Head Gasket Noob Questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by tychoseven, Oct 21, 2016.
  1. Oct 21, 2016 at 10:21 AM
    tychoseven
    tychoseven [OP] Well-Known Member
    Klickitat County, WA
    1999 Tacoma SR5 4x4, 2.7L 5spd
    I had my local mechanic do compression and leakdown tests on my 1999 3RZ with 236,000mi because it was rough starting and blowing smoke. I thought it might be valve seals but looks like head gasket instead; leakdown on cylinder #1 causes bubbles to come up through the radiator. It's not overheating or burning coolant but I expect it will only get worse.
    The mechanic recommends a remanufactured engine swap, new thermostat, new water pump, new radiator, all new hoses, etc. Plus I need a new exhaust manifold and clutch (which I already knew). And I don't have the money for all that. He recommended against just the head gasket because he thinks the price delta between that and a reman engine is worth it for the peace of mind and warranty.
    I got quotes and it's only a couple hours shop time difference between the engine and head gasket so I don't think he's pushing the former only for profit. I just can't afford the work, so I'm thinking about doing the head gasket myself, which I've never done.
    I have all the basic wrenches, 3/8 and 1/2 drive sockets, breaker bars, torque wrench, etc. but do I need any special tools? I will buy new head bolts.
    Is it better to buy a reman head or have mine surfaced at a machine shop? Who's a reputable engine vendor?
    I assume I should do water pump, thermostat, radiator, hoses, etc. at the same time?
    Is there any other work I should do at the same time, while I'm in there? Valve clearances come to mind, but anything else?
    I'm still doing research but this is where I'm at right now.
  2. Oct 21, 2016 at 1:57 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The engine swap is less rocket science then just doing the head gasket .
    Pretty much pull the old engine drop in the new.
    Some shops just don`t have the know how or don`t want to take the time to do the head gasket I hear so many try to talk people into used or reman engines instead
    That is one of those things how do you judge how hard it is to someone who never has done it
    Most times it is some little minor detail that causes all the problems
    Like the left over brackets you have no idea where they go.
    Get all the belts on to notice one still sits outside the truck of course it will be the inside one
    Dalandser likes this.
  3. Oct 21, 2016 at 2:36 PM
    tychoseven
    Interesting, so an engine swap is easier in some ways? I've never done engine swap nor head gasket. I see his point and would do the reman engine if I had the cash, but possibly I could afford it by doing install myself.
    The truck is clean and in good condition except for the engine and clutch, I'd hate to sell it because of those things.
  4. Oct 21, 2016 at 2:55 PM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    Depending on the source of the reman engine, you may even get a warranty (piece of mind). With only replacing the head, you still have a block with 200,000+ mile on those components.
    Rachelsdaddy likes this.
  5. Oct 21, 2016 at 3:16 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Let me put it this way the Lot Boy could do most of a engine swap having someone check things over .
    the head gasket you pretty much need someone skilled after the accessories are removed.
    Your disturbing the timing you need to readjust the valves plus do any R&R needed
  6. Oct 21, 2016 at 3:26 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
  7. Oct 23, 2016 at 2:37 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    The V6 is significantly different from the 3RZ. The 3RZ has a timing chain and the V6 has a timing belt.
    I recommend downloading a pdf of the Toyota repair manual from the "DIY and How To" thread at the top of the forum. Read through the cylinder head removal and installation section.
    Other than rusted bolts, the camshaft timing gear bolt can be tight, so you need a tool to hold the camshaft while loosening that. Also, a tool to hold the crank pulley to tighten that bolt to close to 200 ft-lbs. without spinning the engine (See https://www.tacomaworld.com/threads/homemade-crank-pulley-tool.140646/).
    To check the valve clearances you need feeler gauges.
    The other thing is some will say the head gasket doesn't just blow without an underlying reason. You may have corrosion or warping of the cylinder head to deal with. If you've been driving it a while with the leak, then the block could have eroded slightly near the leak. The block surface needs to be perfectly flat to within 0.05mm otherwise a new head gasket will leak. You'd need a machinists straight edge (ideally a 12" and 18") and feeler gauges to check for flatness.
    Like any auto work, it's the unexpected things that make the job difficult. If you don't mind having it off the road for a while to handle the unexpected things, then you can do it yourself, but read and follow the factory repair manual.
    FirstGen Jer likes this.
  8. Oct 23, 2016 at 2:51 AM
    Speedytech7
    ゼイン
    5520 E Sprague Ave, Spokane Valley, WA 99212
    93 80 Series LC & 96 Turbo V6 Taco 4WD
    I've done a mod or two
    Having gone through this myself, in your case I would get a remain engine and put it in. If I didnt have the money that's what I'd have done. I thought mine was just the head gasket too but guess what 3/2RZs rarely blow the gasket. Turns out my problem is what the 3/2RZs are famous for.... The exhaust valves tightened up and cracked the head. So my head gasket job when from $1000 to $2500 but it was worth it for me because I know the bottom end on my truck is solid so I had them build up a new head casting using my valves and cams and new seals and such. They of course did a valve clearance adjustment as well which should be done every 50000 miles to avoid cracking your head. So unless you are prepared for your routine head gasket job to become more involved.... I'd just throw another 3RZ in there and call it a day. By the way any good mechanic should pressure test a head once it's off the truck to check it for cracks and have it millled if it passes the pressure test. If they just replace the gasket without having the head tested or milled you'll be changing that head gasket again in 5000mi and you won't find out if putting that head back on is worth it (because of possible cracks).
  9. Oct 23, 2016 at 9:40 AM
    tychoseven
    Of course I think the reman engine would be best, but it's just too much money. Mechanic quoted me $7k including the new clutch. I could get it done a bit cheaper over the border in OR since I wouldn't have $500 in sales tax over there. I want to support my local mechanic and I think he'd do it right, but that bill would be a sore blow to my wallet.
    I'll check valve clearances first. I've only had the truck 3 months, the previous owner said he did valves on schedule but I haven't checked.
    Anybody know where I can buy a head gasket kit that includes all the other gaskets I'll need to do that job?
  10. Oct 23, 2016 at 9:49 AM
    herbertgerg
    herbertgerg Well-Known Member
    Gary
    1999 SR5 4x4 5spd Access Cab
    7k! Jebus jeist! A NEW 3rz and clutch flexplate isnt anywhere near that price unless you're talking balance/blueprint with top shelf stuff. You should be able to get a new OEM complete motor and clutch for around 2200$-2700$ without shipping. You can do it yourself in a day if you prep ahead of time. And yes, please read FSM in the sticky section.
  11. Oct 23, 2016 at 10:07 AM
    FirstGen Jer
    Jeromey
    Might want to look at supporting a different local mechanic! 7k? That is more then double of what my buddy just paid to have his engine and clutch replaced.
    WinSlow939 likes this.
  12. Oct 23, 2016 at 11:05 AM
    tychoseven
    It's pretty high, no? I'm shopping around.
    Where can you get new OEM motor and clutch for $2700? Dealer?
  13. Oct 23, 2016 at 11:36 AM
    herbertgerg
    Gary
  14. Oct 23, 2016 at 1:10 PM
    tychoseven
    The engine at that link...is it OEM Toyota or 3rd party manufacture? Seems too good to be Toyota at that price; I'm not putting a Chinese engine in my truck :)
  15. Oct 23, 2016 at 1:11 PM
    1997tacomav6
    1997tacomav6 V6 5sp,RegCab,TRD Supercharger,Haltech,meth, 750k
    Denver
    97 reg cab, v6 5sp 300hp supercharged, Methonal Injection, 750,001 plus miles, Original Owner
    V6 5sp,RegCab,TRD Supercharger, 1.9” pulley, methanol injected Haltech ECU, AC TRD supercharger,(MUST DO) TRD supercharger ported, every 125,000- 150,000 needs rebuild Projector headlights HID 5 speed manual Amsoil for all drive train Smaller 2” pulley, (MUST DO) 2004 DESNO fuel injectors, zero ping ping, 2004 side door mirrors Dick Cepek Rims, Michelin tires LTX, ( that last 100,000 miles) Now running Dynopro ATM mud and snow tires KN cold air intake Cat back exhaust with ss exhaust tip, Raised exhaust tail pipe to 2" below body line Optima*dry cell battery,red top Alpine sirius radio, 200 watt amp, focal is165 split door pod speakers Focal door speakers Subwoffer behind seat Viper alarm, Electric Locks Dark tinted windows, bucket seats corbeau lg1 Tacoma Rubber floor mats TRD fender extenders, Bilstien shocks, King shocks nerf bars, add a leaf for rear springs trailer iv hitch, electric brake control, Drilled slotted brakes, High carbon steel (MUST DO) EBS green stuff 7000 series pads(MUST DO) TRD engine oil cap TRD stick shift, Marlin crawl shift kit. Rear sliding window 2002 4Runner functional hood scoop cut into Tacoma hood, 4Runner dual overhead map light Gentex Auto dim + Compass + Temp, garage,rearview mirror Snow Methonal kit stage 2 Custom 3 core aluminum radiator Linex bed liner Haltech stand alone ECU, Intake supercharger gauge. Stainless steel brake lines, Custom leather wrapped steering wheel,
    Best bet is to do an engine swap if you can find an excellent motor, I went down this road and was
    going to just do a head gastket then decided on just replacing the motor because it would cost just a little more money and I had a lot of miles on the original engine.
    Come to find out the motor had 2 cracked heads that was causing the head gasket problem.
    With the motor being replaced I was able to do all those other things that needed to be done
    all at the same time since the motor was out of the truck like
    Reseal the whole motor, front seal, rear seal, valve gaskets, oil pan gasket, new clutch and bearings,
    new timing belt and water pump and tensions bearings, hoses, vacuum hoses and all that stuff that is so easy to do when the motor is out of the truck.
    Ended costing me 1500 for engine with 100,000 miles that was in the truck running and 1000 to have it all swapped over, so 2500 plus parts for clutch etc
  16. Oct 23, 2016 at 1:20 PM
    WinSlow939
    WinSlow939 Road Salt Life
    Nate
    The Rock, Mass
    2002 with some '99 thrown in for fun
    All the Money I Have
  17. Oct 23, 2016 at 1:44 PM
    herbertgerg
    Gary
    The one I got from them has Toyota markings an the block and head, could they be Chinese fakes? Doubtful. Its got 74k on it with no problems so far.
  18. Oct 23, 2016 at 7:39 PM
    tychoseven
    Just to clarify, $7000 was the out-the-door price, including labor, tax, etc. The engine itself (S&J out of Spokane) is $3400 inclusive of shipping and core. Add in cost for new radiator, hoses, water pump, fuel filter, thermostat, 3x belts, clutch, labor, and tax brings it to darn near $7000.
  19. Apr 3, 2021 at 9:57 AM
    farmtacoma
    farmtacoma Date Farmer
    Julia
    Twentynine Palms, California
    2021 Cement TRD OR DCLB 4x4 & 2018 Silver SR ACLB 4x2
    How common are the head gasket issues?
    I am looking at a 96 2wd v6 today
    170k Miles
    1 owner
  20. Apr 3, 2021 at 10:19 AM
    Speedytech7
    ゼイン
    It's not a huge issue, pre 98 v6 have a slightly more likely chance to blow, but it's still not a real concern. We're talking it might go out at 250k instead of the later ones that make it to 300k haha, still lots of miles and chances are it will never go as long as you maintain your cooling system well.
    farmtacoma[QUOTED] likes this.
