Having second thoughts about doing a OME lift
Discussion in 'Suspension' started by BenWA, Aug 28, 2010.
  1. Aug 28, 2010 at 1:25 PM
    BenWA
    BenWA [OP] Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    My plan was to get the full OME 3" front and rear kit with AAL, 1.25" wheel spacers, or a full set of 5100's with AAL and run BFG KM2 285/75/16's on my stock wheels. But now I am having second thoughts about lifting at all due to all the potential issues I keep hearing about.
    Pros:
    -looks badass
    -obviously better for wheeling
    Cons:
    -a lot of $$$ that could truthfully be better spent on more important things
    -potential drift/alignment issues without UCA's
    -screws up VSC (potentially dangerous?)
    -screws up speedometer/odometer calibration (annoying)
    -potential unwanted vibrations/added highway noise
    -stresses CV's
    -reduced fuel economy
    I'm definitely on a budget and don't have extra cash to start fixing potential secondary problems that may arise, such as investing in expensive UCA's, paying someone to recalibrate the VSC, etc. And since i only plan on doing maybe 4 or 5 wheeling trips a year, I'd say the lift would honestly be more for looks than function.
    Thus I'm having trouble justifying spending $1500 on lift, wheel spacers, and tires for something that's gonna end up riding and performing worse than stock, for the sake of it looking cool.
    So here's you chance to talk me into or out of pulling the trigger and going through with it. :)
  2. Aug 28, 2010 at 1:49 PM
    barlowrs
    barlowrs Well-Known Member
    Robert
    So Cal
    06 Toyota Tacoma Sport 4x4
    Build Thread: http://www.tacomaworld.com/forum/builds/74926-barlowrs-06-taco-expo-build-thread.html OME Lift, FJ SE Wheels, 255/85 KM2, Allpro Plate Bumper, 8K Winch, Synthetic Line, Yaesu FT-8800R, Custom Sliders Sockmonkey bedside decals, BHLM, base model grille, TRD offroad (black) trim
    I run a full OME setup:
    Alignment Issues: My truck aligns perfectly with stock UCA
    VSS: Not sure, dont have it
    Speedometer/Odeometer: SPeedo will be abotu 5 mph off at highway speeds, no big deal, never bothered me as I dont "drive by speedo" anyway, i go flow of traffic. The Odometer actually works in your favor, it will say less miles than you actually drove, so if you sell your truck, it will look like less miles than you actually drive..haha
    Vibs and Noise: I am runnign 255/85 KM2 MT...they are actually VERY quiet and no vibs that I notice. It is also my daily driver, so I am running highway speeds all the time.
    CV: So far so good
    Fuel: I am actually getting the exact same fuel as I was pre lift, though my truck is an odd ball (always gotten bad milage from the day I rolled her off the lot). I get about 15mpg......this is a downside that cannot be overlooked, however if you were worried about fuel, you shouldnt have gotten one of these trucks in the first place.
    all that being said, if its just for looks, save your cash
  3. Aug 29, 2010 at 11:26 AM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    Its your money, so dont do it if you dont want to. I have the ome lift also and nothing is different at all.
    Alignment: no probs there, wandering a little but if you just want a truck to look good put some rims on it and leave it stock. The 3 inch lift works awesome offroad. vsc dont know, dont have it.
    Tires: mine ar 265 nitto terra and not too much noise unless I go up around 75 and to me it sounds good.
    Speedo: about two mph off around 35 but never been pulled over so far at highway speeds so dont know.
  4. Aug 29, 2010 at 11:28 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    If I had to do it over again... I would have jumped right to the RCD kit or not lifted at all
  5. Aug 29, 2010 at 11:31 AM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Yea the vibes can be fixed with axle shims,or carrier bearing drop. Diff drop will help you cv axles. If you dont like you mileage with 285s, regear to 4.11 or something close. I think the vsc is only affected on lifts with drop bracket setups. OME complete kit will run you around 1K to 1500k with new UCA its not that much. You can run wheel spacers if you rub. If you wanna stay low go with 2.25" readylift or 5100s and 265s. Just my .02
  6. Aug 29, 2010 at 1:13 PM
    toycar18
    toycar18 Well-Known Member
    Colorado
    98 Reg Cab 2.7L
    OME Suspension, BFG 33x10.50 AT, Light Racing Upper Control Arms, Rear ARB Air Locker, LCE Header, Dynomax Super Turbo Muffler, K&N Intake
    The ride quality is much better than the stock suspension. No comparison what so ever. Stock suspension is junk!
    I wouldn't get a full 3" kit if you are worried about cv angles alignment, etc. OME lifts are around 2-2.5". OME designs there suspension systems so other modifications are not necessary. If you select the correct components - especially the correct front coils you shouldn't have any other problems.
    Everything you need:
    http://www.trdparts4u.com/scripts/prodView.asp?idproduct=-8415
    1. Wandering - if any, will only be at highway speeds. If it does it will be very minimal and you won't notice it after a month. Low caster (the result from lifting the vehicle) will only effect wandering and not tire wear. I wouldn't worry about this. OME lifts are mild.
    2. Screws up Vsc - no it doesn't
    3. screws up odometer/speedometer - depends on what your previous tire size was. Assuming your tires are 265/70/16 it will be very minimal.
    from the tire calculator
    4. potential unwanted vibes/highway noise - If you stick to OME recommendations and don't go with a full 3" you won't have vibes. If you go with a full 3" it is possible. You might have a tiny bit of highway noise from larger tires but will be very minimal. After a few weeks you won't notice it.
    5. CVs - OME lifts don't make the cv angles too extreme so you will be fine
    6. reduced fuel economy - depends on the gears your truck has and how you drive. If you have a V6 you probably won't notice any change unless you drive fast.
    I would highly recommend replacing the rear leaf springs. You will be happy you did.
    I really don't see the CONS like you do. The ride quality and performance is a huge improvement over stock.
  7. Aug 29, 2010 at 5:42 PM
    SampleFool
    Ga
    Silver
    08 off-road
    Thats weird because mine speedo is faster than actual speed.
  8. Sep 10, 2010 at 10:33 AM
    wilsonpj
    wilsonpj Well-Known Member
    Pete
    Charleston, South Carolina
    2006 DC, SB, OR
    OME 3in Lift, LR UCA's, 33in DuraTracs, All-Pro Full Skids, TRD CAI & Cat Back, 16x8 KMC Enduros
    any calculation on miles for the odometer?
  9. Sep 10, 2010 at 5:54 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    just got an ome lift on at about 3.5 inches, no ucas and she drives perfectly straight on the highway no wobble at all.
  10. Sep 14, 2010 at 9:33 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Hey man; I was in the same place last week.
    First, I was worried about lift interacting with VSC -- the salesman at 4 Wheel Part$ actually *refused* to lift my truck because they'd had to reverse a couple lifts on 2010 tacomas "with the ABS on the passenger side."
    So, I was spooked about that and started this poll:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/112351-vsc-lift-interaction-how-common.html
    Now, after that, I figured I was willing to take a chance with 5-to-1 odds in my favor. And I also figured out that I'm a pretty old, stodgy, conservative, and defensive driver. And I've been driving wheels *without* VSC all my life. So VSC is just a "nice-to-have" add-on. And I'd *rather* have the off-road capable suspension than the VSC, so if I *do* get the unlikely problem I'd rather disable the VSC - and I'm confident I have the knowledge and skills to design (with some help) a simple circuit that will automatically disable VSC every time the vehicle starts up, just as the driver can *already* do by simply pressing and holding the VSC-disable button for three seconds.
    Les Schwab was willing to do the Revtek lift after talking directly with Revtek about my truck. But, you know, I wasn't sure a 3" spacer lift was what I wanted. Like you I was concerned about ride and I didn't want to put on an "off road" suspension that was so jarring that I'd actually have to drive *slower* on rough washboarded roads than I would with the stocker.
    I talked to Ben at Redline Motorsports in Burlingame. He gave me some good input and some prices, and if I were going to have the thing installed, I'd probably have had him do the work.
    Anyhow, I did a lot more searching on the web, designed a suspension "on paper" and solicited thoughts on a thread here
    http://www.tacomaworld.com/forum/suspension/112718-will-setup-meet-my-needs.html
    ...and a similar thread over over at TTORA. (I won't link to it - but you can find it easy enough if you look, I use the same handle 'bjmoose' over there) Nobody replied here but I got a lively discussion over at TTORA that really helped clarify my thinking.
    Like you, I'm willing to spend my hard earned sheckels on stuff that I'll use, but I don't like to *waste* them. And my lift plans kept going more, more, better, better.
    Now the funny (actually logical) thing about lifting is the higher you go, the more changes you have to make from stock, because the more interactions there are between interconnected systems. So there's a lot to be said for KISS - Keep It Simple Stupid.
    More lift - more likelihood of driveline vibration gremlins because the angles get more extreme.
    More lift - more likihood of VSC gremlins because the Yaw sensor is higher off the ground, and also it becomes oriented at a different angle if you do a "levelling" lift.
    Front end lift past about 2" - more stress on the front CV joints. May need to do a diff drop. May need to replace CV boots much more often.
    Front end lift past about 2" (maybe 2.5) - can't align exactly to factory specs anymore without replacing upper-control-arms.
    Bigger tires - more cutting -- unless you're going for the "pavement queen" approach. But what's the point in an off-road suspension that's actually LESS capable off road???
    More rear-end drop - new brake lines in back. Replace and bleed the system.
    etc...
    And, the pros don't like solving those problems any more than you and I do. They want to bolt it up according to the simple instructions, collect your check, and send you on your way.
    I'm pretty handy - the watershed for me was - the right lift for me is the one I could bolt up myself. The whole point is to go OFF ROAD far from where you can call AAA if you break down, right? So self sufficiency is key, and if I bolt it up myself, I've got a leg up on the game if I hit something and break down on the trail. And then, I'm only paying for parts, not pro labor at $100/hr shop rate. So the cost comes down too.
    Conversely, if it is too complex for me to do it, well then, I didn't trust anyone else to be wrenching on my brand new truck doing that same stuff either. (Ask me sometime about the multi-thousand-dollar-car-stereo-installation-gone-wrong, but that's a story for another day...)
    So, with that in mind, I came down to a choice of either:
    Bilstein 5100s all around (set at 1.85, NOT 2.5 in the front) with a simple Add-A-Leaf in the back OR
    OME complete suspension (885 coils, Dakar Leaf packs, + OME shocks) all around but with no additional lift spacers (except the left/right trim pack on the heavier drivers side.)
    I decided on the OME path and ordered it up from Wheelers Off Road yesterday -- but a LOT of people on TacomaWorld are happy with their billies! Billies and 265/75R16 adds clearance and makes for a more capable off road rig. With the right wheels, it stands out visually -- it's a look that doesn't scream "lift" but looks more like a stock rig that's been hittin' the weight room, IMO. Search for photo threads.
    Hope this helps. Your time, your money, your decision. But my two cent summary is: "Remember, keep it simple. more is not better."
  11. Sep 14, 2010 at 9:48 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    I ran OME 885's with bilstein 5100's and diff drop on the front. the rear was a toytec AAL and bilstein rears. The tires were 285/70/17's. My alignment was near perfect and I had zero issues. A once piece drive shaft may alleviate your vibration issues, depending on the culprit.
  12. Sep 14, 2010 at 9:55 AM
    wilsonpj
    Pete
    2006 DC, SB, OR
    OME kit FTW! I did an AAL and think the ride is just fine. No need to for the top plate spacers.
  13. Sep 14, 2010 at 9:57 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Kit includes....
    1 SET OME2885 FR COILS
    2 90000 NitroCharger Sport front struts
    2 OME N182 REAR SHOCKS
    1 FK29 DriveShaft SPACER
    4 OMEU53A U-BOLTS
    4 90389-A0003 TOYOTA BUSHINGS
    2 CS047R REAR LEAFS Please call or email us to make
    That spacer might help with vibes.
  14. Sep 14, 2010 at 10:00 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    on these forums, i bet i have the mildest lift. i went with the full OME with 884 springs and the 1.5" aal in back, set under NON tsb springs. i got 2" up front and a true 1.5" in the back. i am running stock rubber/wheels. 265/70's. i have the tiniest vibe in the rear..that i think is maybe a joint going south. my truck has settled 1.25" from the day i installed the kit. i had the alignment done right away, and they got it close. caster was out of spec, but my truck never wandered. i bet now that it is settled, i should go and get it realigned. i bet they can get it closer. it still doesnt wander.
    would i do it again? probably not. with my very mild lift, i am gaining so little..i could leave it alone and still be happy. why did i do it in the first place? i took my truck hunting and had to so some wheeling. my tires rubbed my fenders hard on some stuff. i figured a different line up that hill could have saved my rubbing. i love my truck. i will go up that same hill in january. i cant wait to see if it helped.
    ride quality is the same as stock. not better or worse.
  15. Oct 28, 2010 at 9:43 AM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    I am not a fan of a full ome setup. I have the 885's mounted on the ome nitro sport 9000's and it rides harder than any one ton I have ever ridden in. I want to go with the RCD lift but it costs more than my budget allows.
  16. Oct 28, 2010 at 9:48 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    My OME front on 885's runs softer than i'd like actually. :cool:
  17. Oct 28, 2010 at 10:02 AM
    CopDoctor
    CopDoctor Well-Known Member
    Trinidad, CO
    2018 Quicksand TRD Off-Road
    i'm running full OME and 885 coils. only vibes i get are from the tires coming un-balanced. other than that, no issues.
    bottom line, you know damn well if you don't do it now, you'll do it later. don't kid yourself.
  18. Oct 28, 2010 at 11:03 AM
    Kdawwwg
    Kdawwwg Well-Known Member
    Ken
    Draper,Utah
    2010 Magnetic Grey DC Long Bed TRD Sport 4x4
    RCD 4.5" Lift ,Moded to 5.5",1.5 inch Toytec AAL Light Raceing UCA's, 285/70/17 Duratracks, Procomp 7028 Wheels 17X8.5x4.75, Leer XQ Shell,Keyless Entry,Bedrug, Kartec Front End Limiting Straps.
    im sure that massive 500 pound bumper helps smooth it out :D
    just kidding i know its only little over 100 lbs,with out a winch,nice fab work by the way :headbang:
    all i can say on these 3 in lifts ,don't do it,go 2 inch max ,or go drop bracket RCD,procrap,fabtec,
    you don't need ome for a 2inch, get a spacer[ride on a 2inch spacer will be ok,its the 3in spacers that bite],or 5100 ,an a aal ,$300$500 bucks ,max
    or ill sell ya my old 3inch kit complete for $150
  19. Oct 28, 2010 at 12:08 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    you sure your truck has vsc? cause if you dont you can scratch that off your list
  20. Oct 28, 2010 at 12:21 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    886 with the older n140 struts.
    Worth every penny. Truck rides like a dream now. If you don't have the money though, just wait.
