 7:57 PM
    MolonLabe1977
    MolonLabe1977 Well-Known Member
    Ben
    San Diego, CA
    2019 Super White DCSB
    From what I've gained from reading on here, 265/75/16 is going to be the biggest size without a lift or other trimming. Can't really answer the others, but somebody will come along.
  3. Aug 12, 2019 at 7:58 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Won’t fit without suspension mods. Will hit cab mounts and front well. Maybe other parts. Lots of threads on that size.
  4. Aug 12, 2019 at 8:21 PM
    Beancooker
  5. Aug 12, 2019 at 8:22 PM
    Dampahee
    Dampahee Well-Known Member
    So Cal
    2019 TRD Off Road
    Fox Factory 2.5 extended travel w/DSC Eibach 650x14 springs Fox Factory 2.5 x 12 in smoothies with rr and DSC / Accutune Adventure tune Archive Garage shock relocation Archive Garage hammer hangers with 3.6" shackles Archive Garage high clearance cross bar Deaver Expedition u402 stage1leaf pack Camburg Racing Uniball UCA's Total Chaos Gusseted Spindles Marlin Crawler HD LCA/cam tabs Frame Brace gussets @weldstaco front diff reinforment kit Wheelers u-bolt flip kit with super-bumps Crown performance SS 24 in extended rear brake lines SS extended front break lines Exhaust re-route mod Dirt King Cab Mount Relocation OV Tune-91 Performance Nitro 5.29 Gears ARB Front Locking Differential ARB High output in board compressor Slee On-board compressor mount Blais Bros Taco differential breather mod Schmellfab 12.5° sliders with kick out RCI steel IFS skid RCI steel transmission skid RCI steel T-case skid RCI LCA skid BAMF Rear differential skid Relentless Fabrication hybrid front bumper Relentless Fab High Clearance rear bumper ATHF rear fender supports SOS performance rear disc brake conversion Trimmed Fenders 2.5" Softopper TRD Heritage grill RFT Raptor lights Morimoto XB headlights Baja Designs amber S2 flush mount chase lights Baja Designs S8 30 in lightbar Cali Raised Relay Mount Cali Raised cubby switch mount Smittybuilt X20 10 k winch Factor 55 Fairlead Factor 55 Flatlink E Factor 55 Flatlink Ropeguard Tandem Off Road Manor winch solenoid mount 1.25 inch Spidertrax wheel spacers 17x9 Ultra Wheel x103 beadlocks 35/11.5/17 Nitto Trail Grapplers Fend-X Wheel Liners Clazzio leather seat covers Taco Garage DMM Mount Taco Garage Anytime Front/Rear Camera MESO Customs Chrome Delete MESO Extended fuse cover AVS in channel low-profile wind visors Kicker CS tweeters, 6x9, 6.5's Kicker Key amp Kilmat sound deadening
    255/85/16 is the biggest. There is a big thread on them.
  6. Aug 12, 2019 at 8:25 PM
    bongbong
    bongbong Active Member
    Georgia
    2019 White Tacoma SR5
    Does anyone know if 285/75R16 will rub with 2inch lift?
  7. Aug 12, 2019 at 8:26 PM
    photogr4x4
    photogr4x4 Well-Known Member
    Canada
    TRD OR
    Nada
    If you do reach snow and deal with it regularly you'll want better tread than the regular KO2s could ever provide anyhow. Get the DTs, avoid snow, have a better warranty and stronger sidewalls. Sounds like a solid choice to me.
    Beancooker[OP] likes this.
  8. Aug 12, 2019 at 8:31 PM
    Beancooker
    @photogr4x4 Thank you! I appreciate the feedback.
    Bongbong, your answer lies within the search button. Here is a link.
    Largest tires WITHOUT a lift
    bongbong[QUOTED] likes this.
  9. Aug 12, 2019 at 8:44 PM
    Mugsy7
    Mugsy7 Well-Known Member
    Mugsy
    Delco, PA
    2021 Cement TRD OR DCSB
    Truxedo Pro X15 tonneau, front tinted windows
    Save some dough. Get General Grabbers ATX.
    JoeCOVA, photogr4x4 and Shellshock like this.
  10. Aug 12, 2019 at 8:57 PM
    Beancooker
    Well, the BFGs are $188 each. The generals are $174. Saves me $56
    For $56 I’d rather have the reliability of the BFGs.
  11. Aug 12, 2019 at 8:59 PM
    photogr4x4
    Canada
    TRD OR
    Nada
    I've heard good reviews about the newer Generals but nothing long-term unfortunately. KO2s might not get past 65% good reviews (that I've seen) but they're well documented and reviewed through many years.
  12. Aug 12, 2019 at 9:02 PM
    Bishop84
    Bishop84 Well-Known Member
    I would 100% do a DT long life tire in AZ. General tires are softer and designed for more rounded climates. Regular KO2's are snowflake rated, so softer.
    Toyo Open Country AT2's have really good tread life in the Extreme LT form, and are a harder compound.
  13. Aug 12, 2019 at 9:15 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    KO2’s are great for dry, desert roads with sharp rocks, including old basalt (lava).
    [Edit] I used to get up to 40k with them on my work truck (70/30 percent on and off-road) and over 45K on my personal trucks (85/15)] and I have not had any significant gouging on them from the roads I drive with them. Also, I have never gotten a blowout in over 600k miles using KO’s on all of my former Toyota’s, including our work trucks.
    I’ve only owned KO’s when I worked off-road a lot, and still use them for my recreational off-road trips, including when towing and remote camping with a lot of gear, steel armor and extra water in my 2017.
    People are right though, they don’t do as well as other tires on snow, but how often does that happen in our desert but for a few days every couple years?
  14. Aug 13, 2019 at 3:20 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I have always run BFG AT for the past 35 years on all my 4wheels drives. But not on my Yotas. Something about them and the balancing. BFGs are always known for being hard to balance and take a lot of weight. They are an extremely hard tire to keep maintained. Hands down a Toyo AT2 is a better tire, 65K mile warranty. They are better in the rain,sand and very quiet and don't require a lot of weight to balance. BFGs are great looking tires and now that I run Toyos, BFGs are just pretty!
  15. Aug 13, 2019 at 6:30 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Stay on the forums long enough and you’ll quickly find that KO2s aren’t that reliable. Or at least anymore reliable. The Generals offer both 3 peak rating and a 60k mile warranty. The KO2s do not offer this.
  16. Aug 13, 2019 at 6:41 AM
    OnHartung'sRoad
    KO2’s have a 6-year/50K mile warranty.
    As far as reliability, according to some, I guess Ive been really lucky with KO’s and KO2’s over my last 600,000+ miles driving with them...
  17. Aug 13, 2019 at 6:44 AM
    rideawalrus
    rideawalrus Well-Known Member
    Four Corners area
    '16 TRD OR 4x4 Prem Tech/JBL Blazing Blue, King coils/shocks, deaver leafs
    King coils/shocks, deaver leafs Pelfrey skid soft topper Nalgene holder
    I've also run KO and Ko2s for the past 12 years and never had a single problem. My last set of the snow rated ones on my 2016 tacoma got about 40k miles, and still had another 5k or so when swapped them for the next size up. I'd call that reliable, especially with the amount of offroad I do.
  18. Aug 13, 2019 at 6:48 AM
    JoeCOVA
    Joe
    Colorado Springs
    The warranty only applies to select sizes. You either get a warranty and no 3peak or you get 3 peak and no warranty. General offers both.
    I ran BFGs exclusively for many years and multiple vehicles, they aren’t bad but there are a lot of other really good tires out there
  19. Aug 13, 2019 at 7:18 AM
    OnHartung'sRoad
    I have three peaks and the 50K warranty, it must have changed since you last had some, all BFG’s are covered:
    https://www.bfgoodrichtires.com/Tire-Warranty.page
  20. Aug 13, 2019 at 7:20 AM
    Uscgamecock7
    Uscgamecock7 Well-Known Member
    Nick
    West Columbia, SC
    2015 Tacoma Trd Sport DCLB 4x4(SOLD) 2017 Tacoma Trd OR 4x4(SOLD) 2024 T4R TRD PRO
    Why isnt goodyear wrangler duratracs on your list. Ran the ko2s and currently on the duratracs and are by far superior in my opinion.
