Headlamp Restoration
Discussion in 'Detailing' started by WV_Tacoma, Jul 20, 2009.
  1. Jul 20, 2009 at 8:31 PM
    WV_Tacoma
    WV_Tacoma [OP] Well-Known Member
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    If you want to make your headlamps look like new or restore them to a much, much better quality follow these steps.
    I purchased a kit for Plastik lens cleaning to restore headlamps from a expensive detail shop(auto-geeks, Wolfgang cleaning kit). I believe you can do it with a cheap set up.
    This system is SICK!!!! I have done every ones lenses that I know. It is really remarkable. I am sure you can buy one of the cheaper systems from the auto stores.......I hear Walmart is performing them now also.......I will be doing my about every year I expect. So it is worth it to me.
    About $50 for my system...
    The kit came with;
    **1-Plastic lens-Liquid cleaner...slight abrasive gritty paste
    **1-Plastic lens-Glaze, slick oily base..says clarifies and shines
    **1-Plastic surface sealant...UV protectant
    **1-4" orange polishing pad....med-hvy foam pad for abrasion,compounding,polishing
    **1-4" black pad.....soft foam used to apply final steps for this and or waxing your car/truck
    Use in same order...with a drill or buffer, about Med-high speed on my 12v drill---Cheap walmart buffer use the one speed...The different foam I think helps polish the lens>>>Which is Very critical to the cleaning.
    Polish per the directions. mine was till haze is almost dry...Maybe 3mins....The others are just dressing and could be applied by hand I would assume....
    I did not think about any pics......My 2005 lenses that have been outside for its life....looks like 10day old headlamps now....Freaking awsome...
    I will do my Girlfriend and post the pics on here later, hers headlamps are a bit yellowed and dingy...Will make a good showing!
    I HIGHLY RECOMMEND DOING THIS OR GETTING IT DONE!! 5 thumbs up....
    Email if you have any questions
    WV_Tacoma
  2. Jul 20, 2009 at 8:33 PM
    Rangerpeterson
    Rangerpeterson Well-Known Member
    Jacksonville, FL
    06 Tacoma
    Sounds good do you have any pics?
  3. Jul 22, 2009 at 10:41 PM
    stock02
    stock02 Member
    Moreno Valley
    02 std cab, short bed
    I used the 3M kit and i bought it for $22. It worked awesome on my truck. I reccomend it to anybody, I'll try to have some pics by tomorrow. It did take a while, and you need a good drill.
  4. Jul 23, 2009 at 12:48 AM
    militaco
    militaco Well-Known Member
    Hawaii
    2009 Double Cab, '99 Regular Cab
  5. Jul 23, 2009 at 7:38 PM
    WV_Tacoma
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    I didn't have any pics before of my Taco...........BUT
    Here is my GF car.....Just did these tonight...Took all of 20mins to do...Her Car is a Honda 2004, keep outside. Lamps were starting to get yellow/chalked/discolored.....Now you be the judge....
    I am telling you this shit ROCKS...
  6. Jul 23, 2009 at 8:26 PM
    militaco
    Hawaii
    Wow WV adn cmack48, that looks awesome, those headlamps do look brand new, great job.........i guess theere are more than one way to skin a cat.
  7. Jul 23, 2009 at 8:33 PM
    militaco
    Hawaii
    No problem.....i actually got the advice from ProtoJ. Glad to hear it worked for you.......feels better with clean headlights huh:)
  8. Jul 23, 2009 at 8:44 PM
    WV_Tacoma
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    Csmack did you use a power buffer or drill? What model is your truck that you did the headlights?
    I have had the same results now on 4 cars...!
  9. Jul 23, 2009 at 9:29 PM
    WV_Tacoma
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    Yours looks good. I think part of it is the condition of the lens to begin with. Nice work...Feels good doing something on your own and not paying someone else to do it!!!!
    Glad we are all happy with a product!!!! Cheers my friend
  10. Jul 23, 2009 at 9:39 PM
    WV_Tacoma
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    Right on.....Now go try some Clay bar to do the paint.........It will remove stuff you never thought would go away, plus bugs and Opossum guts! And it makes waxing by hand or machine way more better:)
