HELP Need Info about 110v socket in BED !!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ideal4u, Oct 21, 2009.
  1. Oct 21, 2009 at 3:35 AM
    ideal4u
    ideal4u [OP] Member
    Steinhatchee Florida
    SR5 4X2 PreRunner TACO
    Chrome Step Bars OEM BedMat WeatherTech Mats Garmin Nuvi 265WT
    I Noticed the tag on the 110v socket in my truck bed. The tag on the cover states that it is 400 watts idling or 100 watts running. Does this mean there is more watts available at the plug in when the truck is sitting still vs. running down the road say at highway speeds? Can someone explain to me how this system produces electricity, is this a inverter, converter, how does it work, and where this is located or mounted on the truck? Is this fused or not? Can you give me some examples of what you have powered with this socket, or could be using this electrical socket for? Is it OK to connect an extension cord to it, say to run to the cab to charge a Laptop etc. Any info would be appreciated. This is on a new 2010 Taco DC. Thanks..
  2. Oct 21, 2009 at 4:33 AM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    I don't have this in my truck, but from my knowledge of electrical thingamajigs...
    The system produces electricity by inverting (i.e. changing dc into ac) the battery voltage. This is achieved by using electronic components. You can use it to power anything up to 400 W (depending on whether you're idling or not)... people have charged phones, batteries for power tools, run small TVs. Basically, 400 W at 110 V gives you rouhly 4 A, and about an amp for 100 W - so don't expect to run a 15 A circular saw with it. You could use an extenion cord on it if you so desired (best not to use too long a cord, though it only really becomes an issue with high currents).
    Not too sure where the inverter itself is mounted, perhaps someone will chime in to let us know. But in terms of fuses, check out your owner's manual, refer to the section on fuses and look for inverter/bed-mount receptacle (don't know what it'll be called) for the fuse number and rating.
  3. Oct 21, 2009 at 4:40 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    The inverter itself is mounted underneath the center console. I have no idea why the difference in load capacity. Perhaps it is due to the constant changing in the RPMs during driving conditions. I could speculate that a sudden drop in RPM would put a heavier strain on the battery than the alternator, and thus might cause the battery to fail sooner than anticipated. That is just a speculation though.
  4. Oct 21, 2009 at 4:46 AM
    kanelakos
    kanelakos Well-Known Member
    Binghamton, NY
    16 DC LB Sport
    I have one on my truck and I think for the most part, it pretty useless. Yes, you can charge cordless batteries with it. I wish it was powerful enough to run, say, a small shop vac or an angle grinder. Not enough watts produced though.
  5. Oct 21, 2009 at 5:10 AM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    they are fairly useful depending on what you use your truck for. those that camp find the most uses for them i would say. there is a mod that you can preform that will make the inverter run at 400 watts all the time regardless of whether you are driving or not. also some of us have chosen to add outlets inside the cab as well for charging things while driving. i just preformed both of those mods recently and love it. they will come in very handy when we go on extended trips camping or traveling.
    inverter always 400 watts mod... http://www.tacomaworld.com/forum/2nd-gen-tacomas/25944-110v-factory-inverter-always-400w.html
    outlets inside truck mod... http://www.tacomaworld.com/forum/2nd-gen-tacomas/25900-cab-110-ac-outlets-option-2-a.html
  6. Oct 21, 2009 at 5:23 AM
    WoadWunner
    WoadWunner Well-Known Member
    Peter
    Bridgetown, Nova Scotia
    17 Accesscab TRD Offroad Inferno
    Tonneau Cover, Devils Horns on the way, Blackened Grill, LED Low beams and Fogs, weathertecs
    It is well described in the owners manual. That is located in the glove box located forward of the passenger seat. It should be in a black fake leather folder.
  7. Oct 21, 2009 at 10:32 AM
    ideal4u
    ideal4u [OP] Member
    Thanks a lot for your very informative Post. No where in the owners manual does it say what people are using it for or describes what kind of load you can put on it or where it is located inside the truck. I was trying to find out what other owners have to say about the outlet, isn't that what this forum is for, INFORMATION? Do you use it just to post smart axx responses to new Taco owners or other Taco owners that have a legitimate question? If you can't say something nice, I wouldn't speak at all. Have a Blessed Day.
  8. Oct 21, 2009 at 3:26 PM
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
    Not true. I used my bed outlet to run an angle grinder and cut through a budbuilt skid plate. If it gets to bogged down it'll throw the overload cut off and you have to reset it but it's apsolutely possible to run power tools off it.
    I'm not saying you can drive into your backyard, throw a table saw on the tailgate and build a shed but it's plenty for basic work on the truck.
    I'm on constant lookout for a low-power coffee maker for tailgate java but so far no luck.
  9. Oct 21, 2009 at 6:07 PM
    Fire931
    VA
    00 4Runner
    keep looking.. one person i went wheeling with had one hooked up to their FJ so they do exist small enough to run off em....
  10. Jan 17, 2014 at 4:12 PM
    JimmyLB
    JimmyLB Member
    Jimmy
    Long beach
    2012 Tacoma debadged
    Mango flow exhaust, air raid cold air intake, unichip
    Is there any way to add power to the outlet, so I could run a circular saw?
  11. Jan 20, 2014 at 10:01 AM
    rhavin42
    rhavin42 Well-Known Member
    Vladimir
    Phoenix, AZ
    09 DC LB SPORT 4x4
  12. Jan 20, 2014 at 10:07 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar/Ontario, CA
    08 TRD 2wd converted to 4wd
    Estock
  13. Jan 20, 2014 at 10:08 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2013 DCSB 4X4 TRD Off Road *Sold*
    And..... The Richard Head Award for today goes too..... ^
    :rolleyes:
  14. Jan 20, 2014 at 11:47 AM
    Chicago Dan
    Chicago Dan Well-Known Member
    Dan
    Chicago
    Tacoma 4X4 Long Bed TRD Sport
    I've run a circular saw, drill, and several lights using it with absolutely no problem.
  15. Jan 20, 2014 at 12:56 PM
    martinh
    martinh Well-Known Member
    New Jersey
    2018 MBP Limited
    The farkles have started and on order
    I've run a Makita 7-1/4 circular saw with it with no problems.
  16. Jan 20, 2014 at 1:05 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    It can provide 3.6 amps or so at 400 watts. It can run many different things but you have to pay attention to amp draw. If the item pulls too many amps, the inverter cuts off.
  17. Jan 20, 2014 at 2:03 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Wouldn't that have been the Richard Head™ award for Oct 21, 2009? ;)
  18. Jan 20, 2014 at 2:05 PM
    RearViewMirror
    Craig Christ
    Haha... Why yes it would! That's what I get for posting on my phone lol;)
