Headlight upgrade
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Davis98, Feb 25, 2018.
  1. Feb 25, 2018 at 7:29 PM
    Davis98
    Davis98 [OP] Well-Known Member
    2016 Tacoma TRD Sport 4x4
    Alright guys, I’ve done the research and read through countless threads on here and still can’t seem to decide which headlights bulbs to upgrade to. Currently I have Auxbeam F16’s in right now and am not
    Impressed, they’re bright but have no distance on them. I’ve been looking into hids like my last tacoma(2nd gen, I know reflector heads aren’t made for HIDs) but does anyone know what the best hid In terms of reliability and brightness are? Currently I’m torn between xenondepots extreme hid kit and morimotos elite hid kit. If anyone has pictures of these to help it would be greatly appreciated and so would any input!
  2. Feb 25, 2018 at 8:58 PM
    tcjacado
    tcjacado Well-Known Member
  3. Feb 25, 2018 at 11:57 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Either one of those kits will work great. I opted for the hylux kit, which was a lot cheaper but just as good. I'm running those auxbeam F16s in my highbeam though; work well for that, but wouldn't want to put them in my low beams.
  4. Feb 26, 2018 at 1:44 AM
    TacomaSingh
    TacomaSingh Active Member
    2017 TRD Sport DCSB M/T
    I got XenonDepots in my Tacoma. Morimotos in my Armada. Can't go wrong with either one of them. XDs pricing is a bit less than Morimoto.
  5. Feb 26, 2018 at 1:49 AM
    Modesto Tacoma
    Modesto Tacoma Well-Known Member
    central california
    LIMITED 4X4
    From my personal experience and from my friends LED light aftermarket anyways won't get you much light down the road.
    Garyji likes this.
  6. Feb 26, 2018 at 6:51 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    What Modesto said. Due to the nature of the beast, you're not going to get much improvement, if any, with new bulbs.
    The "Bro-Cool" factor may be higher though.
    G.
    Modesto Tacoma likes this.
  7. Feb 26, 2018 at 7:05 AM
    Muffdiver
    Muffdiver Growing old is mandatory, growing up is optional
    Ty
    Elkhart, In
    2012 TRD OR DC 4x4
    crashnburn80 likes this.
  8. Feb 26, 2018 at 7:36 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    ...with LEDs sure, but HIDs bring loads of improvement to the table.
  9. Feb 26, 2018 at 2:11 PM
    Davis98
    Wo
    Would you happen to have a pic of the hylux kit?
  10. Feb 26, 2018 at 5:12 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Edit: My bad I was thinking of the 'latest' LEDs, not hylux HIDs.
  11. Feb 26, 2018 at 5:48 PM
    Davis98
    ? What are you talking about
  12. Feb 26, 2018 at 5:53 PM
    su.b.rat
    su.b.rat broken truck
    jerzsubbie likes this.
  13. Feb 26, 2018 at 6:09 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I had originally got the name confused with an LED brand vs the HIDs. Rather than just deleting the post entirely, I just edited the non-relavent material out.
  14. Feb 26, 2018 at 6:33 PM
    Davis98
    Is it the bulb or the ballast that determines brightness? Wondering because I found A similar kit that has the same hylux ballast but different bulbs
  15. Feb 26, 2018 at 8:32 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Both.
    The higher wattage the ballast (35w vs 55w) the brighter the light output, however higher wattage HID ballasts also reduce color temperature and shorten bulb life. Meaning a higher wattage ballast will be brighter but also shift the light output slightly toward the yellow spectrum. While 2 ballasts may be labeled as '35w' it can also depend on how true they are to the specs.
    Bulbs will vary in output depending on brand and color temperature. All other things being equal, bulbs near the low-mid 4000k range will have the highest lumen output, the further you go from that color temp the lower the output. Xenon Depot for example advertises Philips bulbs as 4% brighter than the same color bulb from a different brand. Going from 4300k to 5000k color temp also results in a 4% loss in output, according to their specs specs. As a general rule though, a 35w HID in the low-mid 4000k spectrum is going to produce ~3200 lumens. There are other factors to consider like quality, durability, lifetime ect that do not come into play when looking at just the output specs.
    I haven't done any output comparison testing on HIDs to validate the specs. Yet.
  16. Feb 26, 2018 at 9:14 PM
    Davis98
    Makes sense, thanks!
  17. Feb 26, 2018 at 9:27 PM
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
  18. Mar 2, 2018 at 12:35 PM
    XenonDepot
    XenonDepot Well-Known Member Vendor
  19. Mar 2, 2018 at 2:15 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    happy to help!
  20. Mar 2, 2018 at 6:12 PM
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    I have also been reading a metric crap ton on here about this subject and I have even been on xenons website picking out my order. The part I always get hung up on, bulb color. What are people doing with this option?
    upTOPOverland_Drew likes this.
