Help wiring Hella 700ff with HID conversion
Discussion in 'Lighting' started by MJonaGS32, Jun 18, 2010.
  1. Jun 18, 2010 at 10:43 PM
    MJonaGS32
    MJonaGS32 [OP] MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    I need helping wiring the HIDs to the Hella 700ff relay.
    - Each ballasts has a red and black wire. I'm assuming power and ground.
    - The Hella 700ff relay has red (power), blue (ground), yellow (relay trigger), and black (output to lamps) wires. Then there's an extra green wire to power the switch.
    With the red and black wires coming from the ballasts, which color wire from the relay does it connect to? I know that it's obviously not red (power) and blue (ground), but I'm left with yellow and black.
    Can anyone tell me which wire goes where?
    Also, for the rocker switch, I can either pick the ground or power wire (from the relay) right? Just as long as the switch breaks and opens the current?
    idk why I'm being such a noob with this LOL. I think the wire colors on the relay are tripping me out because blue is ground and black is the output to the lamps.
    Thanks for the help everyone.
  2. Jun 18, 2010 at 10:46 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
  3. Jun 19, 2010 at 8:01 AM
    MJonaGS32
    MJ
    SF Bay Area (East)
    the only thing in that thread that has anything to do with the wiring is this:
    which is the obvious thing to do, but now does that go to the black wire (output to lamps) of the relay? Then where does the yellow wire (relay trigger) go to? And then does the negative wire from the ballast just get grounded?
  4. Jun 19, 2010 at 8:13 AM
    MJonaGS32
    MJ
    SF Bay Area (East)
