hey ima detailer! no really...
Discussion in 'Detailing' started by stunt man hans, Sep 15, 2010.
  1. Sep 19, 2010 at 9:48 AM
    stunt man hans
    stunt man hans [OP] DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    picture of paint trying to show scratch? assuming they are light scratches and not an overwhelming amount of them any detail shop should be able to buff them out. for situations like this i used a dewalt buffer with a green general application pad and a polish called diamonds crystal four made by a company called ardex that polish is not a compound it just deepens the finish very nicely and helps the high speed buffer stay lubricated.
  2. Sep 19, 2010 at 9:52 AM
    Flynn Diesel
    Flynn Diesel Well-Known Member
    Phoenix, AZ
    2010 PreRunner SR5 Double Cab
    •BFG AT KO 285/70/17, XD Addict 17x9, Light Racing UCA’s, Billstein 5100’s, OME 885’s, Toytec AAL, Seat Belt warning disable, Grill Craft Black MX Upper & Lower Grill, VisionX 55/65 watt xenon Low/High Beam lights. FOG Light only Mod. Tailgate theft prevention mod. Wet Okole armrest mod. Redline Hood Struts, Weathertech floor liners. AMP Bed Extender. Wet Okole Seat Covers. Pioneer P4200DVD
    How do I get yellowing of my tire walls. Not sure what it's from but my motorcycle was sitting for a while and now the tires look like crap. I've scrubbed the shit out of them but as soon as they dry, they look yellow again.
  3. Sep 19, 2010 at 9:53 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    try a wax first carnuba wax and a clean cotton applicator pad that is kept damp through out the process. work small areas at a time and lay the wax on heavy make sure the pad i wet and lightly try and work them loose with the misture in the pad and the wax then once again lightly scratch them off with your finger nail. then a polish.
  4. Sep 19, 2010 at 9:58 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
  5. Sep 19, 2010 at 10:01 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    if you decide to take it to have it done professionally take it to the toyota dealership not some where else let their recon dept work on it. that way if the burn anything they have to replace it just look the car over good and know what blemishes where on the car before they started.
  6. Sep 19, 2010 at 12:49 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    My hood has what looks like water spots etched into the paint. The hood looks good until you view it from the side in direct sunlight. What do you advise, or is it too late to fix? I've tried cleaners and wax but they don't touch it.
  7. Sep 19, 2010 at 1:24 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Water Spots on windshield? How can I has them come off?
  8. Sep 20, 2010 at 9:54 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    super fine steel wool and spray wax or window cleaner prob solved. just press with a normal amount of pressure it will not hurt your window make sure its super fine steel wool.
  9. Sep 20, 2010 at 10:02 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    hard water or acid rain yikes. you will need to have your car buffed i would suggest taking the car to the dealership and having them buff it out as it will need to be cut and polished then sealed. i would be careful where you park this chick i worked with had terrible water spots and it was coming from her sprinkler system it would kick on over night and wet her car hard water is a common thing with most lawn systems as they are not really filtered or softened. you could try going at it by hand if its not that bad, but i would suggest a professional.
  10. Sep 20, 2010 at 10:06 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    something out there saw fit to only let me drive black trucks. i mean no matter what i always end up in black wtf! for those of you out there that want to get the most out of your dark colored truck i will post pictures and descriptions of the store bought chems i swear by. some are actually better than the stuff the pros use and some almost seemed designed to destroy your rig's finish. more to come
  11. Sep 20, 2010 at 10:08 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Hey OP, in your opinion what would be the best thing to use to get rainspots off the windshield without using wool? i dont feel like searching here
  12. Sep 20, 2010 at 12:00 PM
    printman2000
    printman2000 Well-Known Member
    Amarillo, Tx
    09 Double Cab TRD
    Upon closer inspection, it is small chips. It really looks like it was sand blasted.
    Guess the only option is to replace the windshield. No money for that so in will live with it for now. Thanks for the help.
  13. Sep 20, 2010 at 12:07 PM
    The_Dude
    The_Dude Well-Known Member
  14. Sep 20, 2010 at 10:36 PM
    I Liquid I
    I Liquid I Well-Known Member
    Puerto Rico
    06 BSP DCLB, 17 Inferno TRD Offroad DCSB, 06 SW ACLB
    Too many mods to list
    You do mean polish first and wax second right?...
    Because if you wax first and polish after... you are pretty much just taking out the wax you just put on the area...
  15. Sep 20, 2010 at 10:39 PM
    #35
    I Liquid I
    Puerto Rico
    1. Tuff Stuff the roof.
    2. Brush with mild brush.
    3. Wipe excess with towel.
    4. Oh damn!, it looks brand new.
    I did this to a couple cars ive had, some of them had very soft tops and there has never been any damage. Unless your thing is falling apart in which case... replace...
    For the seats... you should seriously get some seat covers... and put something between the seat and the seat cover... cause that looks gross...
  16. Sep 20, 2010 at 10:41 PM
    #36
    I Liquid I
    Puerto Rico
    You should try waxing that windshield... youd be amazed at how little youll see some of the imperfections on glass as well as how well your wipers will work and how much less rain affects your visibility. Try to work the wax, work it!
  17. Sep 20, 2010 at 10:42 PM
    #37
    I Liquid I
    Puerto Rico
  18. Sep 21, 2010 at 1:20 AM
    #38
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    lol dude your seats need to be steam cleaned. we have a machine that heats the water and citrus cleaning solution we use to around 250 degrees and it rocks out anything. as far as the headliner this you could do yourself. try finding a generally light all purpose cleaner and dilute it with 50/50 with water then have on hand a bucket full of hot water and a large hand towel. wet the towel ring it out then spray the allpurp on it then work a section at a time going in one direction rinse and repeat when towel gets funky to avoid spreading caca around. do not rub to hard or go to crazy with it if you need to make the solution stronger just make sure it says its safe for fabrics. also try not to get the head liner to wet, if you get it to wet it can sometimes look clean on the surface only because it darkens up and makes the stain less noticable. on a side not you could look into renting a steam cleaner and doing it yourself price it out and see whick one is cheaper.
  19. Sep 21, 2010 at 1:24 AM
    #39
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    you could use the tuff stuff spray but i would advise against using any sort of brush on a headliner. that would not provide the results your gonna be looking for:eek:
  20. Sep 21, 2010 at 5:03 PM
    #40
    The_Dude
    Lol thanks guys...I really appreciate the sharing of knowledge...+1's goin' out!
