Grind Calipers or wheels?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AZtacoma05, Dec 9, 2010.
  1. Dec 9, 2010 at 9:43 PM
    AZtacoma05
    AZtacoma05 [OP] Well-Known Member
    Austin, TX
    17 DCSB TRD Off Road
    OK.. so long story short I bought new wheels because my new tires were rubbing my LR UCAs and now Im rubbing the caliper (btw 4wheelparts said they would fit fine.. never listening to them again lol). I ground down the inside of one wheel and put my spare 32" to get it home but now I need to get them to clear all the way. The one I ground down i took down probably about 1/8in and it still is rubbing, but only slightly. I'd like some opinions on whether to grind down the wheels more or try to take a little off the caliper. Also does anyone know if taking a little off the wheels is going to cause me any problems? I can't do spacers because I'm running 35s and spacers are only rated to 33s.. Oh and i did see this old thread but I wanted to get some other opinions... Click
    The wheels I got are steel pro comp 17x8 with 4.25" BS and 0 offset (sorry for the crappy cell pics)
    and here's the old fj wheels with the 35s
    and with the new wheels....
    and here's a pic of the inside of the wheel i took of where it rubbed the inside of the D window
    Any help would be great.. thanks guys
  2. Dec 9, 2010 at 9:45 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Honestly, I would sell the wheels and get some soft 8 type wheels (d windows rub, soft 8 style dont).
  3. Dec 9, 2010 at 9:47 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Wait, so you now have 17s and they rub on the calipers with 4.25 backspacing. Somethings not right
  4. Dec 9, 2010 at 9:51 PM
    AZtacoma05
    Austin, TX
    I think it has to do with the offset but that's just a guess.. 4wheelparts said it wouldn't matter but I'm guessing a negative offset would have fixed this..
  5. Dec 9, 2010 at 9:52 PM
    AZtacoma05
    Austin, TX
    even a wheel with the same specs? with 0 offset?
  6. Dec 9, 2010 at 10:19 PM
    AZtacoma05
    Austin, TX
    Would there be any problem with grinding the wheels? I have to try to this in the morning so i can actually drive! thanks!
  7. Dec 9, 2010 at 10:22 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    never grind steel wheels, they are MUCH more thinner than alloys....DO NOT grind steel wheels... and I would NEVER recommend grinding calipers...buy wheel spacers
  8. Dec 9, 2010 at 10:23 PM
    cactuscorn
    cactuscorn Another FNG
    El Paso, TX
    2016 BBR TRD OR AT DCLB w/JBL
    OEM bedmat, Weather Tech mats, JDM ASTAR 800 lumen LED reverse bulbs, blue LED dome light and every cubbyhole filled with crap.
    send em back. you may have to eat the 1 ya filed down... 1/8". just how thick is that steel anyway? holy broken wheel batman!
  9. Dec 9, 2010 at 10:25 PM
    cactuscorn
    El Paso, TX
    yes
    no
  10. Dec 9, 2010 at 10:34 PM
    AZtacoma05
    Austin, TX
    The main problem is there's a lip around the inside of the D window that's pretty thick.. the part where I ground it down didn't even get close to the outside surface. I guess I'll call 4wheelparts in the morning and see what they'll do..
  11. Dec 9, 2010 at 10:36 PM
    AZtacoma05
    Austin, TX
    I would do spacers but spacers can only be use on wheels up to 33" and I've got 35's... Guess ill call 4wheelparts in the morning
  12. Dec 9, 2010 at 10:37 PM
    mach1man001
    mach1man001 eh whatever
    Rob
    Blackstone, MA
    '09 Sport DCLB Met Grey
    Toyota bed mat (1st mod), Toyota all season floor mats, Rear spring TSB, Map light mod, Fog light mod, Putco yellow fog bulbs, Weather Tech window vents, Extra d-rings, Mounted mag light, TRD CAI with AFE pro dry filter, '05 front mud flaps (winter only), 2 set's of wheels/tires, 285/75/16 Hankook MT's, Black Painted 1st Gen TRD wheels (wheeling set) Black powder coated FJ Cruiser with 265/70/17 BFGoodrich KO2's (everyday), painted center of grill & bumper black, Devil horns, OME with 885's + spacers front, OME shocks w/OMD designed rear springs, Front diff drop, Rear trailer plug relocate, ATO IFS skid, Relentless Trans & Transfer skids, BAMF bolt on rock sliders, Relentless tailgate reinforcement, Uniden 75 CB radio, BAMF antenna bracket, TRD exhaust, high lift jack w/ATO mounts. And of course ProEFX Towing Mirrors!
    What are you doing with the FJ wheels?
  13. Dec 9, 2010 at 10:39 PM
    cactuscorn
    El Paso, TX
    ok, i get it. unfortunately that lip is critical structure and gives the wheel rigidity. yer still hosed pal. got yer fj wheels and tires, right? time to put em back on. good luck with yer call.
  14. Dec 9, 2010 at 10:39 PM
    AZtacoma05
    Austin, TX
    selling them... they're painted matte black... I sandblasted them before painting them..
  15. Dec 9, 2010 at 10:42 PM
    AZtacoma05
    Austin, TX
    Ya thats what I was worried about : / well hopefully since they told me the offset wouldnt matter I can get some credit for some new wheels..
  16. Dec 9, 2010 at 10:48 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    yea, you better get back there asap and hopefully they won't give you a hard time. best of luck and i liked the fj wheels better on your truck.
  17. Dec 9, 2010 at 10:58 PM
    cactuscorn
    El Paso, TX
    agreed. not sure i understand the draw to steel wheels over alloy. feel free to clue me in.
  18. Dec 9, 2010 at 11:04 PM
    AZtacoma05
    Austin, TX
    Y I liked em better too :frusty: .. especilly after all the work i put into them! sadly with the new tires they rubbed on the UCAs.. i went with the steel wheels because they were the cheapest and I didn't foresee the problem with the fj wheels when I went the 35's :(
  19. Dec 9, 2010 at 11:13 PM
    AZtacoma05
    Austin, TX
    am I wrong about the wheel spacers? I don't remember where I read it but I thought I heard that spacers were only for tires up to 33s? if not I can run the fj wheels with some spacers...
  20. Dec 9, 2010 at 11:16 PM
    cactuscorn
    El Paso, TX
    just keep tellin yerself, "bigger is better!" i have half a mind to make ya write it on the chalkboard till yer fingers bleed and ya give up on the idea. ill be in town at krismiss to take those fj's off yer hands for all the friendly advice ive provided. you can keep the mondo tires
