help please, 2013 w/ 3" giving warning tone
Discussion in 'Technical Chat' started by Dark Knight, Jan 2, 2013.
  1. Jan 2, 2013 at 2:18 PM
    Dark Knight
    Dark Knight [OP] Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    I have a friend with a brand new 2013 truck. This truck has a 3" lift, when you are going around turns or if you have to swerve for something in the road the truck will give off a faint tone. Sometimes louder than others. No VSC or traction control lights come on in the cluster. The faint tone is like the truck is wanting to give a warning of some sort but never really gets the response to give a warning.
    My 05 has none of this electronic B/S so I'm a little lost on what is going on. Ideas?
  2. Jan 2, 2013 at 2:20 PM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
  3. Jan 2, 2013 at 2:21 PM
    Dark Knight
    Jeff
    NC/SC
    Already been done.
  4. Jan 2, 2013 at 2:23 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Maybe it's just the tires squeeling :notsure:
    Did one of the ABS wires possibly get yanked during installation, causing the ECU to not get feedback like it should?
  5. Jan 2, 2013 at 2:29 PM
    Dark Knight
    Jeff
    NC/SC
    I wish it was a tire squeeling. This is an electronic tone that sounds like it is struggling to make the noise it wants to. No ABS wires were pulled during install.
    Should also be noted the tires are 265/70/17 trail grapplers with dick cepek DC2 wheels. So there really is no "upsize in tire"
  6. Jan 2, 2013 at 6:05 PM
    Dark Knight
    Jeff
    NC/SC
    This truck is a long bed 4 door sr5.
  7. Jan 2, 2013 at 6:08 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    My truck does the exact thing and nobody seemed to believe me when I posted about it
    It sounds like it comes from under the front seat or driver's side dash , no ?
  8. Jan 2, 2013 at 6:11 PM
    Dark Knight
    Jeff
    NC/SC
    Yes. In this case it sounds like from behind portion between the radio and gauge cluster. It has a lot of people stumped.
  9. Jan 2, 2013 at 6:13 PM
    Dark Knight
    Jeff
    NC/SC
    I don't know if the two add up to anything but both your truck and this truck are DCLB.
  10. Jan 2, 2013 at 6:16 PM
    OZ-T
    Peter North
    British Columbia
    My experience is that it is definitely related somehow to the VSC or traction control system .
    I live on a small island and literally drive the same road a couple times a day , there are a few corners that are prone to kicking on the VSC / Traction control . It seems that if you are approaching the threshold at which the VSC will be engaged , but not quite at the threshold , this faint tone appears
    Turn off VSC and drive through the exact same corners at the exact same speed , no tone
  11. Jan 2, 2013 at 6:21 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    My 07 short bed did an electronic tone once while going down a gravel road. The tone sounded like the sound some elevators make when they stop at each floor (kinda like a tuning fork sound)... came from the dash around the radio. That was the first and last time i heard that sound in 5 1/2 years.
  12. Jan 2, 2013 at 6:22 PM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    You mean this? I remember you posting about a VSC issue and a re-flash a couple of years ago. I thought that cured it. Is this a different thing all together?
    Frank
  13. Jan 2, 2013 at 6:28 PM
    OZ-T
    Peter North
    British Columbia
    Yes , that's it
  14. Jan 2, 2013 at 6:42 PM
    OZ-T
    Peter North
    British Columbia
    Hey Jeff , has he taken it back to the dealership , and could the tech reproduce the tone ?
  15. Jan 2, 2013 at 6:44 PM
    Highland Logan
    Frank
    Nova Scotia, Canada
  16. Jan 2, 2013 at 7:20 PM
    OZ-T
    Peter North
    British Columbia
    Where is the yaw sensor located on a Tacoma ?
  17. Jan 2, 2013 at 7:21 PM
    Highland Logan
    Frank
    Nova Scotia, Canada
    Frank
  18. Jan 2, 2013 at 7:28 PM
    OZ-T
    Peter North
    British Columbia
    Thanks Frank
    Intrrestingly enough , it's exactly where it seems like the tone is coming from , at least in my case
  19. Jan 2, 2013 at 7:31 PM
    Highland Logan
    Frank
    Nova Scotia, Canada
    No problem and best of luck. Hopefully the sensor is easy to get at, and not dug in like a tick.
    Frank
  20. Jan 2, 2013 at 7:48 PM
    Dark Knight
    Jeff
    NC/SC
    Thanks for the links frank. We have even gone as far as adjusting the yaw sensor to give it the same angle as factory rake. I'll have to read those links when I have a little more time. The picture of the vsc buzzer seems to be exactly where the faint tone is coming from. It is so odd that it seems that it will not just give a solid tone, only a weak one.
