help quick!!! 2009 strut removal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SoutheastTaco, Mar 7, 2010.
  1. Mar 7, 2010 at 6:31 PM
    SoutheastTaco
    SoutheastTaco [OP] Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    im in the garage now trying to put a lift on how the hell do you remove the strut on a 2009 dc 4x4? im at a standstill
  2. Mar 7, 2010 at 6:34 PM
    soilsample
    soilsample Well-Known Member
    Donald
    Southwest Louisiana
    '09 4x4 Double Cab
    Hard part is to split the ball join on the upper control arm.
    After you pull off the wire clip and remove the 19 mm castle nut, you may meed to put a Jack under the spindle and lift it to get the ball joint out of it's bind. Then hit it with a hammer.
    BE CAREFUL NOT TO DAMAGE THE THREADS!!!!!
  3. Mar 7, 2010 at 6:36 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    screw the nut flush onto the bolt to hit it so you dont hurt the precious threads
  4. Mar 7, 2010 at 6:36 PM
    THROUGHITALLDUDE
    THROUGHITALLDUDE Someone didnt put the tailgate down!
    Jeff
    Southern California
    2005 Silver Tacoma
    285-75-17 Definity ATs - 16'' Chrome Moto Metal 951s - 4'' Maxtrac spindles - Rear Icon Progressive Leaf Pack - Magnaflow exhaust - Aftermarket LED Taillights - BHLM - Custom Wet Okle Seat Covers - Moog Tire Rods - US Spec Ipod - K&N High Flow Filter - Daytime Running Lights - TRD Skid Plate - Grillcraft - Hellas Mounted behind the grill
    where are you stuck at
  5. Mar 7, 2010 at 6:40 PM
    SoutheastTaco
    steven
    columbia sc
    09 trd sport dc 4x4
    ive got the uca loose i cant get the strut out?
  6. Mar 7, 2010 at 6:42 PM
    DieselTech
    DieselTech Well-Known Member
    Jeremy
    Nova Scotia
    2005 Taco
    3" Lift, Eagle Alloys, 285/75 Mickey Thompson BAJA's, Flowmaster 40 series, 8000k HID's, Low-pro tool box, 7" touchscreen with JBL speakers and sub,
    Once the UBJ if free, and the strut obviously, Get some leverage, and giver'
  7. Mar 7, 2010 at 6:42 PM
    SoutheastTaco
    steven
    columbia sc
    09 trd sport dc 4x4
    do i need to remove the three bolts and get the lca loose
  8. Mar 7, 2010 at 6:42 PM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    I had to use a pickle fork and a big hammer to break the spindle loose from the UCA. But first you have to remove the sway bar bolt.
  9. Mar 7, 2010 at 6:42 PM
    THROUGHITALLDUDE
    Jeff
    Southern California
    2005 Silver Tacoma
    it is just a matter of undoing all the bolts upper and lower and just yank the bottom of the shock out if its to stuck have someone push down on your brake rotor thus pushing the lower control arm down giving you some room to pull it out
  10. Mar 7, 2010 at 6:43 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    There is 3 bolts on top of the shock mount, you have to remove those and the one bolt at the bottom.
  11. Mar 7, 2010 at 6:44 PM
    DieselTech
    Jeremy
    Nova Scotia
    2005 Taco
    Right on the Nickel,
    But if your by yourself, grab a nice long breaker bar 25" or so, and pry down on the LCA and that should give you enough clearance to wiggle the bottom of the strut out. And make your that your jack stand are solid, ( unless on a hoist) ... I learnt that lesson the hard way.
  12. Mar 7, 2010 at 6:56 PM
    SoutheastTaco
    steven
    columbia sc
    09 trd sport dc 4x4
    the sway bar is in the way but the drivers side wont rotate up to move it out of the way?
  13. Mar 7, 2010 at 6:58 PM
    DieselTech
    Jeremy
    Nova Scotia
    2005 Taco
    Oh yeah lol, unbolt the sway bar, either twist it up, or forward. What lift are you installing?
  14. Mar 7, 2010 at 6:58 PM
    THROUGHITALLDUDE
    Jeff
    Southern California
    2005 Silver Tacoma
    ok remove your skid plate and undo the sway bar so that it flips backwards out of the way if that doesnt work take it off until your finished
  15. Mar 7, 2010 at 7:48 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
  16. Mar 7, 2010 at 7:53 PM
    SoutheastTaco
    steven
    columbia sc
    09 trd sport dc 4x4
    okay got it out putting it back in how about the lower strut bolt?
  17. Mar 7, 2010 at 7:54 PM
    THROUGHITALLDUDE
    Jeff
    Southern California
    2005 Silver Tacoma
    whats your question
  18. Mar 7, 2010 at 7:56 PM
    SoutheastTaco
    steven
    columbia sc
    09 trd sport dc 4x4
    i cant get it to line up
  19. Mar 7, 2010 at 7:56 PM
    DieselTech
    Jeremy
    Nova Scotia
    2005 Taco
    You're gunna have to fight with er' for a minute or two. If you put a spacer in (assuming you are) it makes it quite a bit harder. Again use you leverage, or your buddy to wiggle the LCA until she slides into spot.
  20. Mar 7, 2010 at 7:59 PM
    aficianado
    back to bone stock.
    stick a rod in there and twist it until it lines up. i have seen the use of 1/4" ratchet extension. i would use a punch.
