Heated Mirror Advice...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zuckdan, Sep 11, 2011.
  1. Sep 11, 2011 at 11:12 AM
    zuckdan
    zuckdan [OP] Well-Known Member
    Evergreen CO
    2011 DC SR5
    I have a 2011 and live in the mountains of Colorado. Heated mirrors are a must for me as I do not have a garage. I have read up on the "EL Cheapo" mod and am debating doing this low cost mod with doing the more expensive sienna mirror swap. I like the idea that the siennas are quite a bit less work, and the heating element covers more of the mirror surface (faster defrost).
    Has anyone put sienna mirrors into a 2011 Tacoma? Hows the fit? If I can confirm that the sienna's work in a 2011, I may look to pull some at a junkyard or get them on ebay to save a lot of work.
    The part of this job that intimidates me the most is the wiring. anyone have any advice on the best way to wire it up? I have a 5-post switch from a paseo that looks like a perfect fit in the dash switch blanks. Do I need to use a relay?
    Any first-hand advice on this mod would be greatly appreciated
    oh yeah...one more thing. Anyone have any credible info on whether toyota is finally getting it's shit together and making heated mirrors for the tacoma with the "light redesign" of the 2012?
    Thanks.
  2. Sep 11, 2011 at 11:18 AM
    zuckdan
    Evergreen CO
    2011 DC SR5
    Here are a couple pics of the switch I am going to use
  3. Sep 11, 2011 at 11:25 AM
    cheehab
    cheehab I bleed Black and Gold
    Adam
    Winter Park, CO
    2015 Tundra TRD Pro CrewMax
    I don't have any advice for you but am dying to hear how this goes.
  4. Sep 11, 2011 at 11:27 AM
    zuckdan
    Evergreen CO
    2011 DC SR5
    I know other people must be interested in this as well. Not having heated mirrors is such a huge issue for me. I will be sure to take pictures of the process once I decide which way I am going and share them.
    I wonder what toyota is thinking not having these as an standard, or at least an option. My '97 nissan pathfinder came with them standard!
  5. Sep 11, 2011 at 11:32 AM
    SB11Tacoma
    SB11Tacoma Well-Known Member
    Dave
    New York
    11 TRD Sport DCLB 4X4 with JBL
    Lund Nerf Bars Tonnopro Tri Fold
    I would definitely like to see how this works out
  6. Sep 11, 2011 at 11:54 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Somebody has done Sienna mirrors , I'll try to find the thread .
    Also check out Muth mirrors
    http://www.muthco.com/
  7. Sep 11, 2011 at 12:03 PM
    zuckdan
    Evergreen CO
    2011 DC SR5
    I have seen people talking about the siennas in the el cheapo thread, but haven't heard anyone specifically confirm the siennas fit the 2011. Not really interested in the muth cuz they are so much more expensive than the other options. $250 I think.
  8. Sep 11, 2011 at 12:31 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    I also interested. But I'll be waiting until I can pick up some cheap 2012 mirrors (with the turn signal lights) for a direct swap, and I'll just add the heating element at that time.
  9. Sep 11, 2011 at 12:43 PM
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    I am totally waiting to hear how this turns out- I have already run wires for the heated mirrors, but am not sure if the Sienna mirrors fit exactly. I even went to the dealer and traced out a Sienna mirror on the lot. When I put it over the Tacoma mirror it was inconclusive. They are almost identical, but maybe the Sienna mirror is a bit more pointy in one corner. I want to assume that Toyota would just use the same mirror in both vehicles, but who knows.
    Also, the Highlander switch is supposed to be an exact match for Tacoma switch, but need to change the bulb from green to orange. 15 minute timer is built into the switch, but need to use a relay to handle the current.
  10. Sep 11, 2011 at 12:49 PM
    zuckdan
    Evergreen CO
    2011 DC SR5
    Do you really think they will be "cheap?"
    Also, I am not sure I want the turn signals on my mirrors.
  11. Sep 11, 2011 at 12:51 PM
    zuckdan
    Evergreen CO
    2011 DC SR5
    So, how did you run the wiring. I assume two wires to the mirror. were you able to just run them back to the driver fuse panel and make it all happen there? what sort of relay should I be looking for?
  12. Sep 11, 2011 at 1:01 PM
    84Hilux
    Gary
    Vancouver, Canada
    I just ran the wiring in the doors when I had the skins off for stereo install. I just ran the wires to the kick plates and terminated them there. I am planning to use an unused slot in my fuse box for the relay. I am going to use a spare Toyota fog light relay that I have. I found someone on ebay that sells them for $10.
    You want to run at least 16ga wiring for this. I ran 18ga and found out later that 16 is recommended.
    What I am planning top do is run the wires from the back of the switch and the wires from the mirrors through the firewall boot out to the fuse box area. I already have a hole punched through the boot for the stereo wiring- just use a beefy philips driver to punch the hole.
  13. Sep 11, 2011 at 1:05 PM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    I tried the Sienna mirrors and they didn't quite fit right in my 2010, so I went with the Muth ones. I also used the highlander switch shown above.
    The mod is well worth the money.
  14. Sep 11, 2011 at 1:18 PM
    84Hilux
    Gary
    Vancouver, Canada
    Yeah, that's why I stalled on my mirror project. I don't want turn signal mirrors and I had a feeling the Sienna mirrors were not an exact fit.
    I laughed at your comment "only took 3 months of studying/procrastinating"
    It looks like Muth is still the best option. I emailed them and asked if it is possible to get the mirrors without turn signals- they never answered.
  15. Sep 11, 2011 at 1:54 PM
    AeroCooper
    NH
    I didn't want the turn signal mirrors either, but I have to admit, they are pretty cool once you get them installed. I really like them now.
  16. Sep 11, 2011 at 1:59 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    Do we know if 2012 are getting blinkers in mirrors?
  17. Sep 11, 2011 at 2:44 PM
    ouyin2000
    Nova Scotia
    '11 DCSB TRD Sport
    The Sport models are yes.
  18. Sep 11, 2011 at 3:06 PM
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    I'm the one who mentioned the Sienna mirrors as well as had my highlander switch burn out because of not using a relay in the El Cheapl thread.
    I'm not sure if the 2011 mirrors are different then my 2008's (everything I have read indicates they are the same). The Sienna mirrors fit perfect on my truck and still work great after a couple of years.
    Keep in mind you are only buying the glass not the entire assembly, I'm not sure if a wrecking yard will separate the glass to sell.
    I would also not make the same mistake as me and make sure to use a relay.
    Shawn
  19. Sep 11, 2011 at 3:12 PM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
  20. Sep 11, 2011 at 6:25 PM
    ouyin2000
    Nova Scotia
    '11 DCSB TRD Sport
