HID Fog vs HID long range ?'s
Discussion in '1st Gen. Tacomas (1995-2004)' started by XCR89, May 5, 2012.
  1. May 5, 2012 at 9:02 AM
    XCR89
    XCR89 [OP] Member
    Mitch
    Utah
    2002 ext cab Tacoma 5vz-fe
    ARE Camper, 265/75-16 Goodyear duratracks,
    Hey everyone this is my first post here, and I just want to get some opinions.
    Right now I have a pair of KC HID Daylighters (flood/fog beam) recessed into my grill, and I want to add some lights for longer range lighting, however I don't really want to spend the $$$ for another set of HIDs (got these for an absolute steal!)
    So should i buy some long range lenses for the Daylighters and get some fog beam halogens?
    Or should I keep the HIDs as fogs and get some long range halogens?
    P.s. for halogens i'm looking at something around $200 range.
    Thanks for your help guys!
  2. May 5, 2012 at 9:17 AM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
  3. May 5, 2012 at 10:50 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    do the Hellas!
    i have 4 HIDed and they rock!
  4. May 5, 2012 at 11:50 AM
    XCR89
    XCR89 [OP] Member
    Mitch
    Utah
    Ok i guess my question simplified is are my daylighters better as floods or would they be better utilized as long range lights. Im starting to look into rigid light bars too they seem fairly affordable and put out a ton of light it seems like.
  5. May 5, 2012 at 12:18 PM
    Taqoma
    Brennan
    Los Angeles
    2011 TRD Off-Road
    rigid and affordable are mutually exclusive terms :D
    I have no real-world experience with daylighters...it sounds like you want to change the daylighters into pencil beam lights and then buy an extra set of fogs for flood light?
    why not keep daylighters as your flood light / fogs and then HID some Hellas for your long range?
  6. May 5, 2012 at 12:52 PM
    XCR89
    XCR89 [OP] Member
    Mitch
    Utah
    the 10" rigid is $280 on Amazon, that ain't too bad i think. but you do have a point the hellas with a conversion kit it pretty cheap too and look great. I guess the whole reason i like the rigid is cause could mount it to the bumper just below my KCs, where if i went with the hella conversion i would have to mount them to the roof bars on my ARE top, then it might not fit in my garage.
  7. May 5, 2012 at 12:53 PM
    XCR89
    XCR89 [OP] Member
    Mitch
    Utah
    here is my set up pre ARE top [​IMG]
  8. May 5, 2012 at 1:03 PM
    Taqoma
    Brennan
    Los Angeles
    2011 TRD Off-Road
    ahhh ya I see what you're going for now. seems you know what you want already ;)
  9. May 5, 2012 at 1:23 PM
    XCR89
    XCR89 [OP] Member
    Mitch
    Utah
    I don't know i'mim torn. Might have to wait till I build a bumper then just see how many lights it takes to fill in the gap between the headlights lol.
    If I was rich I would just do a 40" Rigid led bar on the top and call it good!
    Brennan does having your lights behind the grill affect output or dispersion at all?
  10. May 5, 2012 at 1:30 PM
    Taqoma
    Brennan
    Los Angeles
    2011 TRD Off-Road
    not at all they're just too damn bright. I have the 55w bulb/ballast
