Having trouble removing adhesive imprint..............
Discussion in '2nd Gen. Tacomas (2005-2015)' started by surfsupl, Nov 8, 2009.
  1. Nov 8, 2009 at 7:27 PM
    surfsupl
    surfsupl [OP] Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    How do I get rid of this? (see pic)...............I 1st used goof-off, then later on tried a scratch remover, and then rubbing compound.....all my other badges came off just fine w/out leaving anything....for those who have done this mod,what can I use to remove this?....
  2. Nov 8, 2009 at 7:34 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    Are you sure that it is sticky leftover not faded paint. just start off simple first.
  3. Nov 8, 2009 at 7:36 PM
    surfsupl
    Gregg
    WestCoast
    That ran across my mind.................the faded paint............thats sucks if thats the end result...............all my other emblems did not leave a mark on the truck...........
  4. Nov 8, 2009 at 7:38 PM
    surfsupl
    Gregg
    WestCoast
    im not a pro so hope someone knows exactly.......thats why I'm asking as well...........
  5. Nov 8, 2009 at 7:38 PM
    topgun155
    Zack
    Richmond, TX
    2018 F-150 5.0
    Does that side of your truck recieve more sun light than the others. Think about where you park regularly. Also try rubbing compound or clay bar.
  6. Nov 8, 2009 at 7:40 PM
    surfsupl
    Gregg
    WestCoast
    rubbing compound yes.............clay bar no..............I might go to a detailing shop and pick their brain...........
  7. Nov 8, 2009 at 7:45 PM
    topgun155
    Zack
    Richmond, TX
    2018 F-150 5.0
    That would probably be a good idea. Also there is an official detailing thread. That guy knows his stuff you will just have to wait for his response.
  8. Nov 8, 2009 at 7:47 PM
    surfsupl
    Gregg
    WestCoast
    well @ least if it does not come off I know exactly where to put my new one...........:)
  9. Nov 8, 2009 at 7:52 PM
    topgun155
    Zack
    Richmond, TX
    2018 F-150 5.0
  10. Nov 8, 2009 at 7:56 PM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    I used a claybar
  11. Nov 8, 2009 at 8:02 PM
    cwrose
    cwrose Don't spreadsheet this...
    Fairbanks, AK
    2023 Tacoma TRD OR DCSB in MGM
    I know this isn't constructive, but that was the exact thought that ran through my mind after reading the first few posts. :D
  12. Nov 8, 2009 at 8:06 PM
    surfsupl
    Gregg
    WestCoast
    Thats the 1st thought that ran through my mind as I was attempting to remove it the 2nd time..............
  13. Nov 8, 2009 at 8:06 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    You try a heat gun if it is the adhesive from the decal?
  14. Nov 8, 2009 at 8:08 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
  15. Nov 8, 2009 at 8:09 PM
    topgun155
    Zack
    Richmond, TX
    2018 F-150 5.0
    Hold up there. A heat gun can and will burn the paint. Also the heat might soften the adhesive, it won't make it go away. Too much heat will just burn the adhesive on better.
  16. Nov 8, 2009 at 8:45 PM
    surfsupl
    Gregg
    WestCoast
    no need to worry............I would never take a heat gun to my trucks paint job..........
  17. Nov 8, 2009 at 11:08 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    A good heavy cut cleaner will work. Meguiars should do the job and you used to be able to find that at any automotive store, not so sure anymore. I wouldn't recommend anything heavier unless you're experienced. I think the next step up is Diamond cut any I'll never use it on any of my vehicles.
    http://www.amazon.com/gp/product/B0002SQVF8
    Use to and go over it with a rotary buffer (NOT ORBITAL) with a fairly low speed so you don't heat things up. Smooth it out with a fine cut cleaner and you should be good to go. Don't forget to wax. If you don't have a buffer, you might be able to use the heavy cut cleaner by hand, but it will take awhile.
  18. Nov 9, 2009 at 10:29 AM
    zanodave
    zanodave Well-Known Member
    so il
    07speedwayblue
    if it is glue residue try 3m adhesive and wax remover.
  19. Nov 9, 2009 at 10:35 AM
    fauskar
    fauskar Active Member
    Rick
    Wisconsin
    SR5
    Hitch
    Wd40.
  20. Nov 9, 2009 at 10:50 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I used wd40 after fishing line then this little square plastic dish scraper thing the wife had that had nice smooth edges on it for a couple stubborn spots, then waxed it. No discoloration, no scratches, just gone.
