Headlight replacement bulb
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 41magmag41, Oct 25, 2015.
  1. Oct 25, 2015 at 4:57 AM
    41magmag41
    41magmag41 [OP] Well-Known Member
    jim
    New Hamshiire
    tacoma double cab TRD 4 x 4
    This probably been covered but cant find anything to my specific question. I would like more light out of my high beams on my 2014 DC trd off road and have found a german company that produces a stock H-4 replacement bulb but its rated 55w/100w. It meets or exceeds all standards in europe but was wondering with the 100w rating will I have to upgrade anything on my taco. And yes I know I'm being naughty by installing it because U.S. standards are only 55/60 but I rarely use my high beams except while traveling on the interstate. thanks for any info.
  2. Oct 25, 2015 at 5:27 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Its hard to tell with the info you posted. Most of my lights have been replaced with LEDs. There as long as the lumen out put is higher and amps it draws is equal or lower I'm ok.
  3. Oct 25, 2015 at 6:26 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Pulling a few more amps and it will get hotter than stock.
  4. Oct 25, 2015 at 8:13 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You run significant risk of damaging your electrical by melting your wires. You need to get a stand alone headlight electrical harness to bypass the factory system. In addition to heavy gauge wiring to handle the current, and drawing power directly from the battery bypassing the factory switches, they will use ceramic connectors to prevent melting.
    Tamomas come in both ground switched and conventionally switched electrical systems. My 2015 is conventionally switched. You need to test your truck to determine the correct harness. See this post: https://www.tacomaworld.com/threads/highbeams-negative-or-positive-switched.397465/#post-11007455
    Do you want more light on your low beams? I personally like the Orsam hyper 85/80w H4s. They produce significantly more light than stock on both high and low beam, and have better bulb life than 100w bulbs. They also won't be quite as hot which is better for your headlight assembly.
    Running brighter halogens on the OEM lens is better for oncoming drivers than putting an improper HID retrofit in there that scatters light into the eyes of oncoming drivers because the optics are all wrong.
    Just Dandee likes this.
  5. Oct 25, 2015 at 8:18 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Tex-Tac likes this.
  6. Oct 25, 2015 at 8:29 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    While they may seem brighter, a standard wattage bulbs will not compare to a performance high wattage bulb.
    Any bulb with a colored lens to make the light output 'whiter' is actually filtering out part of the lighting spectrum and producing less usable light. The Orsams I mentioned above have no coating.
  7. Oct 25, 2015 at 8:36 AM
    moondeath
    Pa, Gardners
    The PIAA are definitely brighter than the factory bulbs. They also project light out further than factory. It's not even comparable.
    Tex-Tac likes this.
  8. Oct 25, 2015 at 8:49 AM
    luchin
    luchin living the Canadian dream
    Vancouver Island
    15 6MT DCSB SR5
    OME 885 coils, Dakar leaf pack, Bilstein 5100 struts, SCS Matte Jet Black SR8 wheels, 265/75/16 Toyo Open Country AT II, Arrow cap, Truxedo Truxsport Tonneau cover, TRD Exhaust, colour matched grill.
    I use the Piaa NightTech and they are much better then stock not as white as their hyper whiter/super white but too white and things get 'washed' out.
    I will say this. Changing the bulbs in this truck is a PITA. Lol. Removing my grill and then removing the chrome surround from my grill to paint it was easier. They must have 5 year olds or adults with very small hands put the bulbs in these trucks.
  9. Oct 25, 2015 at 9:07 AM
    Krogen
    Krogen Well-Known Member
    Puget Sound
    14 AC V6 6sp 4x4 Off-Road
    Long ago, I had Cibie sealed-beam replacements in my '87 Supra. I switched over to 100 W bulbs and saw little difference except the light quality got yellow-ish. Didn't burn the wiring, but the increased power pulled nearly double the current and reduced the voltage at the bulb (Ohms law). The reduced voltage prevented me from getting the full 100 W and produced the yellow light. Re-wiring with heavier wire would have been the solution.
  10. Oct 26, 2015 at 7:40 PM
    bluesttape
    bluesttape Well-Known Member
    Denver
    '14 TRD Sport DCSB
    Debadged 3in Lift KO2s 275/70/17 OEM Stock Rims w/TRD Center Caps TRD Cap-Back Exhaust Avid Light Bar A.R.E. CX Cap OEM Nerf Bars OEM Rack on Cab Thule Rack on Cap WeatherTech Floor-liners WeatherTech Vent Visor CoverKing Seat Covers Chicco Keyfit 30 :-) Clifford 5806x Alarm & Remote Start LED Replaced (dome,map,flasher, reverse, & parking) Salex Organizer in Glove Box & Center Console Fully Tinted 12in ClearBra
    I am looking for a white light to match the new Fog LEDs. Are the Osrams white? I really don't want the blueish look. Also are they drop in?
  11. Oct 26, 2015 at 8:43 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    They are whiter, but they do not have a color filter coating, so they are not a blue/white. I'll have pics up in a couple days.
    Edit. If you run the 85w they are a drop in but should be run with a standalone harness. There is a lower 75w version that would be easier on the factory wiring.
  12. Oct 28, 2015 at 8:39 AM
    bluesttape
    Denver
    '14 TRD Sport DCSB
    uh oh, a bit over my head. Is there a link to a thread about this? or would you mind expanding?
  13. Oct 28, 2015 at 9:07 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    FYI.... the 2nd gens are all relayed. there is a huge relay (labeled DIM) that controls high or low beams, and another one (HEAD) that feeds power to the DIM relay. NO significant power runs through the stalk.
  14. Oct 28, 2015 at 11:19 AM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
  15. Oct 28, 2015 at 11:23 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Pics and writeup here:
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-not-led-or-hid.398066/
    Good to know, even so the heavier wiring from a standalone harness will reduce voltage drop which will increase light output.
  16. Oct 28, 2015 at 11:46 AM
    nd4spdbh
    SoCal
  17. Oct 28, 2015 at 12:00 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    You guys are crazy. The stock setup can easily handle 1.21 gigawatts of electricty.
    TacoDan723 likes this.
  18. Oct 28, 2015 at 5:33 PM
    bluesttape
    Denver
    '14 TRD Sport DCSB
    well played sir. well played.
  19. Oct 28, 2015 at 5:36 PM
    bluesttape
    Denver
    '14 TRD Sport DCSB
    Thanks everyone. I really want a drop in solution even if its not my forever solution.
  20. Oct 29, 2015 at 12:17 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    <---- 40 years as an electrician / electronics tech.
    What? That makes no sense. It doesn't work that way.
    The Voltage to the headlights is constant provided by battery. Unless you added something to reduce the voltage.
    Tex-Tac and 3coma like this.
