help with eibac/bilstein lift kits
Discussion in 'Suspension' started by jake slatnick, Nov 1, 2009.
  1. Nov 1, 2009 at 10:00 PM
    jake slatnick
    jake slatnick [OP] Well-Known Member
    jake
    San Diego
    Cement TRD Pro
    285/75r16 KO2's, Baja XL 80's on CBI ditch brackets, TRD intake, opticoat pro, clear bra running the bottom sides, morimoto LEDs, all white LEDs inside, mounted shovel and axe above wheel well in the bed, linex'd the bed...
  2. Nov 1, 2009 at 10:05 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    option 4
    1/4" front spacer for leveling
    it says it in the description
  3. Nov 1, 2009 at 10:08 PM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    ya i saw the description but what is a 1/4" front spacer and do i need it for the prerunner?
  4. Nov 1, 2009 at 10:15 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    the spacers are good to get the full 3" lift. alot of people only use the driver side one to fix the taco lean
  5. Nov 2, 2009 at 8:21 AM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    4 has 1 spacer to even out the famous lean and 3 doesn't have any spacers
