Greetings ….. and fluids
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bomberito, Sep 21, 2024.
  1. Sep 21, 2024 at 9:19 AM
    Bomberito
    Bomberito [OP] New Member
    Mario
    2010 Red Tacoma TRD Sport
    Newer model grill
    Hi, I’d like to start by thanking Bob for his warm welcome, as well as Juan and all who may read my note. Preemptive apologies for my gift of making a short story long. Last week I jumped in and bought a used 2010 Tacoma with mileage barely south of 200k. It’s red and gorgeous, ‘twas love at first sight. It has its issues, but so do I. Sadly for me, even buying an old truck like this, represents a major investment. So here I am passing bricks and hoping all goes well. Third day driving, and it may be something in my hands, but the dreaded check engine light comes on. MAS says AutoZone, thanks to YouTube I discover that it can be cleaned, and while at it wiped the throttle body. Had CE light reset but next day light is back on. For variation, O’Reily this time. Gas cap they say, so this time I make the purchase.
    If you’re still with me, couple questions,
    Can check engine light be reset other than disconnecting battery?
    What fluid/oil for differentials?
    How about automatic transmission?
    And the transfer case?
    Thaks in advance for your opinions, Mario
    buckhuntin-tacoma likes this.
  2. Sep 21, 2024 at 10:38 AM
    MGMDesertTaco
    An OBD2 scanner from Amazon will clear it, but if there's an issue it will keep coming back until the issue is resolved. Autozone can do a scan for free, probably clear it too and give you some advice on repairs if needed.
    08885-02506
    Any synthetic 75w-90 GL5 would suffice. I believe the sport trims require the limited slip additive.
    https://www.tacomaworld.com/threads/changing-differential-fluid-a-step-by-step-how-to.24545/
    OEM Toyota ATF W/S or Valvoline Maxlife ATF (Valvoline is cheaper and some claim higher quality)
    75w-90 API GL4/GL5
    08885-02106
    https://www.blauparts.com/ravenol-g...MI_Y3D98nUiAMV9w2tBh0BwDIwEAQYAiABEgL1ZfD_BwE
    The owners manual will tell you what Toyota requires and recommends. Here's a copy if you don't have one.
    https://bobistheoilguy.com/forums/threads/2010-tacoma-fluids.377869/
  3. Sep 21, 2024 at 5:33 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    Bomberito[OP] and Squirt like this.
  4. Sep 21, 2024 at 5:39 PM
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can. AMP Powersteps
    IIRC 2009 and up have electronic LSD so no additive required!
  5. Oct 1, 2024 at 8:03 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  6. Oct 1, 2024 at 8:09 PM
    MGMDesertTaco
    None, but there's several posts and threads advocating the benefits of Valvoline Maxlife over Toyota's WS. (longevity between fluid changes, better heat tolerance, ect.)
    TnShooter likes this.
  7. Oct 1, 2024 at 8:16 PM
    TnShooter
    Deogee
    STOCK
    The most important part is changing it early and often.
    Ideally a drain and fill every 40-45k. Sooner if towing or under harsh conditions.
    Pan drop, magnet, and filter at or before 100k.
    Almost no one services their transmission regularly.
    And Toyota didn't help by making the process overly complicated in order to get the fluid to the correct level.
    Which in turn, makes one procrastinate........Guilty I am.....
