Help cleaning MAF sensor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by faller, Apr 17, 2012.
  1. Apr 17, 2012 at 4:15 PM
    faller
    faller [OP] Active Member
    Vancouver Island
    Tacoma
    Bilstein 5100's @ 0.85, Toytec/Eibach coils, 1.5" AAL fbconvert's DIY AUX Input
    I have spent the last half hour searching for a DIY on cleaning the Mass Airflow Sensor. I swear I have found one on here before and can't find anything other than people suggesting to clean it. In the Haynes manual it just shows you where it is and how to remove it. Do I just remove it, spray it off, let it dry, and put it back in? Or do you have to spray out the whole air box/throttle body? If I remember right in the DIY I think I remember finding they took the throttle body off...
    I used to get around 18.5 mpg and it's steadily declined over the last year or so. Put in new plugs and new air filter, now considering cleaning the MAF sensor. I've come to understand it's pretty sensitive so make sure it touches nothing but MAF cleaner, and make sure the MAF cleaner touches but the MAF sensor...correct?
  2. Apr 17, 2012 at 4:17 PM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    ONLY use MAF cleaner or just plain ole compressed air. Any other liquid should not touch it
  3. Apr 17, 2012 at 4:19 PM
    faller
    Vancouver Island
    Tacoma
    Thanks. Will it be visibly dirty? The majority of what I've read on other threads is people recommend cleaning it, but it sounds like they can get damaged easily. If you're careful it's probably good to go ahead an clean it it? It's a 2005 4.0L and it hasn't been cleaned before...
  4. Apr 17, 2012 at 5:26 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) Since you have lower gas mileage, you may want to clean the Throttle body. I think it would do more good than the MAF, but since you have to take it apart to get to the throttle, you can clean both and see if the mileage goes up.
    This is my 3rd thread since yesterday offering advice on cleaning the throttle body. Maybe yearly cleaning of the throttle body could help prevent problems. Just as you get your teeth cleaned once or twice a year, you could clean your throttle body once a year. :D
  5. Apr 17, 2012 at 5:37 PM
    faller
    Vancouver Island
    Tacoma
    Thanks I'll see if I can find a DIY on cleaning the throttle body too.
  6. Apr 17, 2012 at 5:48 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
  7. Apr 17, 2012 at 5:54 PM
    faller
    Vancouver Island
    Tacoma
