Glass break sensor add on???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DTOM TACO, May 1, 2020.
  1. May 10, 2020 at 5:58 AM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Can confirm that PT398-35160 (TVIP V5) is plug and play on 2017 Tacoma. There was no need to enable GBS with tech stream, and hood jumper connector is already installed. My Tacoma has the factory alarm, so this just adds GBS to factory alarm.
    But if you don't have factory alarm it looks like this module will also act as the alarm, and you WILL need tech stream to enable. (But someone else will need to confirm that).
    elaudtr and mattleg like this.
  2. May 10, 2020 at 7:42 AM
    aro
    aro Well-Known Member
    Orange County, CA
    2019 OR DCLB 4X4
    Did you have to do the hood switch dummy connector?
    How difficult was it? In the pdf posted earlier there are things like "plug in the V5 8P white connector", "locate the vehicle's 5P connector", "disconnect the vehicle's 26P connector". How hard is it to identify those? It's a little bit of a maze down there.
  3. May 10, 2020 at 7:57 AM
    mutely
    The hood connector is not a "dummy" connector if you have the factory alarm. So you don't install the jumper that comes with the kit.
    Finding all the connectors is easy, and you can't get it wrong as all connectors are unique. Took about 5 mins to install once you have the dash panels out the way.
    aro[QUOTED] likes this.
  4. May 10, 2020 at 9:29 AM
    aro
    Orange County, CA
    2019 OR DCLB 4X4
    Cool stuff, thx! You gave me the impulse to finally do it. (I have the factory alarm)
  5. Jun 15, 2020 at 2:04 PM
    ChrisIz
    ChrisIz Well-Known Member
    Texas
    2023 TRD Off-road
    I have a 2020, did the install and can't seem to get it to work. I have the sensitivity up to 7 on the module. At first I installed the connector that came with the kit to replace the "dummy". It makes no difference if either of them is installed. My truck does have the factory alarm. Any idea?
  6. Jun 15, 2020 at 5:33 PM
    mutely
    Assuming you are following the testing instructions correctly. What are you tapping the window with? Try tapping the window with something that makes more of a metallic sound, like the end of a screwdriver (the handle end).
  7. Jun 15, 2020 at 5:55 PM
    ChrisIz
    Texas
    2023 TRD Off-road
    I tried my keys, it is on setting 7.
  8. Jun 15, 2020 at 6:33 PM
    mutely
    Your keys? Hopefully not car key as your keyfob needs to be far enough to away for the system NOT to register it, it won’t go off if it’s too close. Try setting it to 12, try something other than keys, install instructions were quite detailed on testing / checking if I remember correctly.
  9. Jun 16, 2020 at 10:22 AM
    Volt
    Volt Well-Known Member
    Overland Park, Kansas
    2022 SR5 4x4 Double Cab V6
    My fourth red Tacoma
    I bought the window stickers off of eBay. I'm a fake.
    TexasWhiteIce likes this.
  10. Jun 16, 2020 at 11:32 AM
    mutely
    people buy those? I think I chucked mine, Now I’ll have to see if I can find them and find a sucker on ebay.:D
    Jc_dabs and TacoPacific like this.
  11. Feb 11, 2021 at 6:22 PM
    Msweetz13
    Msweetz13 Well-Known Member
    Michell
    Parker Colorado
    2017 Inferno Tacoma SR5
    Maxxis Razr 35's Fox 2.5 DSCs BD Everything Evil MFG third brake light & roof bar w/6xLP6s Dual Sp9100s Blaze Built molle panels and dual SP9100 Mounting set up Lil B's Bumper and sliders Tons of other goodies Designing a custom Prerunner style bed cage with through bed shock towers. Designing custom front 18" long travel for 37s, will be cutting out my entire inner fender skirts and relocating all electronics/ items mounted to them.
    I recently had two buddies here in Denver get their glass broken and items were stolen. Apparently, auto theft is up 400%, and break-ins are up 1000% here in the Denver area, so I will definitely be installing this on my truck, just texted my buddy at the dealer to get it ordered!
  12. Aug 1, 2021 at 4:15 PM
    MiTacoTRD
    MiTacoTRD Well-Known Member
    N. Idaho
    2019 Tacoma TRD Off-Road DCSB
    I want.
  13. Aug 1, 2021 at 4:26 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
  14. Aug 2, 2021 at 7:30 PM
    markram
    markram Well-Known Member
    washington, state of
    2020 TRD OR DCSB 4X4 Cement
    few questions for you if you don't mind:
    - did you get your gbs to work in your 2020?
    - was your gbs part number the PT39835160 one?
    - did your truck come with the oem alarm system?
    my 2020 tacoma has the oem alarm and i'm just making sure this gbs will work in it before buying it... thanks for any help!
  15. Aug 2, 2021 at 7:53 PM
    #35
    LRockPro
    LRockPro Well-Known Member
    LRock
    Compustar alarm it can be integrated with ur factory remote. There DAS2 sensor is shock, glass & tilt all in one.
  16. Aug 3, 2021 at 1:17 PM
    #36
    ChrisIz
    Texas
    2023 TRD Off-road
    I got it to work correctly, same exact part number. My truck did come with the factory alarm system. I set the gbs to 7 and tapped the window with my house keys while having the smart key far away from the truck. Make sure that you leave the plug by the hood on if you already have something plugged in to it. Some trucks use the dummy plug there. No techstream was needed.
    markram[QUOTED] likes this.
  17. Aug 3, 2021 at 6:57 PM
    #37
    markram
    awesome, thanks very much! just what i wanted to hear :thumbsup:
  18. Oct 5, 2021 at 9:02 PM
    #38
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
  19. May 26, 2024 at 6:15 PM
    #39
    vp12198
    vp12198 Member
    Frank
    Miami
    23 toyota tacoma SR5
    Stock
    I cant get the gbs to turn on any ideas is on a 2023 taco
  20. Jun 2, 2024 at 9:28 AM
    #40
    ChrisIz
    Texas
    2023 TRD Off-road
    It has no light. What sensitivity did you set the GBS? Smart key has to be away and truck has to be locked. Tap the glass with keys.
