Help me make my truck look better!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 802, Jan 6, 2014.
  1. Jan 6, 2014 at 12:55 PM
    802
    802 [OP] Well-Known Member
    Rob
    VT
    '13 TRD Off-Road
    Toytec Nitto Ridge Grapplers
    I was thinking about that. I can do it in our shop, so thats no problem. I just wasn't sure how good it would look...
  2. Jan 6, 2014 at 12:56 PM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    Wheels and tires
  3. Jan 6, 2014 at 1:00 PM
    802
    Rob
    VT
    '13 TRD Off-Road
    what do you think about plasti dipping the wheels i have? does it look good, not cheap?
  4. Jan 6, 2014 at 1:02 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    there is a few pics on here that guys have done it. looks good and they say it holds up well.
  5. Jan 6, 2014 at 1:03 PM
    802
    Rob
    VT
    '13 TRD Off-Road
  6. Jan 6, 2014 at 1:04 PM
    802
    Rob
    VT
    '13 TRD Off-Road
    ill give it try.
  7. Jan 6, 2014 at 1:07 PM
    802
    Rob
    VT
    '13 TRD Off-Road
    also, i know this question has been asked probably a million times, but what is the biggest size tire i can fit on my stock 245/75 R16's?
  8. Jan 6, 2014 at 1:07 PM
    evan
    evan Well-Known Member
    SK, Canada
    Definitely do some searches about that. I've been reading about durability issues. I guess it will depend on how long you expect it to hold up and what type of roads you drive on.
    Since you don't have a TPMS to worry about it would be super cheap to find whichever Toyota alloy you prefer from Tacoma or 4Runner or FJ Cruiser. Lots of guys upgrade to aftermarket and sell the factory alloys cheap.
    Yeah, LED's are expensive. There are cheaper versions out there but they still aren't that cheap. If you're okay with the current light output I would put that lower on the priority list.
    Biggest tire on factory suspension is 265/75/16.
  9. Jan 6, 2014 at 1:14 PM
    802
    Rob
    VT
    '13 TRD Off-Road
    would the 265's raise it up noticeably? also you said earlier that a 2in lift would be good, if i got 265's would i want to get a bigger lift? also would i want to lift the back a little?
  10. Jan 6, 2014 at 1:24 PM
    evan
    SK, Canada
    If I were you I'd put 265/75/16 tires on factory offroad alloys (or aftermarket if you want to spend a bit more) and Bilstein 5100 shocks on all four corners with the fronts set at 1.5".
    If you go more than approx 2" lift you will run into alignment issues (can be fixed by aftermarket upper control arms for $450). If you go with a bigger tire you will run into rubbing issues (not a big deal if you're okay trimming stuff off in the wheel well). Lots of guys go with taller lifts and bigger tires but the above setup is a relatively cheap and conflict free way to improve the truck. With that in mind I would recommend you spend a few weeks browsing the forums to see what everyone is doing and what they think about it.
  11. Jan 6, 2014 at 1:36 PM
    evan
    SK, Canada
  12. Jan 6, 2014 at 1:38 PM
    802
    Rob
    VT
    '13 TRD Off-Road
  13. Jan 6, 2014 at 1:42 PM
    evan
    SK, Canada
    It would be much easier to just browse the forum and find guys with similar setups first if want to see how it looks.
  14. Jan 6, 2014 at 1:43 PM
    802
    Rob
    VT
    '13 TRD Off-Road
    good idea, thanks!
  15. Jan 6, 2014 at 1:46 PM
    #35
    ChiveOn
    ChiveOn City Slickin' Redneck, I wear a suit with a mullet
    A BC Boy in Calgary
    2013 MGM DCSB TRD Sport 6spd
    Plasti-Dipped Emblems, Tonnopro Tri-fold toneau cover (for winter use only), AVS in-channel visors, Ultra Gauge, Tepui Kukenam RTT, Muteki Trail Hog 285/70/17, Pop N' Lock, Bilstein 5100's in the front set at .85 with Eibach coils, Bilstein 5100's in the rear with a Toytec AAL. Toytec drivers side spacers, Toytec diff drop kit. All Pro u-bolt flip kit, TJM Compressor (permanently mounted), Custom rack for the RTT over the bed, Tepui Kukenam RTT, Toyota Bed Mat, Cobra 75 WX ST CB Radio, and a lot of gear behind the seats.
    Level it out with Billies in the front, derp the emblems, and add this to the passenger seat....
  16. Jan 6, 2014 at 1:47 PM
    #36
    kevinsc
    kevinsc 2012 dbl cab 4x4
    kevin
    Lexington, south carolina
    12 4x4 dbl cab
    chrome on front painted to match, satoshi grill done by myself, BHLM, billys all the way around with ome springs upfront and LR ucas with wheelers 3 leaf progressive pack in the rear, mb gunner wheels powdercoated black on 285/75r16 nitto trail grapplers, tinted all the way around and on windshield, pioneer dbl din touch screen with two 10's behing the seat and new speakers all the way around and certain interior parts painted to match, also have a road wire leather kit black with red stitching sitting here waiting for me to find time to install it!
    here is mine plati dipped and my wifes old mazda.. I had the same rims you do but I have since changed!
  17. Jan 6, 2014 at 1:49 PM
    #37
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    A lift and/or new wheel-tire combo is going to improve the look of your truck more than anything else.
    Add a leaf to the rear leaf pack and throw some Bilstein 5100's in the front. If you just lift the front you will likely end with a dreaded bro lean and they only look good on LT's. Not only will your truck look good with the aforementioned lift, but you will have increased your payload capability
  18. Jan 6, 2014 at 1:56 PM
    #38
    Jhodgman
    Jhodgman ...
    Justin
    So Cal
    13 4x4 DCLB tacoma V6 TRD Sport
    5100 Bilstiens set at 1.75, progressive leaf pack, BFGs, All-Pro rear Bumper(white), Storm troopered out
    lift just the front with some spacers, and color code the grill, thatll make her look a bit meaner.
  19. Jan 6, 2014 at 2:27 PM
    #39
    802
    Rob
    VT
    '13 TRD Off-Road
    That looks great! where did you get the grille?
  20. Jan 6, 2014 at 2:33 PM
    #40
    802
    Rob
    VT
    '13 TRD Off-Road
    http://toyteclifts.3dcartstores.com...able-5100-front-and-rear-5100-shock_p_31.html i was looking at this, would you do that 1.5" add a leaf in the rear? or just do the shocks?
