Has anyone else experienced this?
Discussion in 'Suspension' started by TacoSteve612, Apr 19, 2013.
  1. Apr 19, 2013 at 3:11 PM
    TacoSteve612
    TacoSteve612 [OP] Active Member
    Bel Air, MD
    2012 Tacoma TRD 4x4
    2 inch lift Volant intake
    I ordered 1.5 inch steel rear lift blocks and U bolts from fatbobsgarage and just opened the box to find aluminum blocks instead. The blocks are also angled slightly being1 1/2 inches on one side and 1 3/16 on the other side. Anyone buy from this site before and have this happen? The dealership I bought my truck from recommended this site becuz apparently that's where they buy lift kits from when customers want a lift. Any help is appreciated. Thanks guys
  2. Apr 19, 2013 at 3:16 PM
    Large
    Large Red
    Those sound like badass blocks.. they are angled to rid vibes is my only guess..
  3. Apr 19, 2013 at 3:19 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
  4. Apr 19, 2013 at 3:33 PM
    TacoSteve612
    Bel Air, MD
    2012 Tacoma TRD 4x4
    The reason y got blocks instead of an aal is becuz every site says 1.5-2 inch lift. I have 2 inch blocks up front and wanted an exact number lol so I got 1.5 inch blocks for the rear. How much of a lift did those aal get u?
  5. Apr 19, 2013 at 3:53 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I got roughly about 2" of lift in the rear unloaded. The benefit of a leaf over block is that your load capabilities will increase. Say you fill your bed up with a good amount of weight with a block, you will bottom out, where as with a leaf, you will have more travel.
  6. Apr 19, 2013 at 4:38 PM
    TacoSteve612
    Bel Air, MD
    2012 Tacoma TRD 4x4
    Thanks for the info. I don't intend to load up the bed with heavy items. I mainly haul light items and it took me a while to finally decide on a block instead of a leaf. I wanted the steel block but they sent an aluminum block instead...I might just say screw it and just use the ones they sent
  7. Apr 24, 2013 at 10:01 AM
    Jkohler
    Jkohler HUH?
    Justin
    UT
    02 4DR Taco TDR Supercharged SR5 6in lift
    12" Icon 2.5 coilovers, 6" Drop Bracket, Tuff Country 5" lift knuckles, Icon 4''-8'' Extended Coilovers, Light Racing upper control arms, 7" Alcan leafs, 13" icon 2.0 smooth bodies in the rear. 2.5" exhaust with Magnaflow cats and Thrush muffler. 295x75x16 AT's (34.4") Superchargers Other shit like rear breather mod relocate, gray wire mod, intake elbow removed, led's, toolbox, etc
    The block is angled slightly to keep your axle at the correct angle. It should be angling slightly up towards your xfer case.
  8. Apr 24, 2013 at 1:54 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    I think the aluminum blocks are better. Won't rust and probably cost more to make.
    If you want to use blocks and not a AAL then use the ones you got. Nothing wrong with an aluminum block plus the angle will help drive line vibrations and may increase the life of your u-joints.
  9. May 6, 2013 at 2:31 PM
    TacoSteve612
    Bel Air, MD
    2012 Tacoma TRD 4x4
    Sorry for such a late reply. Thanks for ur input guys its appreciated! I'm not too impressed with the rear blocks :/ they just cause unwanted stress on the leaf springs and now I really wanna take them out and put a 2 inch AAL in there lol. I didn't wanna mess with unbolting the leafs while only using jack stands but I guess its just gonna be the best way to go...should have listened to everyone lol.
  10. May 6, 2013 at 3:59 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    What kind of problem are you having with the blocks? There really should be no issues if installed correctly.
    As far as an add-a-leaf goes, there is no need to remove the whole leaf pack from the vehicle. Just need to jack it up and support the frame with jackstands.
  11. May 6, 2013 at 4:09 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Sherpa Grand Teton/Crows nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights
    Another problem many people experience with blocks is axle wrap... won't get that with aal's.
  12. May 6, 2013 at 4:13 PM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    False.... I have a Toytec aal and i get axle wrap.... but im running URD Stage 3 :D
  13. May 6, 2013 at 8:52 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I still have my AAL's for sale if you are interested
  14. May 8, 2013 at 2:33 PM
    TacoSteve612
    Bel Air, MD
    2012 Tacoma TRD 4x4
    Texoma, how much do u want for ur aal? And are they 2 inch lift asl? The only issue I'm having is since the leafs are sitting directly on the blocks, the leafs are being pushed against at the center and are bowing instead of being arched like they were without any lift. I don't like seeing that becuz I figure they will weaken or maybe even break under stress with a load
  15. May 8, 2013 at 2:35 PM
    TacoSteve612
    Bel Air, MD
    2012 Tacoma TRD 4x4
    I'm guessing the axle warp is due to the blocks not being perfectly center as if the leafs were just sitting on the axle. Yet another reason y I want aal. When I got my alignment done they told me my axle was shifted but not much
  16. May 8, 2013 at 5:24 PM
    Jkohler
    Jkohler HUH?
    Justin
    UT
    You can get axle wrap from any lifted vehicle due to the changed driveshaft/axle angle, increased ride height, bigger tires, or increased amount of power being put out. If you want to stop this, get traction bars! They have hiem joints on both ends and bolt on your axle and up to the frame allowing for movement but not axle wrap! :)
  17. May 8, 2013 at 7:47 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I have them listed in my sale thread below for $45 plus shipping. If we can get this worked out right, I am heading to Chesapeake,VA on Friday and maybe able to meet you. And yes they are 2" and the link to where I originally bought them is in my sale thread as well.
  18. May 9, 2013 at 5:01 AM
    Jkohler
    Jkohler HUH?
    Justin
    UT
    Also should note, there was a major recall on tacoma springs for busting in half. Not sure what years it was exactly. Might be worth while to replace the entire pack.
    I have an 02 and haven't had any issuers my cousin has a 2000 and he has had the second to bottom leaf on both packs break right in half!
  19. May 11, 2013 at 5:56 PM
    DevL
    DevL Well-Known Member
    I'm confused. A proper lift block will be the exact same shape width and length of your axle's spring mount. If it is shifted fore/aft its an axle relocation plate. This would not be a big deal because those only move the axle a fraction of an inch rearward but are still the same shape. If you have aluminum blocks that are also relocation plates and integrated blocks with integrated shims that is very impressive and I am jealous.
