HIDS and light bar suggestions? I'm New to all of this
Discussion in 'Lighting' started by 13tacoma4x4, Aug 27, 2013.
  1. Aug 27, 2013 at 6:53 PM
    13tacoma4x4
    13tacoma4x4 [OP] Well-Known Member
    Adam
    Central Kentucky
    13 4x4 double cab trd sport
    Aries bull bar Nerf bars 15% tint all the way around 3" lift
    Just recently bought my 13 taco a few months ago! I wanted to smoke out my lights then throw in some hids but not really sure what kind or anything to go with! I want some good quality but not spend anything crazy! Any ideas?
    Also was thinking on getting a light bar for the lower grill! I heard rigid light bars are really good but pricey! Any other recommendations! I'm new to all of this lol
  2. Aug 27, 2013 at 7:01 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    The ridgids are a good route to go for the led bar.
  3. Aug 27, 2013 at 7:08 PM
    adriancast
    adriancast Well-Known Member
    Adrian
    Ontario, Ca
    2005 Tacoma 4x4 TRD Off-Road
    -2.5 Donahoe Coilovers -All Pro Standard Leaf Pack -All Pro U Bolt Flip Kit -Front/RearWheeler Super Bumps -Extended rear Bilstein 5100s -Flowmaster 40 Series -All Pro IFS Skid -All Pro Transmission Skid -Bruteforce Hybrid Bumper -30" Double Row LED bar -400 Watt Anytime -TRD Seat Covers -ABS Kill Switch -Locking Center Console Mod -Rear Differential Breather -BHLM -Anytime Fog Light Mod -Toyota Hilux Snorkel
  4. Aug 27, 2013 at 7:21 PM
    13tacoma4x4
    Adam
    Central Kentucky
    Thanks for the heads up! I have a bull bar on the front of mine so I was thinking about going with the 20in rigid bar in the lower grill in the opening or the bar
  5. Aug 27, 2013 at 7:22 PM
    13tacoma4x4
    Adam
    Central Kentucky
    That's what I've heard! I want the 20in looking like it will run me about $530
  6. Aug 27, 2013 at 7:24 PM
    adriancast
    Adrian
    Ontario, Ca
  7. Aug 27, 2013 at 7:25 PM
    adriancast
    Adrian
    Ontario, Ca
    I bought my 21 inch LED bar from Blitzpro for $160
  8. Aug 27, 2013 at 8:16 PM
    13tacoma4x4
    Adam
    Central Kentucky
    Good looking truck! That sounds pretty legit! Have u had good luck with your LED bar? No problems or anything
  9. Aug 27, 2013 at 8:23 PM
    adriancast
    Adrian
    Ontario, Ca
    Zero problems.
  10. Aug 27, 2013 at 8:24 PM
    adriancast
    Adrian
    Ontario, Ca
    Go big tho. I wish I got 30+ inch double row.
  11. Aug 27, 2013 at 8:57 PM
    Spencer
    Spencer Future President
    TIGGLEBITTIES
    Upland, Chino... all of 909.
    2013 DCSB 4X4 6cyl Sex Machine
    Redline hood lift, Flyzeye cabin lights, tailgate lock, SPOD Power block, VIAR onboard air, Cobra CB radio, Firestick 4' Antenna, Hot Blonde CoPilot Mod, SIX 9" Hella 4000 HID conversion with external 55W ballasts, Six 6" LED bars, Napier Bed Tent, Mudflaps delete using rocks, Roof rack by Brute force, Rock sliders by Brute force, Bed LED lights, Underhood LED automatic lights, Constant 12V bed plug, Rugged race radio, ICON uniball UCA's, KING 2.5 700 rate coilovers, Deaver rear leaf springs, KING 2.5 resi rear shocks (Flat 0.15 stack on compression shims), Scangauge, Empty wallet Mod Bug disease, AllPro Apex front bumper, On board heat exchange shower & water pump (Heater Core intercept mod), On Board Air - Viair for now, ARB when it dies-, allpro Skids back to gas tank- Tepui RTT on the shittiest "Bed Rack" ever made.... AllPro U Bolt flip kit with timbren bumps NEXT UP- expo leafs & bed rack, hydraulic bumps in rear, Total Chaos stock LCA's w/ Bypass, Rear 12" shock hoop relocate
    Welcome to TW!
    Prepare your wallet.
    I've got my '13 as well and.... well It's 8 months old and check the build page...
    anyways
    know this for LED's and Hid's/ incandescents- it might help guide you further for your light bar!
    Led's can be bright A.F., and use low power, but just don't project very far. they're great up to 20 ish feet, but everything but maybe that 50" rigid just dont light up what's way out there. Great for rock lights, camp lighting etc.
    HID's use very low power, and put out HUGE amounts of light, and because they are typically built in normal concave housings, they can throw a spot a good quarter mile down or light everything up with a flood. however, they come in HUGE ranges as far as quality/ price- 50$ to 600$ per light, cheap ones are built with cheap ballasts that blast your truck with RF interference which literally kill the engines on some Jeeps and make it near impossible to listen to any radio station. they also typically come in very cold light temperatures, putting out extremely bright, but white to blue light which is actually pretty hard on your eyes, and hard to see depth/ read the ground (everything turns black and white, lacks natural color)
    Incandescents! (Halogens) Put out warm, natural light which is very easy on your eyes and show depth/ detail the best allowing you to really read the ground safely for hours, come in a wide range of housings (spot, 90 degree flood, 120 degree etc) allow you to meticulously fine tune your lighting designs, can throw the best spot light further than you can ever need! BUT take massive amounts of power when wired up- you could very easily pull 50+ amps with four lights which creates tricky logistical issues to avoid a wire fire/ dead battery.
    Lots to take in, but it's experience you need to take the easy way. If you like to go fast, you'll need to see what's way out ahead and LED's just wont cut it to see that rut or rock @ 60 mph. On a budget & occasionally go fast? HID's. Go fast offroad regularly? go for some good quality halogens with the warmest kelvin light. like to rock crawl & set up camp in the dark? LED's.
    Cheers!
