Hidden storage in center console
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 907Yoda, May 8, 2014.
  1. May 8, 2014 at 7:04 PM
    907Yoda
    907Yoda [OP] currently trying to get lost...
    Rapid City SD
    2015 TRD Off Road
    13% Tinted, 5000k HID headlights and fogs, Wet Okole Seat Covers, Weathertech wind deflectors, 13" Shorty antenna, PowerAid throttle body spacer, XTP Intake Manafold Spacer, Magnaflow cat back exhaust, grillcraft grill
    Does anyone know if there is anything located under the center console? I was thinking of maybe cutting out the bottom under the carpet and putting a lock box flush with the bottom and laying the carpet over it.. Kind of a secret compartment if you will. I imagin there isn't much space under there.
    What are your thoughts?
  2. May 8, 2014 at 7:05 PM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    Take the console out and see if it is doable. I'd watch :popcorn:
  3. May 8, 2014 at 7:07 PM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
  4. May 8, 2014 at 7:18 PM
    907Yoda
    Rapid City SD
    2015 TRD Off Road
    Wow great write up. I did search but didn't come up with anything. From those pictures it looks like there is some space to work with. Im going to tear it apart and get measurements then start looking for boxes. I will update with pictures once i get back to my truck in a few weeks.
  5. May 8, 2014 at 7:33 PM
    ziggynagy
    Stoughton, MA
  6. May 8, 2014 at 7:39 PM
    Ray
    Ray Well-Known Member
    San Diego
    09 Pre-Runner
    From the California Health & Safety Code:
    "11366.8. (a) Every person who possesses, uses, or controls a false
    compartment with the intent to store, conceal, smuggle, or transport
    a controlled substance within the false compartment shall be punished
    by imprisonment in a county jail for a term of imprisonment not to
    exceed one year or pursuant to subdivision (h) of Section 1170 of the
    Penal Code.
    (b) Every person who designs, constructs, builds, alters, or
    fabricates a false compartment for, or installs or attaches a false
    compartment to, a vehicle with the intent to store, conceal, smuggle,
    or transport a controlled substance shall be punished by
    imprisonment pursuant to subdivision (h) of Section 1170 of the Penal
    Code for 16 months or two or three years.
    (c) The term "vehicle" means any of the following vehicles without
    regard to whether the vehicles are private or commercial, including,
    but not limited to, cars, trucks, buses, aircraft, boats, ships,
    yachts, and vessels.
    (d) The term "false compartment" means any box, container, space,
    or enclosure that is intended for use or designed for use to conceal,
    hide, or otherwise prevent discovery of any controlled substance
    within or attached to a vehicle, including, but not limited to, any
    of the following:
    (1) False, altered, or modified fuel tanks.
    (2) Original factory equipment of a vehicle that is modified,
    altered, or changed.
    (3) Compartment, space, or box that is added to, or fabricated,
    made, or created from, existing compartments, spaces, or boxes within
    a vehicle."
    The key here is "with the intent to" If you have/make/install etc. just to be able to secure valuables etc. you should be okay, but check your States Codes etc. to be sure. It also would hurt to print and keep a copy of your States code in the vehicle.
    Ray
  7. May 8, 2014 at 8:11 PM
    ziggynagy
    Stoughton, MA
    Cuz the OP in South Dakota wants to read CA statute?
  8. May 8, 2014 at 8:49 PM
    907Yoda
    Rapid City SD
    2015 TRD Off Road
    It was just a cool idea that I could keep valuables or whatever I want in it. Im not a drug smuggler or anything like that. Maybe store some emergency cash in there or what not. Thanks for the advice though I had no idea there was a law like that. California has lots of crazy laws though. im not suprised at all
  9. May 8, 2014 at 9:08 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    in the california code when they say substance are they saying drugs ONLY?
  10. May 8, 2014 at 9:10 PM
    tomwopat
    tomwopat Well-Known Member
    Memphis, TN
    2012 DCSB Prerunner
    Dear lord I'm glad I didn't move to commiefornia when I was thinking about it...
    To the OP, I pulled the carpet from the center console thinking that I had discovered some brilliant idea to hide a gun until a read a few threads on TW... Now I'm looking for a different alternative because apparently I'm not the only genius to wanna hide a weapon under a false bottom in the console. Sub'd to see any different ideas.
    :confused:
  11. May 8, 2014 at 9:14 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    there is not much room between the inverter and console. i kinda had a hard time running the cable for my ipod thru the bottom of it. i’d say maybe 1/4” or so.
  12. May 8, 2014 at 9:24 PM
    907Yoda
    Rapid City SD
    2015 TRD Off Road
    Yeah thats mainly what i was thinking or any valuables. I am still going to investigate and see how much room I have to work with. I would like to hear any different ideas as well
  13. May 8, 2014 at 9:26 PM
    907Yoda
    Rapid City SD
    2015 TRD Off Road
    thats all? it seems like there is more room at a side angle. like a couple inches
  14. May 8, 2014 at 10:20 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    maybe 1/2”? defiantly not a couple of inches maybe on the very sides/edges, the inverter dose not go to the edges of the console but in the middle where it is there is not much room. i had to take it out to get the cable for my ipod started in a hole, and even after i bolted it back down it was hard to adjust the wire was hitting/ rubbing the inverter.
  15. Jun 20, 2014 at 2:47 PM
    Ray
    San Diego
    09 Pre-Runner
    "... but check your States Codes etc. to be sure. It also would hurt to print and keep a copy of your States code in the vehicle."
    After 30-years in law enforcement I've learned that most States have similar statutes and a lot of them model theirs after California's.
    Ray
  16. Jun 20, 2014 at 2:52 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    x2. also check the state codes/ statutes every 6 months to 1 year incase they change, don’t want to get a surprise that they changed when you get stopped.
