HID Retrofit 2009 Tacoma Extended Cab
Discussion in 'Lighting' started by 95SLE, Mar 27, 2012.
  1. Apr 3, 2012 at 2:12 PM
    #41
    Oury
    Oury Texas Taco
    Oury
    Austin, Tx
    07 TRD Offroad
    stuff and more stuff
    got it figured out, problem is, lows don't work and high beams do. Call TRS and they are sending me a update harness.
  2. Apr 3, 2012 at 6:12 PM
    #42
    95SLE
    95SLE [OP] Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    :thumbsup:
  3. Apr 4, 2012 at 9:23 AM
    #43
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
  4. Apr 4, 2012 at 10:22 AM
    #44
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    tried swapping highs for lows and lows for highs?
  5. Apr 4, 2012 at 7:08 PM
    #45
    pringles808
    pringles808 Well-Known Member
    Honolulu
    2012 SW PreRunner
    OME 885x, Bilstein 5100 f/r with driver lean spacer, toytec 2" aal, D2S Morimoto 5000k HID Retrofit, BHLM, Switchbacks, Roll N Lock
    thanks for the write up, will be doing this soon.
  6. Apr 5, 2012 at 12:59 PM
    #46
    Oury
    Oury Texas Taco
    Oury
    Austin, Tx
    07 TRD Offroad
    I did that, I was on the phone with TRS while I was working on it. They were extremely helpful too. When I swapped the Hi/Low in the Harness, I blew the fuses in my fuse box. They are sending me a new harness so I wont mess with it till I get it.
  7. Apr 5, 2012 at 1:00 PM
    #47
    Oury
    Oury Texas Taco
    Oury
    Austin, Tx
    07 TRD Offroad
    first set. gotta seal this one and balance both after the other one is finished.
  8. Apr 6, 2012 at 4:16 AM
    #48
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Looks good Oury. Nice even cut and the projector is lined up horizontally.
  9. Apr 6, 2012 at 5:44 AM
    #49
    Oury
    Oury Texas Taco
    Oury
    Austin, Tx
    07 TRD Offroad
    Thanks! I couldn't have done it without your input! Just waiting on my new harness now. Funny thing, it took me about an hour too align the first projector in the housing... second one took 5 minutes cus I learned the best place too drill the holes. piece of cake :p
    cant wait too seal them up and aim them. did you pull out all the old "gray" window sealant that is on them when you pull the headlights apart? or you use new stuff
  10. Apr 6, 2012 at 9:19 AM
    #50
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    I have a hot air gun and I used it and a screwdriver to clear the channel. In retrospect I would have either done a better job of clearing out the channel or made the black caulking that came with the retrofit kit thinner. Clamping the headlights back together was a PITA.
  11. May 2, 2012 at 7:39 AM
    #51
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Thanks for the write up and pics.
    I have a question about attaching the shroud to the projector. Do I glue the black plastic ring that clips in to the shroud straight to the projector or is there a better way to attach the shroud?
    I am using FX-R projectors and orbit shrouds from TRS.
  12. May 2, 2012 at 5:00 PM
    #52
    AsianAnts
    AnT
    i would use an adhesive to have the black ring stick and clipped into the shroud. Then i would use adhesive to stick the shroud to the projector...
    Hi-Temp silicon works or JBweld works... Do not depend on the ring alone clipped to the shroud to stay on the projector.. i've heard stories and witness them falling off later down the road.
  13. May 2, 2012 at 6:56 PM
    #53
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    What he said ^^^^^
    I used this product for the Gatlin Gun shroud. Both for the black ring to the shroud and the shroud to the FXR projector.
    http://www.permatex.com/products/au...ermatex_High-Temp_Red_RTV_Silicone_Gasket.htm
    So far no problems after 2+ months.
  14. May 7, 2012 at 8:27 PM
    #54
    jimmybee1108
    jimmybee1108 Well-Known Member
    JM
    San Antono
    2012 blk DC sr5 v6 prerunner
    bilstein 5100s, wheelers AALs, amazon dual 10 sub box, with two jlw1s cheap HIDs
    Anyone know of anywhere that can do a complete retrofit projector job in San Antonio Texas.
  15. May 8, 2012 at 6:19 AM
    #55
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    You might want to send a PM to AsianAnts. He does quality work at a fair price.
  16. Jul 22, 2012 at 8:50 AM
    #56
    Taco89
    Taco89 Well-Known Member
    Nik
    Charlotte, NC
    2013 4x4 Super White DBL Cab TRD Sport
    I am about to begin this project in a couple of weeks and just wondering how do you align the headlights once you retrofit them, before sealing the lens back on?
  17. Jul 22, 2012 at 8:52 AM
    #57
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    You want to get the rotational alignment set before you reinstall the lenses or jb weld the projector into the bowl.
  18. Jul 22, 2012 at 8:59 AM
    #58
    Taco89
    Nik
    Charlotte, NC
    Thanks!
  19. Jul 22, 2012 at 11:34 AM
    #59
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    There's a couple of writeups, the best way seems to be to build a jig in your shop that uses the stock mounting lugs and aims the unit at a target... perhaps a garage door, block wall... some fixed object that you can put a piece of tape on to indicate the cutoff line.
    So mount the stock housing into the jig and light it up.
    Mark the location of the cutoff (and step).
    Begin the retrofit, and make sure the jig doesn't get moved.
    When the projectors are mounted and ready to test, re-mount the housing into the test fixture and adjust the projector so the cutoff matches your stock cutoff.
    That should be reasonably close when sealed and remounted.
  20. Jul 22, 2012 at 12:08 PM
    #60
    Taco89
    Nik
    Charlotte, NC
    Thanks Rich.
