help clutch pedal sticks to floor when really cold
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crazytacoma, Dec 7, 2010.
  1. Dec 7, 2010 at 10:29 PM
    crazytacoma
    crazytacoma [OP] Member
    jeff silva
    naugatuck ct
    2010 tacoma trd off road supercharged gray
    trd supercharger ... k&n air intake system magnaflow cat back trd short shifter pioneer head unit
    hey guys just want to know if anyone else has the v6 with the 6spd im in ct and its cold here really bad and i havee noticed that my clutch pedal gets stuck to the floor for a second befor comeing back up when really cold asfter warmed up its doesnt do that anyone else haveing this problem or any clutch problem with the 2010 ... its supercharged trd done by dealership and they never said i need to update clutch they said it would be fine but i never blew a clutch in any other taco i had please help a fellow brother out ....:confused::confused::confused::confused::confused::confused:
  2. Dec 7, 2010 at 10:52 PM
    sierrahsky
    sierrahsky Expedition Style
    I have had the same issue with my truck, also I had an issue that sometimes randomly I could not get in to first gear at a stop light or stop sign. So far toyota says "transmission" is ok but sounds like its going bad, we will just replace it when it goes out. Problem is I can only get the clutch to do the problems you have described when its really really cold or otherwise its random. Toyota adjusted the pedal but that did nothing, a little trick i found was to keep it in first or second gear when parked over night.
  3. Dec 7, 2010 at 11:17 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Mine does that too. I believe it's because it's a hydraulic clutch and the oil being cold at startup is thick, therefor creating the drag experienced with the delayed pedal return. My $.02
  4. Dec 7, 2010 at 11:44 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    This has been addressed on this site before, here, and for my 2 cents I'd say change the fluid to a cold-temp tolerant variety. Not sure what you mean by "cold", but if your definition includes below freezing temps then a fluid change might be the answer.
  5. Dec 7, 2010 at 11:47 PM
    JanBoothius
    JanBoothius Well-Known Member
    Jan (Pronounced Yon)
    Upstate New York
    2015 TRD OR DCSB 6 speed
    Heavy stuff big tires drives like hell
    My 2010 does this. Clutch pedal is slow and stiff.
    Works fine though, and reminds me to take it a little easier until everything has warmed up.
    e30saam likes this.
  6. Dec 9, 2010 at 12:07 PM
    crazytacoma
    jeff silva
    naugatuck ct
    Took to dealership today dig defective pressure plate and slave cylinder
  7. Dec 9, 2010 at 12:51 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    Huh?
  8. Dec 9, 2010 at 4:34 PM
    BarefootBandit
    BarefootBandit Well-Known Member
    TC UCA OME 884 5100 TSB+AAL 4.10 V6 6spd 285/75/16
    My clutch feels very spongy on days colder than 40 degrees. It stays that way looooong after the engine has warmed up to operating temperature. I'd never drive my truck without warming it up at least 5 minutes. It feels really different when cold.
  9. Dec 10, 2010 at 12:17 PM
    crazytacoma
    jeff silva
    naugatuck ct
    Me too I let it warm up for 10 min but they are putting i'n new plate and slave will see
  10. Dec 10, 2010 at 4:42 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    I plug in my block heater when it gets below 0 C. I noticed the stiff clutch, but since I've been plugging it in, no problem. The block heater however, does nothing for the rough shifting into first gear when it's cold.
  11. Jan 19, 2016 at 9:48 AM
    ahlerscurtis
    ahlerscurtis Active Member
    2019 Quicksand TRD OR DCLB
    I had this same problem this morning. Clutch sticks until engine is warm. Is there a solution to it? Should I call my dealer. Truck is new and under warranty.
    tcam27 likes this.
  12. Jan 19, 2016 at 9:51 AM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    My clutch never sticks, because I have an automatic.:p
    TacoTaco15 likes this.
  13. Jan 19, 2016 at 9:52 AM
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
    Six-year-old thread and OP seems to be long gone, but it sounds like his dealer did replace some parts for him. I think it's worth a trip to your dealership if you think it's an issue.
  14. Jan 19, 2016 at 10:21 AM
    tcam27
    tcam27 Well-Known Member
    TIm
    CT
    13 silver DCSB 6spd with a bunch a sick bikes
    16 limited wheels and tires TRD Short throw shifter
    im in Colchester Ct my pedal is always slow in the colder weather. but I once I had my squeaky pedal fix with the TSB it did the same thing all I did was loosen the main pivot bolt a half turn. hopefully its that easy for you
  15. Jan 6, 2021 at 6:48 AM
    Tacoma1818
    Tacoma1818 Well-Known Member
    Main pivot bolt on the pedal itself?
    I just had the TSB done for the creaky pedal. Now I have a creak from somewhere under the hood until I start the truck (a concern b/c anything squeaking usually means premature wear, but it goes away as soon as truck is started) but worse, my "gummy" clutch pedal is WAY worse. Used to only happen in single-digit temps. Now it happens in the 30's.
  16. Jan 6, 2021 at 7:02 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    My 08 would do the same.
    Even after time on interstate not using clutch.
  17. Jan 6, 2021 at 3:02 PM
    reg0928
    reg0928 Well-Known Member
    Ross
    Crestone, Colorado
    05 TRD OR Access Cab
    3"OME, 255/85R16
    Yep mine does. I let my truck warm up for a few mins on cold mornings and it works normally once the motor starts to warm up
