Help with truck problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Criley530, Jan 20, 2017.
  1. Jan 20, 2017 at 1:47 PM
    Criley530
    Criley530 [OP] Active Member
    06 Tacoma
    Who knows?
    I have a 06 trd . nothing but problems since i got it. The rear leans to the left about 1.5 2 inches lower than pass side. Has sky jacker tcr515 leafs skyjacker shocks on rear noticed that there is about 1 inch of homemade shims under leaf that is lower. Leaf looks allot flater than other side..... Is it a shock or a leaf spring issue?trucks all over the road very hard to keep in the lines? Needs a new wheel bearing on front can't find one that is already done ? Either buy the bearing and hub and have them pressed i just want one together so i can take off old put new on any help is greatly taken . oh one more thing p0430 code. I've done new Plugs oil . Is it bad cat or bad cylinder? Misfire help me plz.
  2. Jan 20, 2017 at 1:52 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    The only help I can supply is that a shock will not cause any lean. It dampens the shock of bumps and holes, nothing else.
  3. Jan 20, 2017 at 1:53 PM
    Criley530
    06 Tacoma
    Who knows?
    Ok check that off the list. thank you .
  4. Jan 20, 2017 at 1:55 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    P0430, try the cheaper route..... 02 sensor first.
    As for the lean, all 2nd gens lean.... its called the taco lean and toytec even sells something called a driver side lean spacer.
    Criley530[OP] likes this.
  5. Jan 20, 2017 at 1:58 PM
    Criley530
    06 Tacoma
    Who knows?
    I've heard maybe a exhaust leak could throw that code? Any idea how to check for misfire? I'm new to newer Tacoma's. I've always owned 85-89 str8 axle trail trucks. Thank you btw
  6. Jan 20, 2017 at 2:01 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Check with BamaToy for the front wheel bearings.
    TacoCat and 303tacoma like this.
  7. Jan 20, 2017 at 2:01 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
  8. Jan 20, 2017 at 2:05 PM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    Actually, it's BamaToy1997
    303tacoma likes this.
  9. Jan 20, 2017 at 2:06 PM
    303tacoma
    Rebecca
    Linked above:D
  10. Jan 20, 2017 at 2:06 PM
    Criley530
    06 Tacoma
    Who knows?
  11. Jan 20, 2017 at 2:06 PM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    Duhhh.... :)
    303tacoma[QUOTED] likes this.
  12. Jan 20, 2017 at 2:08 PM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    I have the Bamatoy front wheel bearings on my 2006 OR. Basically a "Plug-N-Play" installation.
  13. Jan 20, 2017 at 2:17 PM
    303tacoma
    Rebecca
    I have the same very easy install!!!
    Skrain[QUOTED] likes this.
  14. Jan 20, 2017 at 2:21 PM
    Criley530
    06 Tacoma
    Who knows?
    Ok yeah I'll get that part. That's done. With. Gonna order tomorrow. thanks. Anyone have a 3 inch lift cheap for 06 double cab Tacoma? Or a tcr515 leaf spring for sale?
    Skrain likes this.
  15. Jan 20, 2017 at 2:27 PM
    303tacoma
    Rebecca
  16. Jan 20, 2017 at 2:53 PM
    BKill
    BKill AKA Threadkiller
    Bill
    College Station, TX
    2013 Tacoma PreRunner
    I think I read on here somewhere that some aftermarket suspensions have side specific springs to counteract the lean. Is it possible that yours does and that whoever installed them didn't know that and has them on the wrong sides?
  17. Jan 20, 2017 at 5:17 PM
    RedTac0ma
    RedTac0ma Member
    p0430 U need a manifold for bank 2
  18. Jan 20, 2017 at 7:24 PM
    Criley530
    06 Tacoma
    Who knows?
    Gasket or mani? sounds like could have leak right there. when its cold.
  19. Jan 21, 2017 at 2:52 AM
    RedTac0ma
    RedTac0ma Member
    Unfortunately the manifold that's the efficiency below threshold code
  20. Jan 21, 2017 at 3:29 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    This should sort out your lean problems (one of the full packs) and maybe some new coilovers. These are kind of the cheaper end of high quality parts. There's a lot of info on this stuff on the site plus calling Toytec directly or emailing them proved helpful to me in the past regarding their products. Suspension's a little easier to suss out than engine stuff at least on paper. Sounds like you're giving your truck an overdue makeover!
    http://toyteclifts.3dcartstores.com/Rear-Lifts_c_91.html
