got my billies installed...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by exwrx, Jan 25, 2012.
  1. Jan 25, 2012 at 4:50 PM
    exwrx
    exwrx [OP] Well-Known Member
    Walkerton, ont
    05 Silver DC Taco TRD
    stock
    so i got them installed and got a alignment done today. i have a vibration and i do think its bad enough that more needs to be done to make it better. the vibration was worse before the alignment but it still vibrates and kinda "howls" around 100km/h. the parts installed are billies 5100 f+r, front set at highest setting with stock coils. got a diff lowering kit too (spacer). the rear has a custom ALL that raised the rear about 2.5".
    what kinda parts would fix my vibrations?
    thanks.
  2. Jan 25, 2012 at 4:52 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    carrier bearing drop,
    new UCA's for better alignment
  3. Jan 25, 2012 at 4:54 PM
    lundy
    lundy Well-Known Member
    Justin
    Reno, NV
    2023 Double Cab 4x4
    I hate to say it but you might be joining the club
    http://www.tacomaworld.com/forum/2n...nt-differential-bearing-vibration-thread.html
  4. Jan 25, 2012 at 4:58 PM
    Large
    Large Red
    Remove diff drop.
  5. Jan 25, 2012 at 5:18 PM
    exwrx
    Walkerton, ont
    stock
    alignment was perfect except the casterwasout 1 degree. maxed out at 4.
  6. Jan 25, 2012 at 5:19 PM
    exwrx
    Walkerton, ont
    stock
    why? i thought it was supposed to help...
  7. Jan 25, 2012 at 5:19 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    on 2nd gens, they dont really do anything
  8. Jan 25, 2012 at 5:20 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
  9. Jan 25, 2012 at 5:23 PM
    exwrx
    Walkerton, ont
    stock
    is this the part you meant?
  10. Jan 25, 2012 at 6:39 PM
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    im takin my diff drop out as soon as the weather warms up. after lots of reading ive realized they do more harm then good . the real problem is the cv boot itself and it can be modified
  11. Jan 25, 2012 at 6:48 PM
    ChuckLee
    ChuckLee Well-Known Member
    Richmond, VA
    06 SR5 4x4 DC
    x2
  12. Jan 25, 2012 at 7:35 PM
    bermslider
    bermslider Well-Known Member
    Squampton, BC
    Double Cab 07 TRD Sport
    K&N Air Filter. 17" XD Revolvers wearing Hankook Dynapro ATM's 265/70/17 treads. Bilsteins in the Front set at 1.75". Debadged. Tail lights tinted.
    What did you find about the CV boot and what is the mod that you speak of? I have vibes after a recent lift and haven't seen anything about that? I'm not sure my CV's are the issue though, as they look pretty good to me:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/199308-driveline-vibes.html
    No one was willing to offer any additional advice for me though?
  13. Jan 25, 2012 at 7:49 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    To the OP... put your truck in 4hi while going about 30mph and see if your vibe/howl goes away.. If so... Welcome to the club of bad front diff bearing! :)
    If not, and the vibe is only between 5-20mph then its your drive line... simple axle shim and or Carrier Bearing drop will/should fix it...
    I kept my diff drop in bc it did help my cv angles...
    hope this helps you out, and makes sense.
  14. Jan 28, 2012 at 5:03 PM
    exwrx
    Walkerton, ont
    stock
    i took the front diff spacer out and put some spacers in the carrier bearing (1/2") made it pretty good but still vibrates above 80km/h. it also makes noise when i am going around a curve to the left...
    any other guess's?
  15. Jan 28, 2012 at 5:08 PM
    dad32509
    dad32509 Thinking of something clever
    Dave
    San Diego
    Blacked out 05
    5100's front and back, OME 885x's, LR UCA's, OMD rear springs, Pioneer AVH-P2300DVD, HVAC Green led's MOD, Blacked out bumper, Plastidip emblems, custom front tube bumper, 32" combo led bar, rigid duallys, otrattw switches, my own Satoshi grille, shorty antenna, Spyder LED halo headlights. csjumper2003 map/dome, 3rd brake, DTRL white/amber and parking LED's. Pelfreybilt IFS skid, Cab mount chop, sliders and rear light bar w/blitzpro 5LR dust light. Uniden CB, Magnaflow 18" exhaust, Rear tire carrier, sway bar removed, spidertrax 1.25" spacers, Wheelers 16" Alloys w/265/75r16 Goodyear DuraTracs
    Maybe you got a bad bearing man. Could be as easy as that. When you lift the max on the bills the sway bar can rub against the uca so that could be the noise you hear turning
