Have a problem.. need help
Discussion in 'Suspension' started by jwj202, Jun 20, 2012.
  1. Jun 20, 2012 at 10:00 PM
    jwj202
    jwj202 [OP] Well-Known Member
    Joey
    Mississippi
    '10 silver TRD Offroad SR5
    recently i have noticed a lot of squeek in my suspension somehwere. everytime i hit the brakes and the cab moves it squeeks like a mf. if i get out of the car it also squeeks. so im almost positive it is part of the suspension. Has anybody had this problem or know anything about it. I have the stock TRD offroad shocks and the non tsb leafs. Thanks!
  2. Jun 21, 2012 at 6:13 AM
    Large
    Large Red
    Leaf packs.
  3. Jun 21, 2012 at 9:47 PM
    jwj202
    Joey
    Mississippi
    do i have to replace all the leafs or is there a simpler solution?
  4. Jun 25, 2012 at 12:12 PM
    billyrayaf
    billyrayaf Well-Known Member
    billy
    waynesville,nc
    silver 09 SR5
    6in tuff country, 3.0 king coilovers, crown 7+ brake lines,LR UCA
    check the bushings in the leafs springs they might need to be lubed
  5. Jun 25, 2012 at 12:18 PM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    Also, torque the axle U-bolts to 73 lb/ft. That might fix it.
  6. Jun 25, 2012 at 12:20 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
  7. Jun 27, 2012 at 7:39 AM
    DevL
    DevL Well-Known Member
    90% odds its the clamps on your leaf springs... rubbing the inside of clamp with outside of leaf. Use spray lithium grease. Pump rear of truck up and down with body weight. Problem solved.
