Has anyone been able to swap the "next song" button with "higher volume"?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by siniquezu, Jan 29, 2023.
  1. Jan 31, 2023 at 7:36 PM
    #61
    Grimble27
    Grimble27 Well-Known Member
    Washington
    '23 White Tacoma TRD OR
    True. I’ve gotten used to it mostly, until I go drive my wife’s car and then start all over.
    Now putting the push start button right next to the 4wd selector knob is a different story. I push the 4wd knob every.single.time I start my Tacoma still.
    Buggin112 and virginiamarine like this.
  2. Jan 31, 2023 at 7:38 PM
    #62
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    I’ve been able to swap them in my brain. When my wife plays a song I like, now I say “turn it forward!”
    Deacon Blues and DES2009 like this.
  3. Jan 31, 2023 at 7:40 PM
    #63
    CaptSourPatch
    CaptSourPatch Well-Known Member
    PNW
    2023 Lunar Rock TRD OR
    Stock. For now.
    Just bought a ‘23 Tacoma. The steering wheel controls are not intuitive AT ALL! I haven’t done any mods yet outside of some led inserts for the bed. If Meso Customs is coming up with a solution to this, I’d definitely be on board.
    virginiamarine likes this.
  4. Jan 31, 2023 at 7:53 PM
    #64
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    if thats the case it might be as simple as moving some resistors around. Curious why meso made a PCB then, maybe to get the labels right?
  5. Jan 31, 2023 at 7:56 PM
    #65
    bockafer
    bockafer Well-Known Member
    Earth
    22 Limited 4x4 MGM
    New button overlay and resoldering small surface mount resisters isn't in a lot of people's wheelhouse.
    musicisevil likes this.
  6. Jan 31, 2023 at 8:02 PM
    #66
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Here’s the post with pics of both sides.
    Interestingly the wiring harnesses look to be different
    0xDEADBEEF[QUOTED] likes this.
  7. Feb 1, 2023 at 3:29 AM
    #67
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Nope. This schematic was posted by @ktbell444 in an older thread.
  8. Feb 1, 2023 at 7:03 AM
    #68
    Silver-Taco1
    Silver-Taco1 Well-Known Member
  9. Feb 1, 2023 at 8:22 AM
    #69
    0xDEADBEEF
    Ahh interesting. Definitely more complicated, would need some careful analysis to modify it. I think what I didn't take into account in my original post was the LED backlights.
  10. Feb 1, 2023 at 10:20 AM
    #70
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    I just adapted to the change. After a few mistakes of skipping past a song that i wanted to hear LOUDER my brain rewired and i learned to just reach over and adjust the volume knob on the head unit.
    I found my path of least resistance and moved on.
    petethemeat likes this.
  11. Feb 1, 2023 at 10:26 AM
    #71
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    If that's how it's set up, then you'd probably need to swap resistors around on the PCB to alter how it reads the buttons. Odds are the values or R2, R3, and R4 are all different so that the system determines which button is pushed based on the net impedance when each switch is closed, or the variation in the voltage in the output line. If R2, R3, and R4 are all essentially in series and how many engage depends on which button is activated, then it would be extremely difficult to modify that configuration without altering/replacing the PCB unit itself.
    The question then might be whether the "decoder" circuit is in the HU itself, or if this design is used just to allow those controls to use only 3 wires in the "clockspring" rather than 9. If there's a processor unit somewhere in the dash which feeds the wheel control signal to the HU harness via multiple hot/cold wires rather than a variable voltage multiplexed signal then it would still be possible to cross-splice those wires.
    If the 3-wire run connects all the way to the head unit, then the best option might be just to see if a button unit (PCB and all) with the desired configuration could swap into the wheel of the vehicle you're looking to modify.
  12. Feb 1, 2023 at 11:12 AM
    #72
    ljh824
    ljh824 Regular Guy
    Lou
    Kabul, Afghanistan / Oviedo, Florida
    -21 AG Sport 4x4 DC
    many threads on this. i hate it, had my truck two years now and still hit the wrong button occasionally. Hard wired in from what I can tell. Took the steering wheel off thinking I could just turn the whole thing a quarter turn counterclockwise. no luck. someone will have to build something to change it. I'm not smart enough.
  13. Feb 1, 2023 at 12:44 PM
    #73
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    i think you are making it more complicated than necessary.
    i'd use an exacto knife to cut traces as necessary. then add new traces using something like this (maybe scuffing with exacto for good adhesion):
    https://www.amazon.com/Circuit-Scribe-Non-Toxic-Conductive-Silver/dp/B00OZATJ3A/?th=1
    then mask the pad landings and spray a sealer on the board.
    in another thread a guy even made it easy: (post #147)
    https://www.tacomaworld.com/threads...everse-toggle-on-steering-wheel.558265/page-8
    if the 4 button piece can be rotated 90 degrees, you are done. if not, might have to relabel the buttons somehow (or live with it).
    i am just hunting and pecking at the many threads (i don't really care about this) and have no first hand knowledge, but unless i am way off, this is not hard.
    maybe my rambling will help someone.
    edit: another trace creation option, instead of the pen, might be copper foil tape commonly used in stained glass work, etc.
    that stuff can be soldered easily with a swipe of some steel wool to remove oxide layer, a dab of flux and a soldering iron hot enough
    to get it done without vaporizing the foil.
    i have used similar for EMI shielding in the past and it is pretty nice to work with.
    might have to hunt around for maybe 1/16" width but probably exists. or could cut 1/8" easily obtained.
    bmgreene[QUOTED] likes this.
  14. Feb 1, 2023 at 1:45 PM
    #74
    we_want_tacos
    we_want_tacos Well-Known Member
  15. Feb 1, 2023 at 1:48 PM
    #75
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Same here, I've been turning the volume UP and DOWN and skipping songs NEXT and BACK for 8 months now. It is now correct, and is the way it should have come from the factory. The factory layout is a stupid design, no matter how many people go to bat for it.
    When someone complains about how loud something is, they never ask for it to be turned left.
  16. Feb 1, 2023 at 1:55 PM
    #76
    Tacospike
    Two Trucks
    No wonder I was used to it in my tundra. Volume is separate lol
    but also adapted to the Tacoma functions
    Superdave1.0 and doublethebass like this.
  17. Feb 1, 2023 at 2:20 PM
    #77
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I though eye to hand coordination is the same as American pie thingy.
  18. Feb 1, 2023 at 4:09 PM
    #78
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    No. That's not possible. Look at the diagram in post#68. There are 3 wires to the HU from the steering wheel switches for volume and select. The head unit measures resistance (or voltage) depending on which button is pressed.
  19. Feb 1, 2023 at 6:31 PM
    #79
    LickyBeaverz
    LickyBeaverz Active Member
    Leesburg, VA
    2022 AG Tacoma TRD Sport
    KDmax Pro9.0 ECU tune w/ "normal" throttle, 17x8.5 Fuel wheels, 32" Falken Wildpeak AT3's, S&B CAI, tonneau cover, PCV catch can, hood deflector, clown head tow ball cover..
    The resister ladder design hypothetically allows the design to use the same resistor value for all the resistors, minimizing the number of unique parts on the board parts list. Each button closure runs through a different number of resistors and they sum together. It's also slightly less copper trace runs this way. So typically can't even swap resistors in these designs.
  20. Feb 1, 2023 at 6:37 PM
    #80
    Vlady
    Issy, WA
    How do you think blind people get around?
    Toyota already put a clue on those buttons.
    DWD484 likes this.
