Heated seats
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Redcorn66, Feb 19, 2022.
  1. Feb 19, 2022 at 12:10 PM
    Redcorn66
    Redcorn66 [OP] Member
    Mickey
    None
    I have a 2021 Tacoma extra cab, does anyone know if it comes prewired for heated seats?
  2. Feb 19, 2022 at 12:13 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
  3. Feb 19, 2022 at 1:24 PM
    chrlsone
    chrlsone Well-Known Member
    Charles
    2022 TRD OFFROAD 4x4
    I have a 22 TRD OFFROAD 4x4 ACCESS CAB and it is prewired for heated seats. The wires run from power/switch connections, under the carpet, and comes out under the seats. You would have to get the center climate control dash(which can be found at a junkyard) and it has the factory switches. Then you would need to purchase the factory heated pads and wiring for them that connect to the wires running to under the seat. Then there is a relay that needs that needs to be put in a box behind the drver side lower dash/kick panel. In all your looking at $1,500 to $2,000 to get factory heated seats and that is doing everything yourself.
    bonnfabrication likes this.
  4. Feb 19, 2022 at 1:27 PM
    tcjacado
    tcjacado Well-Known Member
  5. Feb 19, 2022 at 1:30 PM
    chrlsone
    Charles
  6. Feb 20, 2022 at 6:26 AM
    Asmara
    Asmara Active Member
    2021 Super White SR5 4X4
    Hard Tonneau cover, OEM power tailgate, retro accent stripes, tailgate accent letters, retro 4WD badge, Blackvue DR750X-2CH Plus, Spiker Hood Struts
    I put in aftermarket heated seats but used the factory relay and fuse so it appears more OEM. I ran new wiring to the seats.
    The heating pads and switches were about $80, add in some hog ring pliers, wire, and some connectors and the total costs were in the $100 range. The hardest part of the installation is reinstalling the seat covers. I put up some site.
    Tocamo and tacoshell88 like this.
  7. Nov 10, 2023 at 11:00 PM
    sikeitsryan
    sikeitsryan MidWestMTB
    MidWest
    '22 MGM SR 4x4
    So I'm in a bit of a pickle, I have a 2022 sr that has the blue wire coming into the IE2 junction. My seat heater relay has all the female connectors and the fuse block came with a 20a fuse installed in the seat heater fuse location. HOWEVER I can't seem to get power to pin 5 or 4 of IE2. Checking around the connector I seem to be getting 7V between pins 11 and 2
    I'm going to check continuity between the fuse and and the coil on the seat heater relay but it just doesn't make sense to me that this wouldn't be wired when everything else is, not to mention the guy with the 21 sr having the circuit fully wired in the tacoma3g thread. Any thoughts on what might be wrong here or what else to check?
  8. Nov 11, 2023 at 3:40 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
  9. Nov 11, 2023 at 3:53 AM
    caribe makaira
    Caribbean, Puerto Rico
    Why or where are you getting info on the fused power locations you are "checking"?
    Fused power is available as soon as vehicle is ON.
    The selection on turning it ON to the heating elements is done by the switches and their settings position. (Part of A/C Amplifier module)
    Chew and FLAK-TAC like this.
  10. Nov 11, 2023 at 8:32 AM
    sikeitsryan
    MidWest
    '22 MGM SR 4x4
    Got the info from that exact wiring diagram you posted
    can you elaborate on the ac amplifier module?
    one more thing I'll mention is I manually connected pins 3 and 5 on the seat heater relay and still wasn't able to get power to that sky blue wire out of IE2. Looks like I mistyped my previous post, I wanted to check the continuity between pin 5 on the relay and the fuse (not the coil)
  11. Nov 11, 2023 at 10:16 AM
    sikeitsryan
    MidWest
    '22 MGM SR 4x4
    Alright so I just experienced what I can only consider a Christmas Miracle...last night after connecting everything, I wasn't getting power to that wire in IE2. Just now, went downstairs, checked all my connections again, checked the seat heater fuse and it was good, checked continuity between the relay and the fuse, everything was as expected. Thought, what the hell, let me try to manually connect the switch on the relay again (87 to 30 / 3 to 5 on the Toyota diagram). Did that, still wasn't getting power...thinking I was defeated I pulled the seat heater fuse to use it on a add-a-circuit to pull from a different circuit...the fuse was blown (this is the same fuse that I had checked not even 5 minutes prior).
    I threw in another 20a fuse in the box and now everything works?? 12v coming out of IE2 SB wire, relay switch closing with ignition, seats getting warm, the whole nine. I have absolutely zero clue how or why this happened but its probably the closest thing to an act of God I've ever experienced. :amen:
  12. Nov 11, 2023 at 3:43 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Good to hear Ryan.
    I use my heated seats more than I put on the heater. And thank god I don't have Leather seats. Soooooo overrrated and phucking cold in the winter and burn your ass in the summer.
  13. Nov 24, 2023 at 11:10 AM
    bonnfabrication
    bonnfabrication Well-Known Member
    Brandon
    Bremerton
    2018 Tacoma TRD OR DCSB 4x4
    Dobinsons HD MRR lift SCS F5 wheels BFG K02s front bumper, custom roof rack
    Ive been wondering about if the wiring is there for the factory heated seats for a while now. Im glad to have found this and maybe ill be able to swap in heated seats and the AC control unit from a different truck at some point.
  14. Nov 24, 2023 at 11:33 AM
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    Hell with heated seats. I'd like to have some air flow seats like my friend has on his Dodge Ram.
    I'd never heard of them till he was taking me to pick up my new bike back in 2014.
    Would love to have a set up like that on my bike too.
  15. Nov 24, 2023 at 11:40 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    they're nice,,, but there is more to it, the seat covers are perforated, duct work running through them and the floors, then you'd have get in to the dash and HVAC system. Not worth it to me.
    I'd say that my next truck will have this option,,, but I don't like leather either.
  16. Nov 24, 2023 at 9:27 PM
    wood714
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    Something I can always wish for.
    Never understood the love for leather seats in a car/truck.
    My mom has a RAV4 she leaves in Florida the summers. I drive it a lot, and the leather seats suck!
    I like my cloth seats with neoprene seat covers.
    Chew[QUOTED] likes this.
